Привет! У меня настроена беспроводная сеть на базе Intel DN2800MT, 1ГБ оперативной памяти и беспроводной карты Compex WLE300NX 6A, но я не могу получить более высокую скорость беспроводной связи, чем 300/300 Мбит/с. Поддерживает ли эта карта скорость выше 300 Мбит/с?
ROS 6.0beta3 на x86
/interface wireless
set 0
adaptive-noise-immunity=none
allow-sharedkey=no
antenna-gain=0
area=""
arp=enabled
band=5ghz-a/n
basic-rates-a/g=6Mbps
basic-rates-b=""
bridge-mode=enabled
channel-width=20/40mhz-ht-below
compression=no
country="czech republic"
default-ap-tx-limit=0
default-authentication=yes
default-client-tx-limit=0
default-forwarding=yes
dfs-mode=none
disable-running-check=no
disabled=no
disconnect-timeout=3s
distance=dynamic
frame-lifetime=0
frequency=5700
frequency-mode=manual-txpower
frequency-offset=0
hide-ssid=no
ht-ampdu-priorities=0
ht-amsdu-limit=8192
ht-amsdu-threshold=8192
ht-basic-mcs= mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-guard-interval=any
ht-rxchains=0,1,2
ht-supported-mcs= mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-txchains=0,1,2
hw-fragmentation-threshold=disabled
hw-protection-mode=none
hw-protection-threshold=0
hw-retries=7
l2mtu=2290
mac-address= 00:80:48:77:04:4E
max-station-count=2007
mode=ap-bridge
mtu=1500
multicast-helper=default
name=wlan1
noise-floor-threshold=default
nv2-cell-radius=30
nv2-noise-floor-offset=default
nv2-preshared-key=""
nv2-qos=default
nv2-queue-count=2
nv2-security=disabled
on-fail-retry-time=100ms
periodic-calibration=default
periodic-calibration-interval=60
preamble-mode=both
proprietary-extensions=post-2.9.25
radio-name=00804877044E
rate-selection=advanced
rate-set=default
scan-list=default
security-profile=default
ssid=SPKFree-FINtoMTS
station-bridge-clone-mac= 00:00:00:00:00:00
supported-rates-a/g=6Mbps
supported-rates-b=""
tdma-period-size=2
tx-power=3
tx-power-mode=all-rates-fixed
update-stats-interval=disabled
wds-cost-range=50-150
wds-default-bridge= none
wds-default-cost=100
wds-ignore-ssid=no
wds-mode=disabled
wireless-protocol=unspecified
wmm-support=disabled
tx-power at all rates fixed = 3
range ~500m
ROS 6.0beta3 на x86
/interface wireless
set 0
allow-sharedkey=no
antenna-gain=0
area=""
arp=enabled
band=5ghz-a/n
basic-rates-b=""
bridge-mode=enabled
compression=no
dfs-mode=none
disabled=no
distance=dynamic
frame-lifetime=0
frequency=5700
frequency-offset=0
hide-ssid=no
ht-amsdu-limit=8192
ht-rxchains=0,1,2
ht-txchains=0,1,2
hw-retries=7
l2mtu=2290
mode=ap-bridge
mtu=1500
name=wlan1
nv2-cell-radius=30
nv2-qos=default
nv2-queue-count=2
preamble-mode=both
rate-set=default
scan-list=default
tdma-period-size=2
tx-power=3
wds-ignore-ssid=no
wds-mode=disabled
range ~500m
