    Серия Cisco 1800 / DMVPN / подключение MikroTik RB750 в качестве клиента
    Серия Cisco 1800 / DMVPN / подключение MikroTik RB750 в качестве клиента, RouterOS
    maroon
    10.11.2011 14:57:00
    Возможно ли установить VPN-соединение с RB750 на Cisco 1800, используя конфигурацию ниже… DU-XYZ-1841#show run
    Building configuration...
    Текущая конфигурация: 4641 байт
    version 12.4
    service timestamps debug datetime msec
    service timestamps log datetime msec
    service password-encryption
    hostname XXXXX
    boot-start-marker
    boot-end-marker
    logging count
    logging buffered 10000
    enable secret 5 $1$6tsl$Eymq5zUkHIMfdsf32rwef
    enable password 7 3dfdsvfsdcvfwe
    aaa new-model
    aaa authentication login USER local
    aaa authorization network l-auth local
    aaa session-id common
    dot11 syslog
    ip cef
    ip inspect name FWOUT tcp
    ip inspect name FWOUT udp
    ip inspect name FWOUT icmp
    ip inspect name FWOUT ftp
    no ip domain lookup
    ip domain name yfholding.com
    multilink bundle-name authenticated
    password encryption aes
    username xduser password 7 070B226C570F110DEFSDSFA1B16020203
    username du secret 5 $1$Vmp8$UEwV.6RUClcwerwugcgIQ8DaO.
    username fvpn password 7 023FSDFS224D1B085F71
    username ku password 7 063F29294342SDFSD0D100B103526
    archive
    log config
     logging enable
     hidekeys
    crypto keyring dmvpnspokes
     pre-shared-key address 0.0.0.0 0.0.0.0 key Verysecretoooo
    crypto isakmp policy 1
    encr 3des
    hash md5
    authentication pre-share
    crypto isakmp policy 10
    encr 3des
    hash md5
    group 2
    crypto isakmp client configuration group DUolding
    key DUKey!@
    pool VPN
    acl 181
    split-dns 192.100.100.100
    crypto isakmp profile DMVPN
      keyring dmvpnspokes
      match identity address 0.0.0.0
    crypto isakmp profile VPNclient
      match identity group DUHolding
      client authentication list USER
      isakmp authorization list l-auth
      client configuration address respond
    crypto ipsec transform-set DU-SET esp-3des esp-md5-hmac
    mode transport
    crypto ipsec profile DU-PROFILE
    set transform-set DU-SET
    set isakmp-profile DMVPN
    crypto dynamic-map IMAP 10
    set isakmp-profile VPNclient
    reverse-route
    crypto map mymap 100 ipsec-isakmp dynamic IMAP
    ip ssh version 2
    interface Tunnel0
    bandwidth 4000
    ip address 192.168.234.1 255.255.255.0
    no ip redirects
    ip mtu 1440
    ip hold-time eigrp 90 60
    no ip next-hop-self eigrp 90
    ip nhrp authentication cisco@DU
    ip nhrp map multicast dynamic
    ip nhrp network-id 1
    ip nhrp holdtime 60
    ip tcp adjust-mss 1360
    no ip split-horizon eigrp 90
    ip ospf network point-to-multipoint
    tunnel source FastEthernet0/1
    tunnel mode gre multipoint
    tunnel key 0
    tunnel protection ipsec profile DU-PROFILE
    interface FastEthernet0/0
    description LAN
    ip address 192.100.100.253 255.255.255.0
    duplex auto
    speed auto
    interface FastEthernet0/1
    description WAN
    ip address 82.195.135.2 255.255.255.248
    ip access-group internet in
    no ip redirects
    no ip unreachables
    ip inspect FWOUT out
    duplex auto
    speed auto
    no cdp enable
    crypto map mymap
    router eigrp 90
    redistribute static
    redistribute ospf 1 metric 1 1 1 1 1
    network 192.100.100.0
    network 192.168.234.0
    no auto-summary
    router ospf 1
    log-adjacency-changes
    redistribute eigrp 90 subnets
    network 192.100.100.0 0.0.0.255 area 0
    network 192.168.234.0 0.0.0.255 area 0
    ip local pool VPN 172.16.100.1 172.16.100.10
    ip forward-protocol nd
    ip route 0.0.0.0 0.0.0.0 82.195.135.1
    ip http server
    no ip http secure-server
    ip access-list extended internet
    deny   ip 0.0.0.0 0.255.255.255 any
    deny   ip 127.0.0.0 0.255.255.255 any
    deny   ip 192.0.2.0 0.0.0.255 any
    deny   ip 169.254.0.0 0.0.255.255 any
    deny   ip 224.0.0.0 31.255.255.255 any
    deny   ip 172.16.0.0 0.0.15.255 any log
    deny   ip 10.0.0.0 0.255.255.255 any log
    deny   ip 192.168.0.0 0.0.255.255 any log
    permit esp any any
    permit udp any host 82.195.135.2 eq isakmp
    permit tcp host 212.98.130.56 eq 22 host 82.195.135.2
    permit udp any host 82.195.135.2 eq non500-isakmp
    permit gre any any
    permit tcp host 174.8.7.53 host 82.195.135.2 eq 22
    deny   ip any any log
    access-list 181 permit ip 192.100.100.0 0.0.0.255 172.16.100.0 0.0.0.255
    access-list 181 permit ip 192.168.40.0 0.0.0.255 172.16.100.0 0.0.0.255
    access-list 181 permit ip 10.20.10.0 0.0.0.255 172.16.100.0 0.0.0.255
    access-list 181 permit ip 194.194.0.0 0.0.0.255 172.16.100.0 0.0.0.255
    access-list 181 permit ip 192.168.0.0 0.0.0.255 172.16.100.0 0.0.0.255
    access-list 181 permit ip 10.20.20.0 0.0.0.255 172.16.100.0 0.0.0.255
    access-list 181 permit ip 193.193.0.0 0.0.0.255 172.16.100.0 0.0.0.255
    access-list 181 permit ip 10.55.55.0 0.0.0.255 172.16.100.0 0.0.0.255
    access-list 181 permit ip 10.40.40.0 0.0.0.255 172.16.100.0 0.0.0.255
    control-plane
    line con 0
    line aux 0
    line vty 0 4
    exec-timeout 30 0
    logging synchronous
    transport input telnet ssh
    line vty 5 807
    exec-timeout 60 0
    transport input ssh
    scheduler allocate 20000 1000
    end
    DU-XYZ-1841# Буду очень признателен за любые советы и помощь!!!
    oreggin
    06.02.2012 19:45:00
    Когда примерно будет поддержка многоточечного GRE и/или NHRP в RoS? Где эти функции в плане развития?
    oreggin
    06.02.2012 19:57:00
    Кроме того, у интерфейса GRE-туннеля нет IPv6 локального адреса канала, и я не могу назначить локальный адрес канала на интерфейс GRE-туннеля, поэтому не могу использовать DHCPv6 на нём.
    florinsanaja
    16.09.2012 10:29:00
    Могу ли я настроить мультипиринговый VPN (центральный) на маршрутизаторе Cisco 2911 и подключаться с другими филиалами, которые используют роутеры Mikrotik? Возможно ли запускать мультипиринговый VPN одновременно на Cisco-роутере, чтобы он был подключен к филиалам на Mikrotik?
    florinsanaja
    16.09.2012 16:49:00
    Дорогие друзья, возможно ли создать VPN между маршрутизатором Cisco 2911 и Mikrotik RB750? Я не могу настроить мультипиры Mikrotik на центральном Cisco маршрутизаторе. Думаю, Mikrotik не поддерживает GRE или DMVPN для настройки на обоих устройствах. Буду очень благодарен за любые идеи! Спасибо большое!
    infused
    28.09.2013 04:55:00
    Просто поднимаю это сообщение, потому что у вас это получится, мы вот только что сделали. Ваш главный Cisco DMVPN роутер подключается к Mikrotik с помощью простого GRE-туннеля. Добавляете маршруты в DMVPN — и дело в шляпе. На самом деле всё не так уж сложно. Просто нужно вручную добавить маршруты на Mikrotik.
