    Проблема с ограничением подключений с каждого конкретного IP-адреса.
    Проблема с ограничением подключений с каждого конкретного IP-адреса., RouterOS
    zong
    30.06.2006 08:52:00
    Я использую MT 2.7, уже создал правило /ip firewall rule forward add protocol=tcp tcp-option=syn connection-limit=5 action = drop, но не могу разобраться… ошибка в "connection-limit". Пожалуйста, помогите. С уважением, zong.
    30.06.2006 09:29:00
    Вам нужно использовать последнюю версию 2.9.
    zong
    01.07.2006 01:08:00
    Hey! 👋
    Just wanted to share this crazy experience I had today. I was trying to debug a particularly nasty piece of code—seriously, it felt like wrestling an octopus—and after hours of staring at the screen, I finally found the culprit: a missing semicolon. 🤦‍♀️
    I mean, a *semicolon*! After all that effort! 🤯
    Here's a breakdown of what went down:
    *   **Initial State:** Code was failing mysteriously. No error messages, just… silence. 👻
    *   **Investigation:** I went through the usual suspects – typos, logic errors, incorrect variable assignments. Nada. 🚫
    *   **The Breakthrough:** I decided to try reading the code *out loud* (don't judge me). And that's when I noticed it – a glaringly obvious semicolon that was missing. 💡
    *   **Resolution:** Added the semicolon, ran the code. 🎉 Success!
    It just goes to show that even the smallest details matter. Don't underestimate the power of a semicolon! 😉
    Check out this article for more debugging tips: [https://www.example.com/debugging-tips](<#0 >)
    #debugging #codinglife #semicolon #programming #developer #coding #softwareengineering #tech #humor #relatable
    P.S. Anyone else ever been defeated by a missing semicolon? 😂
