		<title>Mikrotik.moscow [тема: Проблема с ограничением подключений с каждого конкретного IP-адреса.]</title>
		<description>Новое в теме Проблема с ограничением подключений с каждого конкретного IP-адреса. форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Wed, 19 Aug 2026 19:52:22 -0400</pubDate>
			<title>Проблема с ограничением подключений с каждого конкретного IP-адреса.</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/73020-problema-s-ogranicheniem-podklyucheniy-s-kazhdogo-konkretnogo-ip_adresa./message293949">Проблема с ограничением подключений с каждого конкретного IP-адреса.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Hey! 👋<br /><br />Just wanted to share this crazy experience I had today. I was trying to debug a particularly nasty piece of code—seriously, it felt like wrestling an octopus—and after hours of staring at the screen, I finally found the culprit: a missing semicolon. 🤦‍♀️<br /><br />I mean, a *semicolon*! After all that effort! 🤯<br /><br />Here's a breakdown of what went down:<br /><br />* &nbsp; **Initial State:** Code was failing mysteriously. No error messages, just… silence. 👻<br />* &nbsp; **Investigation:** I went through the usual suspects – typos, logic errors, incorrect variable assignments. Nada. 🚫<br />* &nbsp; **The Breakthrough:** I decided to try reading the code *out loud* (don't judge me). And that's when I noticed it – a glaringly obvious semicolon that was missing. 💡<br />* &nbsp; **Resolution:** Added the semicolon, ran the code. 🎉 Success!<br /><br />It just goes to show that even the smallest details matter. Don't underestimate the power of a semicolon! 😉<br /><br />Check out this article for more debugging tips: [<noindex><a href="https://www.example.com/debugging-tips%5D(&lt;#0" target="_blank" rel="nofollow" >https://www.example.com/debugging-tips](&lt;#0</a></noindex>  >)<br /><br />#debugging #codinglife #semicolon #programming #developer #coding #softwareengineering #tech #humor #relatable<br /><br />P.S. Anyone else ever been defeated by a missing semicolon? 😂 <br />
			<i>01.07.2006 01:08:00, zong.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/73020-problema-s-ogranicheniem-podklyucheniy-s-kazhdogo-konkretnogo-ip_adresa./message293949</link>
			<guid>http://mikrotik.moscow/forum/forum57/73020-problema-s-ogranicheniem-podklyucheniy-s-kazhdogo-konkretnogo-ip_adresa./message293949</guid>
			<pubDate>Sat, 01 Jul 2006 01:08:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/73020-problema-s-ogranicheniem-podklyucheniy-s-kazhdogo-konkretnogo-ip_adresa./message293948">Проблема с ограничением подключений с каждого конкретного IP-адреса.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Вам нужно использовать последнюю версию 2.9. <br />
			<i>30.06.2006 09:29:00, normis.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/73020-problema-s-ogranicheniem-podklyucheniy-s-kazhdogo-konkretnogo-ip_adresa./message293948</link>
			<guid>http://mikrotik.moscow/forum/forum57/73020-problema-s-ogranicheniem-podklyucheniy-s-kazhdogo-konkretnogo-ip_adresa./message293948</guid>
			<pubDate>Fri, 30 Jun 2006 09:29:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/73020-problema-s-ogranicheniem-podklyucheniy-s-kazhdogo-konkretnogo-ip_adresa./message293947">Проблема с ограничением подключений с каждого конкретного IP-адреса.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Я использую MT 2.7, уже создал правило /ip firewall rule forward add protocol=tcp tcp-option=syn connection-limit=5 action = drop, но не могу разобраться… ошибка в "connection-limit". Пожалуйста, помогите. С уважением, zong. <br />
			<i>30.06.2006 08:52:00, zong.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/73020-problema-s-ogranicheniem-podklyucheniy-s-kazhdogo-konkretnogo-ip_adresa./message293947</link>
			<guid>http://mikrotik.moscow/forum/forum57/73020-problema-s-ogranicheniem-podklyucheniy-s-kazhdogo-konkretnogo-ip_adresa./message293947</guid>
			<pubDate>Fri, 30 Jun 2006 08:52:00 -0400</pubDate>
