		<title>Mikrotik.moscow [тема: Неверная глобальная команда &quot;/export&quot; или &quot;/export compact&quot;.]</title>
		<description>Новое в теме Неверная глобальная команда &quot;/export&quot; или &quot;/export compact&quot;. форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Mon, 17 Aug 2026 08:26:31 -0400</pubDate>
			<title>Неверная глобальная команда &quot;/export&quot; или &quot;/export compact&quot;.</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/59951-nevernaya-globalnaya-komanda-_export_-ili-_export-compact_./message228170">Неверная глобальная команда &quot;/export&quot; или &quot;/export compact&quot;.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			[admin@MikroTik] &gt; /export jan/02/1970 00:01:21 by RouterOS 6.7 software id = 0MIF-GMWW /ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d /port set 0 name=serial0 set 1 name=serial1 /ip address add address=192.168.88.1/24 comment=“default configuration” interface=ether1 network=192.168.88.0 /ip dns set allow-remote-requests=yes /ip dns static add address=192.168.88.1 name=router /lcd interface set sfp-sfpplus1 interface=sfp-sfpplus1 set sfp-sfpplus2 interface=sfp-sfpplus2 set ether1 interface=ether1 set ether2 interface=ether2 set ether3 interface=ether3 set ether4 interface=ether4 set ether5 interface=ether5 set ether6 interface=ether6 set ether7 interface=ether7 set ether8 interface=ether8 /system leds set 0 type=interface-speed set 2 type=interface-speed /system routerboard settings set boot-device=nand-only cpu-frequency=1200MHz memory-frequency=1066DDRТе же проблемы с: /system leds<br />set 0 type=interface-speed<br />set 2 type=interface-speed [admin@MikroTik] /system leds [admin@MikroTik] /system leds&gt; set 0 type=interface-speed failure: This preset is read-only! [admin@MikroTik] /system leds&gt; set 2 type=interface-speed failure: This preset is read-only! <br />
			<i>11.12.2013 13:53:00, Shkrid.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/59951-nevernaya-globalnaya-komanda-_export_-ili-_export-compact_./message228170</link>
			<guid>http://mikrotik.moscow/forum/forum57/59951-nevernaya-globalnaya-komanda-_export_-ili-_export-compact_./message228170</guid>
			<pubDate>Wed, 11 Dec 2013 13:53:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/59951-nevernaya-globalnaya-komanda-_export_-ili-_export-compact_./message228169">Неверная глобальная команда &quot;/export&quot; или &quot;/export compact&quot;.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Делаю это, чтобы создать резервную копию и синхронизировать конфигурации роутеров. Два CCR1036 и VRRP на них. На втором периодически буду скачивать новую конфигурацию с помощью команд export/import. <br />
			<i>11.12.2013 11:32:00, Shkrid.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/59951-nevernaya-globalnaya-komanda-_export_-ili-_export-compact_./message228169</link>
			<guid>http://mikrotik.moscow/forum/forum57/59951-nevernaya-globalnaya-komanda-_export_-ili-_export-compact_./message228169</guid>
			<pubDate>Wed, 11 Dec 2013 11:32:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/59951-nevernaya-globalnaya-komanda-_export_-ili-_export-compact_./message228168">Неверная глобальная команда &quot;/export&quot; или &quot;/export compact&quot;.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Пытаюсь объяснить проблему через код:<br />[admin@MikroTik] &gt; /system reset-configuration after reboot with default config<br />[admin@MikroTik] &gt; /export jan/02/1970 00:01:21 by RouterOS 6.7 software id = 0MIF-GMWW<br />/ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d<br />/port set 0 name=serial0 set 1 name=serial1<br />/ip address add address=192.168.88.1/24 comment=“default configuration” interface=ether1 network=192.168.88.0<br />/ip dns set allow-remote-requests=yes<br />/ip dns static add address=192.168.88.1 name=router<br />/lcd interface set sfp-sfpplus1 interface=sfp-sfpplus1 set sfp-sfpplus2 interface=sfp-sfpplus2 … … …<br />[admin@MikroTik] &gt; /user group add name=test<br />[admin@MikroTik] &gt; /ip address add address=1.1.1.1/29 interface=ether1<br />[admin@MikroTik] &gt; /export jan/02/1970 00:04:03 by RouterOS 6.7 software id = 0MIF-GMWW<br />/ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d<br />/port set 0 name=serial0 set 1 name=serial1<br />/user group add name=test<br />/ip address add address=192.168.88.1/24 comment=“default configuration” interface=ether1 network=192.168.88.0<br />add address=1.1.1.1/29 interface=ether1 network=1.1.1.0<br />/ip dns set allow-remote-requests=yes<br />/ip dns static add address=192.168.88.1 name=router<br />/lcd interface set sfp-sfpplus1 interface=sfp-sfpplus1 set sfp-sfpplus2 interface=sfp-sfpplus2 … … …<br />[admin@MikroTik] &gt; /export file=testcon<br />[admin@MikroTik] &gt; /system reset-configuration keep-users=yes no-defaults=yes run-after-reset=testconf.rsc<br /><br />после перезагрузки<br /><br />[admin@MikroTik] &gt; /export jan/02/1970 00:01:31 by RouterOS 6.7 software id = 0MIF-GMWW<br />/ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d<br />/port set 0 name=serial0 set 1 name=serial1<br />/user group add name=test<br />/lcd interface set sfp-sfpplus1 interface=sfp-sfpplus1 set sfp-sfpplus2 interface=sfp-sfpplus2 … … …<br />[admin@MikroTik] &gt; log print<br />00:00:14 system,info router rebooted<br />00:00:16 system,info hotspot user profile default changed<br />00:00:16 system,info port &nbsp;changed<br />00:00:16 system,info port &nbsp;changed<br />00:00:19 interface,info ether8 link up (speed 1000M, full duplex)<br />00:00:20 system,info,account user admin logged in via winbox<br />00:01:16 system,info,account user admin logged in via local<br />Script execution failed, because group “test” already exists<br />I think global export(“/export” or “/export compact”) shouldn’t exports all “/user” section, excluding “/export verbose” <br />
			<i>11.12.2013 11:19:00, Shkrid.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/59951-nevernaya-globalnaya-komanda-_export_-ili-_export-compact_./message228168</link>
			<guid>http://mikrotik.moscow/forum/forum57/59951-nevernaya-globalnaya-komanda-_export_-ili-_export-compact_./message228168</guid>
			<pubDate>Wed, 11 Dec 2013 11:19:00 -0500</pubDate>
