    RB5009 SFP+ 10G оптический и медный DAC с Intel X520-DA1
    RB5009 SFP+ 10G оптический и медный DAC с Intel X520-DA1, Аппаратное обеспечение
    arfoll
    09.11.2021 22:27:00
    8 RS name="sfp-sfpplus1" default-name="sfp-sfpplus1" mtu=1500 l2mtu=1514 mac-address=2C:C8:1B:FF:XX:XX
    orig-mac-address=2C:C8:1B:FF:8F:65 arp=enabled arp-timeout=auto loop-protect=default
    loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m auto-negotiation=no
    advertise="" full-duplex=yes tx-flow-control=off rx-flow-control=off speed=10Gbps
    bandwidth=unlimited/unlimited switch=switch1 sfp-rate-select=high sfp-shutdown-temperature=95C
    > interface/ethernet/monitor sfp-sfpplus1
    status: link-ok
    rate: 10Gbps
    full-duplex: yes
    tx-flow-control: no
    rx-flow-control: no
    sfp-module-present: yes
    sfp-rx-loss: no
    sfp-tx-fault: no
    sfp-type: SFP-or-SFP+
    sfp-connector-type: optical-pigtail
    sfp-link-length-copper-active-om4: 3m
    sfp-vendor-name: AVAGO
    sfp-vendor-part-number: AFBR-7CER03Z-BD1
    sfp-vendor-serial: XXX
    sfp-manufacturing-date: 13-08-22
    sfp-wavelength: 850nm
    eeprom-checksum: good
    А на клиентской стороне:
    $ sudo ethtool ens2
    Settings for ens2:
    Supported ports: /[ FIBRE /]
    Supported link modes: 10000baseT/Full
    Supported pause frame use: Symmetric
    Supports auto-negotiation: No
    Supported FEC modes: Not reported
    Advertised link modes: 10000baseT/Full
    Advertised pause frame use: Symmetric
    Advertised auto-negotiation: No
    Advertised FEC modes: Not reported
    Speed: Unknown!
    Duplex: Unknown! (255)
    Auto-negotiation: off
    Port: FIBRE
    PHYAD: 0
    Transceiver: internal
    Supports Wake-on: umbg
    Wake-on: g
    Current message level: 0x00000007 (7) drv probe link
    Link detected: no
    $ sudo ethtool -m ens2
    Identifier: 0x03 (SFP)
    Extended identifier: 0x04 (GBIC/SFP defined by 2-wire interface ID)
    Connector: 0x0b (Optical pigtail)
    Transceiver codes: 0x10 0x00 0x00 0x00 0x40 0x40 0x08 0x40 0x00
    Transceiver type: 10G Ethernet: 10G Base-SR
    Transceiver type: FC: short distance (S)
    Transceiver type: FC: Shortwave laser w/o OFC (SN)
    Transceiver type: FC: Multimode, 62.5um (M6)
    Transceiver type: FC: 800 MBytes/sec
    Encoding: 0x06 (64B/66B)
    BR, Nominal: 10300MBd
    Rate identifier: 0x00 (unspecified)
    Length (SMF,km): 0km
    Length (SMF): 0m
    Length (50um): 0m
    Length (62.5um): 0m
    Length (Copper): 3m
    Length (OM3): 0m
    Laser wavelength: 850nm
    Vendor name: AVAGO
    Vendor OUI: 00:17:6a
    Vendor PN: AFBR-7CER03Z-BD1
    Vendor rev:
    Option values: 0x00 0x12
    Option: RX_LOS implemented
    Option: TX_DISABLE implemented
    BR margin, max: 0%
    BR margin, min: 0%
    Vendor SN: XX
    Date code: 130822
    Когда загружаю/перезагружаю ixgbe (с помощью sudo modprobe -r ixgbe && sudo modprobe ixgbe allow_unsupported_sfp=1 debug=16), получаю:
    [ 6002.933547] ixgbe: Intel® 10 Gigabit PCI Express Network Driver
    [ 6002.933549] ixgbe: Copyright © 1999-2016 Intel Corporation.
    [ 6003.100831] ixgbe 0000:04:00.0: Multiqueue Enabled: Rx Queue count = 16, Tx Queue count = 16 XDP Queue count = 0
    [ 6003.101235] ixgbe 0000:04:00.0: 32.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x8 link)
    [ 6003.101563] ixgbe 0000:04:00.0: MAC: 2, PHY: 16, SFP+: 5, PBA No: H29295-003
    [ 6003.101565] ixgbe 0000:04:00.0: 90:e2:ba:bd:XX:XX
    [ 6003.105440] ixgbe 0000:04:00.0: Intel® 10 Gigabit Network Connection
    [ 6003.105649] libphy: ixgbe-mdio: probed
    [ 6003.106393] ixgbe 0000:04:00.0 ens2: renamed from eth0
    [ 6003.286464] ixgbe 0000:04:00.0: registered PHC device on ens2
    [ 6003.473490] ixgbe 0000:04:00.0 ens2: detected SFP+: 5
    [ 6003.745516] ixgbe 0000:04:00.0 ens2: NIC Link is Up 10 Gbps, Flow Control: RX/TX
    [ 6004.645635] ixgbe 0000:04:00.0 ens2: NIC Link is Down
    К сожалению, другого 10G железа, чтобы менять, у меня мало, так что я немного в тупике. Это на 7.1rc6, кроме отключения autoneg, не совсем понял, что делать дальше. Пробовал форсировать 1 Гбит, но вторая сторона (Linux) меня не пускает:
    $ sudo ethtool -s ens2 speed 1000 duplex full autoneg off
    netlink error: link settings update failed
    netlink error: Invalid argument
    Есть идеи, в чём может быть проблема? Всё вроде должно работать.
    rolling
    15.01.2022 06:48:00
    Привет, у меня такая же проблема с включённым автоопределением скорости. Прошивка 7.1.1. Сервер Proxmox с X520DA1. Кабель DAC 2 метра. Автоопределение → неполное. Пробовал вручную выставлять 1 Гбит — безуспешно. Всем привет.
    ethanspitz
    15.01.2022 07:53:00
    У меня такая же проблема, такая же настройка. Я пробую только с Copper DAC, но соединение не держится. Кто-нибудь добился успеха с этим?
    brg3466
    15.01.2022 22:03:00
    У меня такие же проблемы: RB5009 и CRS328 соединены 3-метровым Mikrotik sfp+ DAC. Связь между RB5009 и CRS328 периодически прерывается. Автонастройка также показывает статус «incomplete».
    Saveliy410
    19.01.2022 10:32:00
    У меня такая же конфигурация и такая же проблема: RB5009+ (7.1.1) подключён к CRS328 (6.49.2/7.1.1) через XS+DA0003. Статус автоопределения скорости «Не полный», и связь постоянно обрывается несколько раз в день.
    ethanspitz
    21.01.2022 17:44:00
    Есть ли у кого-то еще информация по этому поводу? Ожидается ли какой-нибудь программный патч? Это просто несовместимое оборудование? Может, кто-то знает хорошие альтернативы использованию 10G DAC с X520-DA1?
    brg3466
    21.01.2022 18:13:00
    Я отправил письмо в службу поддержки Mikrotik, чтобы сообщить об этой проблеме, и получил номер обращения. Но пока от Mikrotik никакого ответа.
    fragtion
    23.01.2022 01:38:00
    У меня работает с парой UBNT UF-MM-1G (между RB5009 и RB260GSP). Собственный S+DA0001 от MikroTik, похоже, несовместим.
    Saveliy410
    23.01.2022 22:28:00
    Сегодня я протестировал RB5009+ моего друга, и там та же проблема — неполный автоопределение скорости и переключение портов. Значит, либо это какая-то аппаратная неисправность (хотелось бы в это не верить), либо просто программный баг.
    Kaldek
    24.01.2022 00:47:00
    Интересное поведение. У меня есть RB5009 с версией 7.1, подключённый к CRS328 с той же версией (хотя раньше тоже работало на 6.48), связаны они через Mikrotik DA0001. Проблем с подключением никогда не было, поэтому интересно, что у вас иначе? ОБНОВЛЕНИЕ: я проверил своё устройство подробнее — проблем с нестабильностью нет, но пишет «Автосогласование не завершено» при скорости соединения 10 Гбит/с.
    fragtion
    26.01.2022 10:35:00
    Постоянно выполняйте пинг до RB5009 с стороны CRS в сети. Я думал, что SFP на моём rb5009 работает стабильно, но хотя в логах не видно переключения порта, время от времени происходит что-то, из-за чего связь прерывается или сбрасывается, и примерно 3 подряд пинга теряются (пинг Windows с параметрами по умолчанию).
    JerryYan
    13.02.2022 10:11:00
    Та же проблема с использованием intel xxv710-da2 (версия sfp28) и rb5009. Я пробовал DAC-кабель и AOC-кабель (оба оригинальные), обе стороны распознают sfp+ модуль, но с той же проблемой (подключение сбрасывается и восстанавливается снова и снова). Всё работает нормально с тем же кабелем, подключённым к rb4011 и crs305. Сейчас я использую crs305, чтобы «прозрачить» связь между Intel xxv710 и rb5009, надеюсь, что в будущем это поправят.
    arfoll
    10.03.2022 09:40:00
    Я попробовал с другой картой X520-DA2 — поведение точно такое же. Кто-нибудь уже открывал тикет в техподдержку mikrotik по этому поводу? Ссылка работала достаточно долго, чтобы я успел получить IP, но потом умерла, как только включил flow control и autonegotiation.
    Mar 10 10:40:32 xyz dhcpcd[395]: ens2f1: IAID 9f:6f:82:32
    Mar 10 10:40:32 xyz kernel: ixgbe 0000:04:00.1 ens2f1: detected SFP+: 4
    Mar 10 10:40:33 xyz dhcpcd[395]: ens2f1: soliciting an IPv6 router
    Mar 10 10:40:33 xyz kernel: ixgbe 0000:04:00.1 ens2f1: NIC Link is Up 10 Gbps, Flow Control: RX/TX
    Mar 10 10:40:33 xyz kernel: IPv6: ADDRCONF(NETDEV_CHANGE): ens2f1: link becomes ready
    Mar 10 10:40:33 xyz dhcpcd[395]: ens2f1: soliciting a DHCP lease
    Mar 10 10:40:33 xyz dhcpcd[395]: ens2f1: offered 192.168.88.15 from 192.168.88.1
    Mar 10 10:40:33 xyz dhcpcd[395]: ens2f1: probing address 192.168.88.15/24
    Mar 10 10:40:34 xyz dhcpcd[395]: ens2f1: carrier lost
    Mar 10 10:40:34 xyz kernel: ixgbe 0000:04:00.1 ens2f1: NIC Link is Down
    metalhhead22
    17.07.2022 23:10:00
    У меня такая же проблема на CRS326-24S+2Q+RM под управлением RouterOS v6.49.6. Порты постоянно срываются связи с картами X520. Использую 5-метровые DAC-кабели и уже не знаю, что ещё можно попробовать.
    arfoll
    18.07.2022 07:46:00
    Так что я должен был упомянуть, что проблема с RB5009 исправлена начиная с версии 7.3.x, но, честно говоря, понятия не имею, как дела обстоят с CRS326.
