Всем привет! Я использую метод PCC с 4 WAN-подключениями. Каждый WAN имеет скорость загрузки 10 Мбит/с и скорость выгрузки 1 Мбит/с. После настройки PCC скорость загрузки стала 40 Мбит/с, но скорость выгрузки осталась 1 Мбит/с. Мне нужно получить суммарную скорость выгрузки всех 4 WAN.
/interface ethernet
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether3 ] name=WAN3
set [ find default-name=ether4 ] name=WAN4
set [ find default-name=ether10 ] name=LAN
/ip address
add address=192.168.0.2/24 interface=WAN1 network=192.168.0.0
add address=192.168.2.2/24 interface=WAN2 network=192.168.2.0
add address=192.168.3.2/24 interface=WAN3 network=192.168.3.0
add address=192.168.4.2/24 interface=WAN4 network=192.168.4.0
add address=10.0.0.1/16 interface=LAN network=10.0.0.0
/ip firewall mangle
add action=accept chain=prerouting disabled=yes dst-address=192.168.0.0-192.168.4.255 in-interface=LAN
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=ISP1_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=ISP2_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/1
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=ISP3_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/2
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=LAN new-connection-mark=ISP4_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:4/3
add action=mark-routing chain=prerouting connection-mark=ISP1_conn in-interface=LAN new-routing-mark=to_ISP1
add action=mark-routing chain=prerouting connection-mark=ISP2_conn in-interface=LAN new-routing-mark=to_ISP2
add action=mark-routing chain=prerouting connection-mark=ISP3_conn in-interface=LAN new-routing-mark=to_ISP3
add action=mark-routing chain=prerouting connection-mark=ISP4_conn in-interface=LAN new-routing-mark=to_ISP4
add action=mark-connection chain=prerouting connection-state=new in-interface=WAN1 new-connection-mark=ISP1_conn passthrough=no
add action=mark-connection chain=prerouting connection-state=new in-interface=WAN2 new-connection-mark=ISP2_conn passthrough=no
add action=mark-connection chain=prerouting connection-state=new in-interface=WAN3 new-connection-mark=ISP3_conn passthrough=no
add action=mark-connection chain=prerouting connection-state=new in-interface=WAN4 new-connection-mark=ISP4_conn passthrough=no
add action=mark-routing chain=output connection-mark=ISP1_conn new-routing-mark=to_ISP1 passthrough=no
add action=mark-routing chain=output connection-mark=ISP2_conn new-routing-mark=to_ISP2 passthrough=no
add action=mark-routing chain=output connection-mark=ISP3_conn new-routing-mark=to_ISP3 passthrough=no
add action=mark-routing chain=output connection-mark=ISP4_conn new-routing-mark=to_ISP4 passthrough=no
/ip firewall nat
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add action=masquerade chain=srcnat out-interface=WAN3
add action=masquerade chain=srcnat out-interface=WAN4
/ip route
add check-gateway=ping distance=1 gateway=192.168.0.1 routing-mark=to_ISP1
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=to_ISP2
add check-gateway=ping distance=1 gateway=192.168.3.1 routing-mark=to_ISP3
add check-gateway=ping distance=1 gateway=192.168.4.1 routing-mark=to_ISP4
add check-gateway=ping distance=2 gateway=192.168.2.1
add check-gateway=ping distance=3 gateway=192.168.3.1
add check-gateway=ping distance=4 gateway=192.168.4.1
/interface ethernet
/ip address
/ip firewall mangle
/ip firewall nat
/ip route
