В моих логах часто появляются такие записи от pim: 12:12:36 pim,warning RX WHOLEPKT signal: vif_index = 31 src = 10.1.1.2 dst = 239.255.255.250 len = 201: нет RP-адреса для этой группы. Я не понимаю, что их вызывает, и, похоже, это ни на что отрицательно не влияет. Вот моя конфигурация PIM.
[admin@MikroTik] /routing pim> export verbose
# 16 окт 2015 12:14:36, RouterOS 6.32.2
# software id = XXXX-XXXX
/routing pim
set switch-to-spt=yes switch-to-spt-bytes=0 switch-to-spt-interval=1m40s
/routing pim interface
add alternative-subnets="" assert-override-interval=3s assert-time=3m disabled=no dr-priority=1 hello-holdtime=1m45s hello-period=30s hello-trigerred-delay=5s igmp-version=IGMPv2 interface=vlan101 join-prune-holdtime=3m30s join-prune-period=1m override-interval=250 preferred-source-address=0.0.0.0 propagation-delay=50 protocols=pim,igmp require-hello=yes tracking-support=yes
add alternative-subnets="" assert-override-interval=3s assert-time=3m disabled=no dr-priority=1 hello-holdtime=1m45s hello-period=30s hello-trigerred-delay=5s igmp-version=IGMPv2 interface=vlan102 join-prune-holdtime=3m30s join-prune-period=1m override-interval=250 preferred-source-address=0.0.0.0 propagation-delay=50 protocols=pim,igmp require-hello=yes tracking-support=yes
add alternative-subnets="" assert-override-interval=3s assert-time=3m disabled=no dr-priority=1 hello-holdtime=1m45s hello-period=30s hello-trigerred-delay=5s igmp-version=IGMPv2 interface=vlan103 join-prune-holdtime=3m30s join-prune-period=1m override-interval=250 preferred-source-address=0.0.0.0 propagation-delay=50 protocols=pim,igmp require-hello=yes tracking-support=yes
/routing pim
