    Неверная глобальная команда "/export" или "/export compact".
    Неверная глобальная команда "/export" или "/export compact"., RouterOS
    Shkrid
    11.12.2013 11:19:00
    Пытаюсь объяснить проблему через код:
    [admin@MikroTik] > /system reset-configuration after reboot with default config
    [admin@MikroTik] > /export jan/02/1970 00:01:21 by RouterOS 6.7 software id = 0MIF-GMWW
    /ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
    /port set 0 name=serial0 set 1 name=serial1
    /ip address add address=192.168.88.1/24 comment=“default configuration” interface=ether1 network=192.168.88.0
    /ip dns set allow-remote-requests=yes
    /ip dns static add address=192.168.88.1 name=router
    /lcd interface set sfp-sfpplus1 interface=sfp-sfpplus1 set sfp-sfpplus2 interface=sfp-sfpplus2 … … …
    [admin@MikroTik] > /user group add name=test
    [admin@MikroTik] > /ip address add address=1.1.1.1/29 interface=ether1
    [admin@MikroTik] > /export jan/02/1970 00:04:03 by RouterOS 6.7 software id = 0MIF-GMWW
    add address=1.1.1.1/29 interface=ether1 network=1.1.1.0
    [admin@MikroTik] > /export file=testcon
    [admin@MikroTik] > /system reset-configuration keep-users=yes no-defaults=yes run-after-reset=testconf.rsc
    после перезагрузки
    [admin@MikroTik] > /export jan/02/1970 00:01:31 by RouterOS 6.7 software id = 0MIF-GMWW
    [admin@MikroTik] > log print
    00:00:14 system,info router rebooted
    00:00:16 system,info hotspot user profile default changed
    00:00:16 system,info port  changed
    00:00:19 interface,info ether8 link up (speed 1000M, full duplex)
    00:00:20 system,info,account user admin logged in via winbox
    00:01:16 system,info,account user admin logged in via local
    Script execution failed, because group “test” already exists
    I think global export(“/export” or “/export compact”) shouldn’t exports all “/user” section, excluding “/export verbose”
    Shkrid
    11.12.2013 11:32:00
    Делаю это, чтобы создать резервную копию и синхронизировать конфигурации роутеров. Два CCR1036 и VRRP на них. На втором периодически буду скачивать новую конфигурацию с помощью команд export/import.
    Shkrid
    11.12.2013 13:53:00
    [admin@MikroTik] > /export jan/02/1970 00:01:21 by RouterOS 6.7 software id = 0MIF-GMWW /ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d /port set 0 name=serial0 set 1 name=serial1 /ip address add address=192.168.88.1/24 comment=“default configuration” interface=ether1 network=192.168.88.0 /ip dns set allow-remote-requests=yes /ip dns static add address=192.168.88.1 name=router /lcd interface set sfp-sfpplus1 interface=sfp-sfpplus1 set sfp-sfpplus2 interface=sfp-sfpplus2 set ether1 interface=ether1 set ether2 interface=ether2 set ether3 interface=ether3 set ether4 interface=ether4 set ether5 interface=ether5 set ether6 interface=ether6 set ether7 interface=ether7 set ether8 interface=ether8 /system leds set 0 type=interface-speed set 2 type=interface-speed /system routerboard settings set boot-device=nand-only cpu-frequency=1200MHz memory-frequency=1066DDRТе же проблемы с: /system leds
    set 2 type=interface-speed [admin@MikroTik] /system leds [admin@MikroTik] /system leds> set 0 type=interface-speed failure: This preset is read-only! [admin@MikroTik] /system leds> set 2 type=interface-speed failure: This preset is read-only!
