    Проблема с IPSEC, mt <> cisco
    Проблема с IPSEC, mt <> cisco, RouterOS
    rexie
    04.05.2006 08:32:00
    Привет, я пытаюсь настроить ipsec-туннель между нашим Mikrotik и Cisco (модель неизвестна) клиента. По какой-то причине мы не можем пройти этап 1. У кого-нибудь есть какие-нибудь подсказки или примеры настройки этого соединения?
    Конфигурация:
    policy:
           src-address=10.36.0.0/16:any
           dst-address=172.16.54.147/32:any
           protocol=all
           action=encrypt
           level=require
           ipsec-protocols=esp
           tunnel=yes
           sa-src-address=62.x.y.z
           sa-dst-address=217.x.y.z
           proposal=BT
           manual-sa=none
           dont-fragment=clear
    peer:
           address=217.x.y.z/32:500
           secret=“*****”
           generate-policy=no
           exchange-mode=main
           send-initial-contact=no
           proposal-check=claim
           hash-algorithm=sha1
           enc-algorithm=3des
           dh-group=modp1024
           lifetime=1d
           lifebytes=0
    proposal:
       1
           name=“BT”
           auth-algorithms=sha1
           enc-algorithms=3des
           lifetime=1d
           lifebytes=0
           pfs-group=none
    log:
       10:21:51 ipsec,ike,info queuing SA request, phase 1 with peer 217.x.y.z will be established first
       10:21:51 ipsec,ike,info initiating phase 1, starting mode Identity Protection (local 62.x.y.z:500) (remote unknown)
       10:21:51 ipsec,info ipsec packet discarded: src=10.36.1.200 dst=172.16.54.147
       10:21:51 ipsec,ike,info received ISAKMP packet from 217.x.y.z:500, phase 1, Identity Protection
       10:21:52 ipsec,ike,info received ISAKMP packet from 217.x.y.z:500, phase 1, Identity Protection
       10:21:52 ipsec,ike,info packet has invalid ID payload (remote unknown)
       10:21:52 ipsec,info ipsec packet discarded: src=10.36.1.200 dst=172.16.54.147
       10:21:53 ipsec,info ipsec packet discarded: src=10.36.1.200 dst=172.16.54.147
       10:21:54 ipsec,info ipsec packet discarded: src=10.36.1.200 dst=172.16.54.147
       10:21:55 ipsec,info ipsec packet discarded: src=10.36.1.200 dst=172.16.54.147
       10:22:02 ipsec,ike,info received ISAKMP packet from 217.x.y.z:500, phase 1, Identity Protection
       10:22:09 system,info,account user admin logged out from 10.36.0.27 via telnet
       10:22:12 ipsec,ike,info received ISAKMP packet from 217.x.y.z:500, phase 1, Identity Protection
       10:22:22 ipsec,ike,info received ISAKMP packet from 217.x.y.z:500, phase 1, Identity Protection
       10:22:22 ipsec,ike,info dequeuing SA request to 217.x.y.z, phase 1 wait timed out
       10:22:32 ipsec,ike,info received ISAKMP packet from 217.x.y.z:500, phase 2, Informational
       10:22:33 ipsec,ike,info phase 1 deleted (local 62.x.y.z:500) (remote 217.x.y.z:500)
    Привет, Рекс
    fatonk
    04.05.2006 10:47:00
    Можешь, пожалуйста, выложить конфиг Cisco, чтобы можно было сравнить. С уважением, Faton.
    rexie
    04.05.2006 10:51:00
    Вот конфигурация Cisco, которую нам прислали:
    Object-group network Amercom_Network Network=object 10.36.0.0 255.255.0.0
    Object-group network SQL_server Description IPs of the same NIC
    Network-object host 172.16.54.147
    Network-object host 172.16.54.148
    Access-list vpn-amercom extended permit ip object-group SQL_server object-group Amercom_network
    Crypto ipsec transform-set AMERCOM esp-3des esp-sha-hmac
    Crypto map SARALEE-MAP 10 match address vpn-Amercom
    Crypto map SARALEE-MAP 10 set peer 62.x.y.z
    Crypto map SARALEE-MAP 10 set transform-set Amercom
    Crypto map SARALEE-MAP 10 set security-association lifetime seconds 86400
    Crypto map SARALEE-MAP 10 set nat-t disable
    Crypto map SARALEE-MAP interface outside
    Isakmp enable outside
    Isakmp policy 1 authentication pre-share
    Isakmp policy 1 encryption 3des
    Isakmp policy 1 hash sha
    Isakmp policy 1 group 2
    Isakmp policy 1 lifetime 86400
    Tunnel-group 62.x.y.z type ipsec-121
    Tunnel-group 62.x.y.z ipsec-attributes Pre-shared-key *
