В общем, я тоже обновил ОС до последней версии, но решения пока нет. Я перестроил конфигурацию вместо восстановления старой, но конфигурация, которая работала раньше, теперь не работает. [admin@MikroTik] > export compact
# 04.10.2013 19:24:04 by RouterOS 6.4
# software id = PRRI-T8EG
/interface bridge
add l2mtu=1598 name=bridge-dbox
add admin-mac=D4:CA:6D:9A:39:F1 auto-mac=no l2mtu=1598 name=bridge-local \
protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=\
indoors frequency=2452 ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=\
ap-bridge ssid=dd-wrt wireless-protocol=802.11
/interface ethernet
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 name=ether5-slave-dbox
/ip neighbor discovery
set wlan1 discover=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys wpa-pre-shared-key=xxxxxxxxxxxxxxxxxxxx wpa2-pre-shared-key=\
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
/ip pool
add name=dhcp ranges=192.168.100.10-192.168.100.20
/ip dhcp-server
add address-pool=dhcp disabled=no interface=bridge-local name=default
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
/interface bridge port
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-dbox interface=ether5-slave-dbox
add bridge=bridge-dbox interface=ether1-gateway
/ip address
add address=192.168.100.254/24 comment="default configuration" interface=\
wlan1 network=192.168.100.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
no interface=ether1-gateway
/ip dhcp-server network
add address=192.168.100.0/24 comment="default configuration" dns-server=\
192.168.100.254 gateway=192.168.100.254 netmask=24
/ip dns
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router
/ip firewall filter
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=\
ether1-gateway
add chain=forward comment="default configuration" connection-state=\
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
/ip firewall nat
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=bridge-dbox to-addresses=0.0.0.0
/ip service
set api disabled=yes
/system clock
set time-zone-name=Europe/Brussels
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes mode=unicast primary-ntp=85.10.246.226 secondary-ntp=\
193.225.118.163
/system routerboard settings
set silent-boot=yes
/tool mac-server
set [ find default=yes ] disabled=yes
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-dbox
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
Цель - получить eth5 как отдельный интерфейс, получающий WAN IP. Используя конфигурацию выше, DHCP-сервер не получает IP-адрес. Я могу что-то изменить, но толком не знаю, что делаю… Если есть другие, более простые способы достичь этого, буду рад услышать.
