Вот моя конфигурация:
[otgoo@Testing] > ip fire ex
# 12 окт 2010 16:00:55, RouterOS 4.5
# software id = S17R-9NMM
/ip firewall connection tracking
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m \
udp-timeout=10s
/ip firewall mangle
add action=mark-packet chain=forward comment="" disabled=no dst-address=172.16.20.0/24 new-packet-mark=FrMOBINET_ISP passthrough=yes src-address=\
202.131.224.0/19
add action=mark-packet chain=forward comment="" disabled=no dst-address=202.131.224.0/19 new-packet-mark=ToMOBINET_ISP passthrough=yes src-address=\
172.16.20.0/24
/ip firewall nat
add action=masquerade chain=srcnat comment="" disabled=no out-interface=ether1
[otgoo@Testing] > ip add pr det
Flags: X - отключен, I - недействителен, D - динамический
0 ;; К интернету - IP
address=192.168.123.80/24 network=192.168.123.0 broadcast=192.168.123.255 interface=ether1 actual-interface=ether1
1 ;; К Radius - IP:192.168.100.3/24
address=192.168.100.3/24 network=192.168.100.0 broadcast=192.168.100.255 interface=ether3 actual-interface=ether3
2 ;; Japan Town
address=172.16.20.1/23 network=172.16.20.0 broadcast=172.16.21.255 interface=ether2 actual-interface=ether2
3 ;; New 1r khoroolol
address=172.16.24.1/23 network=172.16.24.0 broadcast=172.16.25.255 interface=ether4 actual-interface=ether4
[otgoo@Testing] > ip rou pr det
Flags: X - отключен, A - активен, D - динамический, C - подключён, S - статический, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
0 A S dst-address=0.0.0.0/0 gateway=192.168.123.250 gateway-status=192.168.123.250 reachable ether1 distance=1 scope=30 target-scope=10
1 ADC dst-address=172.16.20.0/23 pref-src=172.16.20.1 gateway=ether2 gateway-status=ether2 reachable distance=0 scope=10
2 ADC dst-address=172.16.24.0/23 pref-src=172.16.24.1 gateway=ether4 gateway-status=ether4 unreachable distance=0 scope=200
3 ADC dst-address=192.168.100.0/24 pref-src=192.168.100.3 gateway=ether3 gateway-status=ether3 unreachable distance=0 scope=200
4 ADC dst-address=192.168.123.0/24 pref-src=192.168.123.80 gateway=ether1 gateway-status=ether1 reachable distance=0 scope=10
[otgoo@Testing] > que ex
# 12 окт 2010 16:07:32, RouterOS 4.5
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
add kind=pcq name=Test-Gueue pcq-classifier=src-address,dst-address pcq-limit=50 pcq-rate=1024000 pcq-total-limit=2000
set default-small kind=pcq name=default-small pcq-classifier="" pcq-limit=50 pcq-rate=0 pcq-total-limit=2000
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=MN-Upload packet-mark=ToMOBINET_ISP parent=global-in priority=1 \
queue=default
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=MN-Download packet-mark=FrMOBINET_ISP parent=global-out priority=1 \
queue=default
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set pppoe-in1 queue=default
[otgoo@Testing] > que sim prin det
0 D name="<hotspot-otgoo>" target-addresses=172.16.20.11/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8
queue=default-small/default-small limit-at=256k/256k max-limit=256k/256k burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s
total-queue=default-small
1 D name="<hotspot-booloo>" target-addresses=172.16.20.18/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8
2 D name="hs-<MobiNet JapanTown>" dst-address=0.0.0.0/0 interface=ether2 parent=none direction=both priority=8 queue=hotspot-default/hotspot-default
limit-at=0/0 max-limit=0/0 burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s total-queue=default-small
3 D name="hs-<1r horoolol>" dst-address=0.0.0.0/0 interface=ether4 parent=none direction=both priority=8 queue=hotspot-default/hotspot-default limit-at=0/0
Проверьте мою конфигурацию и скажите, как её исправить. Спасибо!
