[admin@RB] > /interface wireless export jan/01/2002 01:00:25 by RouterOS 4.9 software id = 05RX-71I2 /interface wireless security-profiles set default authentication-types=“” eap-methods=passthrough group-ciphers=“” group-key-update=5m interim-update=0s management-protection=disabled management-protection-key=“” mode=none name=default radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3= none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“” static-sta-private-algo=none static-sta-private-key=“” static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate= none tls-mode=no-certificates unicast-ciphers=“” wpa-pre-shared-key=“” wpa2-pre-shared-key=“” add authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip group-key-update=5m interim-update=0s management-protection=allowed management-protection-key=“” mode=dynamic-keys name=profile1 radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3= none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“” static-sta-private-algo=none static-sta-private-key=“” static-transmit-key=key-0 supplicant-identity=“” tls-certificate=none tls-mode=no-certificates unicast-ciphers=tkip wpa-pre-shared-key= Welcome10 wpa2-pre-shared-key=Welcome10 add authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip group-key-update=5m interim-update=0s management-protection=allowed management-protection-key=“” mode=dynamic-keys name=profile2 radius-eap-accounting=no radius-mac-accounting=yes radius-mac-authentication=yes radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3= none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“” static-sta-private-algo=none static-sta-private-key=“” static-transmit-key=key-0 supplicant-identity=“” tls-certificate=none tls-mode=no-certificates unicast-ciphers=tkip wpa-pre-shared-key= Welcome10 wpa2-pre-shared-key=Welcome10 /interface wireless set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 antenna-mode=ant-a area=“” arp=enabled band=2ghz-10mhz basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment=“” compression=no country=no_country_set default-ap-tx-limit=0 default-authentication=no default-client-tx-limit=0 default-forwarding=no dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s frame-lifetime=0 frequency=2462 frequency-mode=superchannel frequency-offset=0 hide-ssid=yes hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=4 l2mtu=2290 mac-address=00:15:6D:65:F7:DE max-station-count=2007 mode=bridge mtu=1500 name=wlan1 noise-floor-threshold=default on-fail-retry-time=100ms periodic-calibration=default periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=post-2.9.25 radio-name= “Office” rate-set=default scan-list=2300-2500 security-profile= profile2 ssid=backbone1 station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power=17 tx-power-mode= all-rates-fixed update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=bridge1 wds-default-cost=100 wds-ignore-ssid=no wds-mode=static wmm-support=disabled /interface wireless manual-tx-power-table set wlan1 comment=“” manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17, 6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps :17,HT20-0:0,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7: 0,HT40-0:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0” /interface wireless nstreme set wlan1 comment=“” disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none /interface wireless wds add arp=enabled comment=“” disabled=no master-interface=wlan1 mtu=1500 name= wds1 wds-address=00:15:6D:65:F8:4A /interface wireless access-list add ap-tx-limit=0 authentication=yes client-tx-limit=0 comment=“Office2” disabled=no forwarding=yes interface=wlan1 mac-address=00:15:6D:65:F8:4A management-protection-key=“” private-algo=none private-key=“” private-pre-shared-key=Welcome10 signal-range=-120.120 /interface wireless align set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor= 00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=no ssid-all=no /interface wireless connect-list add area-prefix=“” comment=“” connect=yes disabled=no interface=wlan1 mac-address=00:15:6D:65:F8:4A security-profile=default signal-range= -120.120 ssid=“” /interface wireless sniffer set channel-time=200ms file-limit=10 file-name=“” memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled= no streaming-max-rate=0 streaming-server=0.0.0.0 /interface wireless snooper set channel-time=200ms multiple-channels=yes receive-errors=no
