Я купил VPN-сервис, и мне дали только конфигурационный файл. Как конвертировать conf в ROS? Вот содержимое openvpn.conf:
setenv FORWARD_COMPATIBLE 1
setenv UV_SERVERID 352
client
dev tun
proto udp
remote 118.163.202.118 8292
nobind
persist-key
persist-tun
ns-cert-type server
key-direction 1
push-peer-info
comp-lzo
explicit-exit-notify
verb 3
mute 20
reneg-sec 86400
mute-replay-warnings
max-routes 1000
-----BEGIN CERTIFICATE-----
MIIEFTCCAv2gAwIBAgIJAOt26+6pZCokMA0GCSqGSIb3DQEBCwUAMGQxCzAJ BgNV
BAYTAi4uMQswCQYDVQQIEwIuLjELMAkGA1UEBxMCLi4xCzAJBgNVBAoTAi4u MQsw
CQYDVQQLEwIuLjEOMAwGA1UEAxMFQVNDQTIxETAPBgkqhkiG9w0BCQEWAi4u MB4X
DTE0MDQxMTIwNTgwMloXDTI0MDQwODIwNTgwMlowZDELMAkGA1UEBhMCLi4x CzAJ
BgNVBAgTAi4uMQswCQYDVQQHEwIuLjELMAkGA1UEChMCLi4xCzAJBgNVBAsT Ai4u
MQ4wDAYDVQQDEwVBU0NBMjERMA8GCSqGSIb3DQEJARYCLi4wggEiMA0GCSqG SIb3
DQEBAQUAA4IBDwAwggEKAoIBAQC1gI7za3IjgZeUlOyMypx+vuABzGWANEW2 Z0uK
/uOHEIxwB4/Xvaf+Xo3y416fayyo+dlPE/iFapKZCGRQbf/88YaK2ZTEgsMR 9awX
eeP50rKD/9pJPf2fLDzbNnHYz5oF0oKzwc3msU2s/1xCCqSv8NoSpyqivA08 8UFd
OCuowps4QxQvc8jAdfO8saajnvsG/aXRMwJapuZ10G2ia6Ln9DYnM79Qg0iF zzGP
Q0EOE64eecqEeHmKgGTFl4VavfVkspgBhxn0c6ss1K8vS+J3sLth9XP1gMb0 qNQz
Dfsz6KwxTJ/3p5OorCbNjW+HINT2+GZXrD+GOm4tBgEG+Dw9AgMBAAGjgckw gcYw
HQYDVR0OBBYEFHKIZ9TwU70GU9QzuQ9MsUFNjqkRMIGWBgNVHSMEgY4wgYuA FHKI
Z9TwU70GU9QzuQ9MsUFNjqkRoWikZjBkMQswCQYDVQQGEwIuLjELMAkGA1UE CBMC
Li4xCzAJBgNVBAcTAi4uMQswCQYDVQQKEwIuLjELMAkGA1UECxMCLi4xDjAM BgNV
BAMTBUFTQ0EyMREwDwYJKoZIhvcNAQkBFgIuLoIJAOt26+6pZCokMAwGA1Ud EwQF
MAMBAf8wDQYJKoZIhvcNAQELBQADggEBAJKHXc4JABvR0bC4u56eTzTi+tQt zyl1
I2Sb2RwV5Z99QibIf1CwAUo6cO7TZUheDCBQ2zT9EvbBk6LH2HL8gRX5bRFM dEMU
8dAVBp01d6RWmwRA5X9LgjTzxaCiRPnfzpMBLlYT5SXwqVdHT6hniCr6QkLH IosU
WXBjRX3c7I0YlMxCIigUzkelJhMTsr9D8eRNtDsS2UvsfkCvh2gn6wZiUfZJ IMFJ
rKWYJfvn1DN9Ri0k1OaryfEAeplsvxSj3nGC8kN5df9tnhU/kuei1rR7tYUi ajMF
DWqvB+wv9DtX42uWOd4i4kmuivuw5zTMZFVborRUbO3IlODkx4sgRAE=
-----END CERTIFICATE-----
MIIEGzCCAwOgAwIBAgIDDBnEMA0GCSqGSIb3DQEBCwUAMGQxCzAJBgNVBAYT Ai4u
MQswCQYDVQQIEwIuLjELMAkGA1UEBxMCLi4xCzAJBgNVBAoTAi4uMQswCQYD VQQL
EwIuLjEOMAwGA1UEAxMFQVNDQTIxETAPBgkqhkiG9w0BCQEWAi4uMB4XDTE2 MDcz
MTA5MDUwMVoXDTI2MDczMDA4MDUwMVowLDEqMCgGA1UEAxMhQVMxNjk2MTU5 LTIx
NTY0NTIyNzRFQi1GOTM3MjIxNzQyMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8A MIIB
CgKCAQEAvxAT8CUdsNA1w1jLpZog864KrOAY5aUl5O0OtmoXLANrIAVWOHLN 6++H
lVtRmf5R2EaER7Yjy7dkEeW89ukvNerNBA2qgTYZdyLR4jwIPYXwY/RgaxUq r6FQ
+PigRUhGB0+pr+lnJW6KUldSLTcM4du62hVrzwmnNf2l3uBAB3Aem6S1vLQv O/dj
wfUcbi/Nt51Ycsw5DLTkbtrz9u9/I3zsstj0tAuImOW9aWvEiozOOjafyxgo FOjA
PtZxZWbZNGZXCQGmI2LFVOu29YHwbvyFW3JbcCgQ2hKRLaBIfQ29TqQf5D2y lXy4
LcbyAi1AhJ8A/oalv61yuOhS4qtPswIDAQABo4IBDDCCAQgwCQYDVR0TBAIw ADAh
BglghkgBhvhCAQ0EFBYSQ2xpZW50IENlcnRpZmljYXRlMB0GA1UdDgQWBBT6 2ycN
ujXzp7ujD0ROOW2lMlkvRzCBlgYDVR0jBIGOMIGLgBRyiGfU8FO9BlPUM7kP TLFB
TY6pEaFopGYwZDELMAkGA1UEBhMCLi4xCzAJBgNVBAgTAi4uMQswCQYDVQQH EwIu
LjELMAkGA1UEChMCLi4xCzAJBgNVBAsTAi4uMQ4wDAYDVQQDEwVBU0NBMjER MA8G
CSqGSIb3DQEJARYCLi6CCQDrduvuqWQqJDATBgNVHSUEDDAKBggrBgEFBQcD AjAL
BgNVHQ8EBAMCB4AwDQYJKoZIhvcNAQELBQADggEBAC0VzRJHtE+uFoIvQBxe EOUD
QE0ZQENGoKQOZftZw8BtBC9VSLoYd5ykaCAI0WCjuHUaNoQkB2pG8nWcFPJ2 wR7J
/wGHwyi7P/5eAta2pGwJevAcw3Kp7RKcj0bpe4hvtAhAFvERXiOr2d6XgXuh fHHr
dPA/dPhZChNU8At862409w/cqV9rrpBDjT7y0cjtbd9PjnBYDCb19vraAZZv NSP3
l8p24Mo+plGhrzbovmyJuqpMGkWQzd4wQ1A+PPKQpSAkn9hHFMrs+Zd8WsRY K4cI
1uJ2N8fsJ/uymvytwyMx1eEY36P9h/Fi2ZNwUFe6XOkwI3FDGOwyxNa3Um69 GKA=
client
dev tun
proto udp
nobind
persist-key
persist-tun
ns-cert-type server
key-direction 1
push-peer-info
comp-lzo
verb 3
mute 20
reneg-sec 86400
max-routes 1000
