    CCR 1016 и балансировка нагрузки на 4 WAN с помощью PCC
    CCR 1016 и балансировка нагрузки на 4 WAN с помощью PCC, RouterOS
    resotat
    30.08.2015 18:07:00
    Здравствуйте и заранее спасибо за ваше время и ответ. Я использовал 493AH с кодом для балансировки нагрузки, и он отлично работал. Вот сам код:
    /ip address
    add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local
    add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN1
    add address=192.168.2.2/24 network=192.168.2.0 broadcast=192.168.2.255 interface=WAN2
    add address=192.168.3.2/24 network=192.168.3.0 broadcast=192.168.3.255 interface=WAN3
    add address=192.168.4.2/24 network=192.168.4.0 broadcast=192.168.4.255 interface=WAN4
    /ip firewall mangle
    add chain=input in-interface=WAN1 action=mark-connection new-connection-mark=WAN1_conn
    add chain=input in-interface=WAN2 action=mark-connection new-connection-mark=WAN2_conn
    add chain=input in-interface=WAN3 action=mark-connection new-connection-mark=WAN3_conn
    add chain=input in-interface=WAN4 action=mark-connection new-connection-mark=WAN4_conn
    add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
    add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
    add chain=output connection-mark=WAN3_conn action=mark-routing new-routing-mark=to_WAN3
    add chain=output connection-mark=WAN4_conn action=mark-routing new-routing-mark=to_WAN4
    add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=Local
    add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=Local
    add chain=prerouting dst-address=192.168.3.0/24 action=accept in-interface=Local
    add chain=prerouting dst-address=192.168.4.0/24 action=accept in-interface=Local
    add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/0 action=mark-connection new-connection-mark=WAN1_conn passthrough=yes
    add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/1 action=mark-connection new-connection-mark=WAN2_conn passthrough=yes
    add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/2 action=mark-connection new-connection-mark=WAN3_conn passthrough=yes
    add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses-and-ports:4/3 action=mark-connection new-connection-mark=WAN4_conn passthrough=yes
    add chain=prerouting connection-mark=WAN1_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN1
    add chain=prerouting connection-mark=WAN2_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN2
    add chain=prerouting connection-mark=WAN3_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN3
    add chain=prerouting connection-mark=WAN4_conn in-interface=Local action=mark-routing new-routing-mark=to_WAN4
    /ip route
    add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN1 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_WAN2 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=to_WAN3 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=192.168.4.1 routing-mark=to_WAN4 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=192.168.3.1 distance=3 check-gateway=ping
    add dst-address=0.0.0.0/0 gateway=192.168.4.1 distance=4 check-gateway=ping
    /ip firewall nat
    add chain=srcnat out-interface=WAN1 action=masquerade
    add chain=srcnat out-interface=WAN2 action=masquerade
    add chain=srcnat out-interface=WAN3 action=masquerade
    add chain=srcnat out-interface=WAN4 action=masquerade
    В общем, на 493AH всё работает отлично. НО на CCR1016 это не работает. Что происходит? Загрузка уходит в абсурд. Мои WAN-порты имеют 6 Мбит/с на загрузку (Tx), но Cloud Core начинает показывать цифры далеко за 6 Мбит — 9 и 10 Мбит на разных из 4 WAN-ов.
    Плюс в окне «Interface» порт «Local» показывает всего 2 Мбит Tx, как и Bridge. Зато WAN1 показывает 5 Мбит Tx, WAN2 — 6 Мбит Tx, WAN3 — 9 Мбит Tx, WAN4 — 7 Мбит Tx. Цифры не сходятся, и, конечно, из-за этого вся сеть работает как попало.
    Когда я перепрограммировал CCR1016, мне везде, где в коде стоял интерфейс «Local», говорили менять на Bridge, потому что Local - это подчинённый Bridge.
    Кто-нибудь вообще может объяснить, что происходит? Этот роутер не может выполнять этот код? Может, CCR1016 сломан, аппаратная проблема?
    Ах да, последний момент: 493AH работает на OS 5.12, CCR1016 — на 6.31.
    digitalxtc
    24.07.2016 17:22:00
    restotat, это старая тема, но поднимаю её снова, потому что сам сейчас сталкиваюсь с такой же задачей — настраиваю балансировку нагрузки PCC на 4 WAN на облачных роутерах. Если у тебя всё получилось, не мог бы ты поделиться скриптом для остальных? Спасибо!
    fcforensic
    01.05.2017 10:17:00
    Со мной происходит то же самое, есть ли у кого-нибудь предложение для CCR1016 в конфигурации Loada balance PCC?
    MATU
    05.05.2017 23:15:00
    Также жду ответа.
    gxmc
    08.07.2017 14:56:00
    Я ищу адаптацию, чтобы сделать именно такое же распределение нагрузки, но только с 2 интерфейсами для WAN. У меня есть 2 WAN за одним PTP и ещё 2 WAN за другим PTP. Дело в том, что я уже делал это раньше, но не могу вспомнить, как помечал трафик по IP, а не по интерфейсу.
    resotat
    26.11.2018 20:22:00
    Привет! Проблема оказалась в том, что DNS-запросы по WAN-линиям перегружали пропускную способность загрузки WAN-порта. Решение — правило в файрволе, блокирующее внешние DNS-запросы.
