Привет. У меня проблема с маскировкой srcnat, пытаюсь настроить мой MT как обычный домашний шлюз к интернету, но никак не могу заставить это работать. Вот моя сетевая топология, начиная с моего провайдера: Cisco PIX 10.0.0.1----->AP 10.0.0.2----->Dlink 802.11b Bridge 10.0.0.70 — —>Mikrotik RB532 Ether1 10.0.0.71----->Ether2 (src-nat’ed) 192.168.0.1- ---->PC 192.168.0.2. Вот соответствующие строки из моей конфигурации Mikrotik:
/ interface ethernet set ether1 name=“ether1” mtu=1500 mac-address=00:0C:42:09:36:E1 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes cable-settings=default mdix-enable=yes speed=100Mbps comment=“” disabled=no
set ether2 name=“ether2” mtu=1500 mac-address=00:0C:42:09:36:E2 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes cable-settings=default speed=100Mbps comment=“” disabled=no
/ ip pool add name=“dhcp_pool1” ranges=192.168.0.2-192.168.0.254
/ ip accounting set enabled=no account-local-traffic=no threshold=256
/ ip accounting web-access set accessible-via-web=no address=0.0.0.0/0
/ ip service set enabled=no port=1080 connection-idle-timeout=2m max-connections=200
/ ip dns set primary-dns=72.87.48.50 secondary-dns=72.87.48.70 allow-remote-requests=no cache-size=2048KiB cache-max-ttl=1w
/ ip address add address=10.0.0.71/24 network=10.0.0.0 broadcast=10.0.0.255 interface=ether1 comment=“” disabled=no
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=ether2 comment=“” disabled=no
/ ip route add dst-address=0.0.0.0/0 gateway=10.0.0.1 scope=255 target-scope=10 comment=“” disabled=no
/ ip firewall nat add chain=srcnat out-interface=ether1 action=masquerade comment=“” disabled=no
/ ip dhcp-server add name=“dhcp1” interface=ether2 lease-time=3d address-pool=dhcp_pool1 bootp-support=static authoritative=after-2sec-delay disabled=no
/ ip dhcp-server config set store-leases-disk=5m
/ ip dhcp-server lease
/ ip dhcp-server network add address=192.168.0.0/24 gateway=192.168.0.1 comment=“”
С этой конфигурацией мой Mikrotik может пинговать Cisco PIX моего провайдера по адресу 10.0.0.1, но мой PC — нет. Мой PC может пинговать только до ether1 на Mikrotik, который равен 10.0.0.71. 10.0.0.70 тоже нельзя пинговать с PC. Стоит отметить, что мой Cisco 871w Router/Firewall имеет те же адреса, маршруты и настройку src-nat, и он работает отлично. Может ли кто-нибудь найти проблему в моей конфигурации и сказать, что я делаю не так? Спасибо заранее.
Эрик
Эрик
