Привет, у меня возникла проблема: не получается настроить PPPoE на RB1100 AH. Если PPPoE обрабатывается модемом, всё работает нормально. Использую версию 5.19 с прошивкой 2.39. Если настроить модем в режиме моста, он постоянно переключается между аутентификацией и отключением.
Журнал отладки выглядит следующим образом:
00:12:43 pppoe,ppp,debug,packet pppoe-out1: rcvd LCP TermAck id=0x24
00:12:43 pppoe,ppp,debug pppoe-out1: LCP lowerdown
00:12:43 pppoe,ppp,info pppoe-out1: terminating… - failed to authenticate
00:12:43 pppoe,debug,packet ether2: sent PADT to 00:00:00:00:00:00
00:12:43 pppoe,debug,packet session-id=0x2f659623
00:12:54 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:12:54 pppoe,ppp,debug,packet 00:12:54 pppoe,ppp,debug,packet <name removed@removed>
00:12:57 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:12:57 pppoe,ppp,debug,packet 00:12:57 pppoe,ppp,debug,packet <name removed@removed>
00:13:00 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:13:00 pppoe,ppp,debug,packet 00:13:00 pppoe,ppp,debug,packet <name removed@removed>
00:13:03 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:13:03 pppoe,ppp,debug,packet 00:13:03 pppoe,ppp,debug,packet <name removed@removed>
00:13:06 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:13:06 pppoe,ppp,debug,packet 00:13:06 pppoe,ppp,debug,packet <name removed@removed>
00:13:09 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:13:09 pppoe,ppp,debug,packet 00:13:09 pppoe,ppp,debug,packet <name removed@removed>
00:13:12 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:13:12 pppoe,ppp,debug,packet 00:13:12 pppoe,ppp,debug,packet <name removed@removed>
00:13:15 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:13:15 pppoe,ppp,debug,packet 00:13:15 pppoe,ppp,debug,packet <name removed@removed>
00:13:18 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:13:18 pppoe,ppp,debug,packet 00:13:18 pppoe,ppp,debug,packet <name removed@removed>
00:13:21 pppoe,ppp,debug,packet pppoe-out1: sent CHAP Response id=0x1
00:13:21 pppoe,ppp,debug,packet 00:13:21 pppoe,ppp,debug,packet <name removed@removed>
Если PPPoE обрабатывается модемом, всё работает нормально. Использую версию 5.19 с прошивкой 2.39. Есть какие-нибудь идеи, что может быть не так? Спасибо, Стефано.
