Привет! У меня есть небольшой тестовый стенд, состоящий из AC Lite в роли CAPSMAN-сервера и HAP AX2 как CAP-клиента. На обоих установлена ROS 7.15.3. На AX2 нет соединения, хотя через torch вижу UDP-трафик от AX к CAPSMAN. Думаю, дело в CAPSMAN-сервере.
Это конфигурация CAPSMAN:
2024-08-23 21:44:51, RouterOS 7.15.3
software id = L4DJ-R5PC
model = RB952Ui-5ac2nD
/caps-man channel add band=2ghz-b/g/n name=channel-2ghz
/interface bridge add admin-mac=48:8F:5A:28:A5:8B auto-mac=no comment=defconf name=bridge port-cost-mode=short
/interface wireless set [find default-name=wlan1] band=2ghz-b/g/n channel-width=20/40mhz-XX distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-28A590 wireless-protocol=802.11
set [find default-name=wlan2] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-28A58F wireless-protocol=802.11
/caps-man datapath add bridge=bridge name=datapath-local
/caps-man security add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm name=security1
/caps-man configuration add channel=channel-2ghz country=spain datapath=datapath-local name=cfg-local-2ghz security=security1 ssid=WIFI-TEST
/interface list add comment=defconf name=WAN
/interface list add comment=defconf name=LAN
/interface lte apn set [find default=yes] ip-type=ipv4 use-network-apn=no
/interface wireless security-profiles set [find default=yes] supplicant-identity=MikroTik
/caps-man manager set ca-certificate=auto enabled=yes
/caps-man provisioning add action=create-enabled master-configuration=cfg-local-2ghz
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2 internal-path-cost=10 path-cost=10
add bridge=bridge ingress-filtering=no interface=ether1 internal-path-cost=10 path-cost=10
/ip firewall connection tracking set udp-timeout=10s
/ip neighbor discovery-settings set discover-interface-list=LAN
/ip settings set max-neighbor-entries=8192
/ipv6 settings set disable-ipv6=yes max-neighbor-entries=8192
/interface ovpn-server server set auth=sha1,md5
/ip dhcp-client add comment=defconf interface=bridge
/ip dns set allow-remote-requests=yes
/ip dns static add address=192.168.88.1 comment=defconf name=router.lan
/routing bfd configuration add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock set time-zone-name=Europe/Madrid
/system identity set name=“CapsMan TEst”
/system note set show-at-login=no
/tool mac-server set allowed-interface-list=LAN
/tool mac-server mac-winbox set allowed-interface-list=LAN
А это конфигурация AX2:
2024-08-23 21:46:55, RouterOS 7.15.3
software id = J6GT-ETZP
model = C52iG-5HaxD2HaxD
/interface bridge add admin-mac=48:A9:8A:DA:B2:D9 auto-mac=no comment=defconf name=bridgeLocal
/interface wifi datapath add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface wifi no connection to CAPsMAN add channel.band=5ghz-ax configuration.manager=capsman .mode=ap datapath=capdp disabled=no radio-mac=48:A9:8A:DA:B2:DE security.connect-priority=0
no connection to CAPsMAN add channel.reselect-interval=1m configuration.manager=capsman .mode=ap datapath=capdp disabled=no radio-mac=48:A9:8A:DA:B2:DF security.connect-priority=0
/interface bridge port add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal comment=defconf interface=ether5
/interface wifi cap set caps-man-addresses=CAMPSMAN_IP discovery-interfaces=all enabled=yes slaves-datapath=capdp
/ip dhcp-client add comment=defconf interface=bridgeLocal
Буду очень признателен за любую помощь!
