Хорошо, не мог бы ты помочь мне с настройкой моего роутера hap ac lite? Вот текущая конфигурация:
[admin@Router] > export hide-sensitive
mar/17/2016 13:32:11 by RouterOS 6.34.3
software id = xxxxxxxxx
/interface bridge
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
/interface ethernet
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] disabled=yes master-port=ether2-master
set [ find default-name=ether4 ] disabled=yes master-port=ether2-master
set [ find default-name=ether5 ] disabled=yes master-port=ether2-master
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country=indonesia disabled=no distance=indoors frequency=auto hw-retries=4 mode=ap-bridge ssid=“@net (b/g/n)” wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=indonesia disabled=no distance=indoors frequency=auto hw-retries=4 mode=ap-bridge ssid=“@net (a/n/ac)” wireless-protocol=802.11 wps-mode=disabled
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=“” mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
set [ find default=yes ] html-directory=flash/hotspot
/ip pool
add name=dhcp ranges=192.168.102.2-192.168.102.100
add name=vpn ranges=192.168.89.2-192.168.89.255
/ip dhcp-server
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/interface bridge port
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan1
add bridge=bridge comment=defconf interface=wlan2
/interface l2tp-server server
set authentication=mschap2 enabled=yes max-mru=1460 max-mtu=1460 use-ipsec=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
/ip address
add address=192.168.102.1/24 comment=defconf interface=ether2-master network=192.168.102.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server network
add address=192.168.102.0/24 comment=defconf gateway=192.168.102.1 netmask=24
/ip dns
set allow-remote-requests=yes
/ip dns static
add address=192.168.102.1 name=router
/ip firewall filter
add chain=input comment=“defconf: accept ICMP” protocol=icmp
add chain=input comment=“defconf: accept established,related” connection-state=established,related
add chain=input comment=“allow l2tp” dst-port=1701 protocol=udp
add chain=input comment=“allow pptp” dst-port=1723 protocol=tcp
add chain=input comment=“allow sstp” dst-port=443 protocol=tcp
add action=drop chain=input comment=“defconf: drop all from WAN” in-interface=ether1
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add chain=forward comment=“defconf: accept established,related” connection-state=established,related
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface=ether1
/ip firewall nat
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface=ether1
add action=masquerade chain=srcnat comment=“masq. vpn traffic” src-address=192.168.89.0/24
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ppp secret
add name=vpn
/system clock
set time-zone-name=Asia/Jakarta
/system identity
set name=Router
/system leds
set 0 leds=led1,user-led
set 2 disabled=yes
set 3 disabled=yes
set 4 disabled=yes
add interface=wlan1 leds=led4 type=wireless-status
add interface=wlan2 leds=led5 type=wireless-status
add leds=led3 type=on
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
/tool mac-server
set [ find default=yes ] disabled=yes add interface=bridge
/tool mac-server mac-winbox
Что-то в конфигурации неполное? Пожалуйста, помоги, буду очень благодарен!
