Достаточно ли этой информации?
MIKROTIK Interfaces
0 interface=ether2 cost=10 priority=1 authentication-key="" network-type=broadcast retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s
Networks
0 68.153.44.232/30 backbone
1 68.153.44.240/28 backbone
2 68.153.44.227/32 backbone
Areas Flags: X - disabled
NAME AREA-ID TYPE DEFAULT-COST AUTHENTICATION
0 backbone 0.0.0.0 default none
CISCO show ip ospf
Routing Process “ospf 1” with ID 68.153.44.224
Supports only single TOS(TOS0) routes
Supports opaque LSA
Supports Link-local Signaling (LLS)
Supports area transit capability
Initial SPF schedule delay 5000 msecs
Minimum hold time between two consecutive SPFs 10000 msecs
Maximum wait time between two consecutive SPFs 10000 msecs
Incremental-SPF disabled
Minimum LSA interval 5 secs
Minimum LSA arrival 1000 msecs
LSA group pacing timer 240 secs
Interface flood pacing timer 33 msecs
Retransmission pacing timer 66 msecs
Number of external LSA 0. Checksum Sum 0x000000
Number of opaque AS LSA 0. Checksum Sum 0x000000
Number of DCbitless external and opaque AS LSA 0
Number of DoNotAge external and opaque AS LSA 0
Number of areas in this router is 1.
1 normal
0 stub
0 nssa
Number of areas transit capable is 0
External flood list length 0
Area BACKBONE(0) (Inactive)
Number of interfaces in this area is 2 (1 loopback)
Area has no authentication
SPF algorithm last executed 3w1d ago
SPF algorithm executed 4 times
Area ranges are
Number of LSA 1. Checksum Sum 0x002DA5
Number of opaque link LSA 0. Checksum Sum 0x000000
Number of DCbitless LSA 0
Number of indication LSA 0
Number of DoNotAge LSA 0
Flood list length 0
show ip ospf interfaces
GigabitEthernet0/0 is up, line protocol is up
Internet Address 68.153.44.234/29, Area 0
Process ID 1, Router ID 68.153.44.224, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State DR, Priority 1
Designated Router (ID) 68.153.44.224, Interface address 68.153.44.234
No backup designated router on this network
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
oob-resync timeout 40
Hello due in 00:00:04
Index 2/2, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 0, maximum is 0
Last flood scan time is 0 msec, maximum is 0 msec
Neighbor Count is 0, Adjacent neighbor count is 0
Suppress hello for 0 neighbor(s)
Loopback0 is up, line protocol is up
Internet Address 68.153.44.224/32, Area 0
Process ID 1, Router ID 68.153.44.224, Network Type LOOPBACK, Cost: 1
Loopback interface is treated as a stub Host
Show Run
router ospf 1
log-adjacency-changes
passive-interface Serial0/0/0
network 68.153.44.224 0.0.0.0 area 0
network 68.153.44.232 0.0.0.3 area 0
