Вот перевод текста сообщения на русский язык:
Смотри это:
[admin@lomas] interface wireless> pr
Flags: X - disabled, R - running
0 R name=“arrepentidos” mtu=1500 mac-address=00:02:6F:20:F4:42 arp=enabled disable-running-check=no interface-type=Atheros AR5212 mode=ap-bridge ssid=“acon-lomas” frequency=2532 band=2.4GHz-B scan-list=default-ism supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power=23 noise-floor-threshold=default burst-time=disabled fast-frames=no dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes hide-ssid=no 802.1x-mode=none
1 R name=“pinafrut” mtu=1500 mac-address=00:02:6F:03:17:28 arp=enabled disable-running-check=no interface-type=Prism mode=ap-bridge ssid=“lomas-pinafrut” frequency=2432 band=2.4GHz-B scan-list=default-ism,2512 supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=“” basic-rates-b=1Mbps basic-rates-a/g=“” max-station-count=2007 fast-frames=no dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes hide-ssid=no 802.1x-mode=none
2 R name=“carrandi-c” mtu=1500 mac-address=00:0B:6B:31:B3:0F arp=enabled disable-running-check=no interface-type=Atheros AR5212 mode=bridge ssid=“lomas-limo” frequency=2572 band=2.4GHz-B scan-list=default-ism supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power=default noise-floor-threshold=default burst-time=disabled fast-frames=no dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes hide-ssid=no 802.1x-mode=none
3 R name=“pontinia” mtu=1500 mac-address=00:0B:6B:30:2E:07 arp=enabled disable-running-check=no interface-type=Atheros AR5212 mode=bridge ssid=“lomas-pontinia” frequency=2467 band=2.4GHz-B scan-list=default-ism supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power=23 noise-floor-threshold=default burst-time=disabled fast-frames=no dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes hide-ssid=no 802.1x-mode=none
4 R name=“ap-lomas” mtu=1500 mac-address=00:02:6F:01:78:C5 arp=enabled disable-running-check=no interface-type=Prism mode=ap-bridge ssid=“ap-lomas” frequency=2412 band=2.4GHz-B scan-list=default-ism supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=“” basic-rates-b=1Mbps basic-rates-a/g=“” max-station-count=2007 fast-frames=no dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes hide-ssid=no 802.1x-mode=none
[admin@lomas] interface wireless> /sys reso pr uptime: 18d21h12m59s free-memory: 39072 kB total-memory: 62696 kB model: RouterBOARD 230 cpu: Geode cpu-frequency: 266 MHz cpu-load: 9 free-hdd-space: 27557 kB total-hdd-space: 60604 kB write-sect-since-reboot: 660 write-sect-total: 328898 [admin@lomas] interface wireless> reg pr INTERFACE MAC-ADDRESS AP SIGNAL-S… TX-RATE UPTIME 0 ap-lomas 00:02:6F:03:17:29 no -82 11Mbps 8d01:31:07 1 pontinia 00:02:6F:03:80:6D no -80 11Mbps 4d00:37:19 2 carrandi-c 00:0B:6B:31:B3:CA no -82 5.5Mbps 16:42:34 3 ap-lomas 00:02:6F:01:D2:0A no -73 11Mbps 16:35:57 4 pinafrut 00:02:6F:03:80:69 no -82 11Mbps 08:03:14 5 ap-lomas 00:40:96:36:44:F4 no -83 11Mbps 04:20:58 6 arrepentidos 00:02:6F:20:F4:43 no -77 11Mbps 03:42:14 7 pinafrut 00:02:6F:03:80:69 no -65 11Mbps 00:38:21 8 arrepentidos 00:02:6F:20:F4:34 no -85 11Mbps 00:22:28 9 ap-lomas 00:40:96:41:BB:1D no -71 11Mbps 00:02:51 RESOURSE
