Я пытаюсь настроить правила mangle для создания балансировки нагрузки, но никак не могу определиться, использовать цепочки prerouting или input. Я немного почитал, но все равно не понимаю, когда какой правило лучше использовать. Вот моя конфигурация: `/ip address`
add address=172.16.0.1/24 interface=Local-slave5
add address=10.1.1.2/24 interface=WAN1
add address=10.2.2.2/24 interface=WAN2
add address=10.3.3.2/24 interface=WAN3
`/ip firewall mangle`
add action=accept chain=prerouting disabled=no dst-address=10.1.1.0/24 in-interface=Local-slave5
add action=accept chain=prerouting disabled=no dst-address=10.2.2.0/24 in-interface=Local-slave5
add action=accept chain=prerouting disabled=no dst-address=10.3.3.0/24 in-interface=Local-slave5
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no dst-address-type=!local in-interface=Local-slave5 new-connection-mark=WAN1_mark passthrough=yes per-connection-classifier=both-addresses-and-ports:3/0
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no dst-address-type=!local in-interface=Local-slave5 new-connection-mark=WAN2_mark passthrough=yes per-connection-classifier=both-addresses-and-ports:3/1
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no dst-address-type=!local in-interface=Local-slave5 new-connection-mark=WAN3_mark passthrough=yes per-connection-classifier=both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting connection-mark=WAN1_mark disabled=no in-interface=Local-slave5 new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_mark disabled=no in-interface=Local-slave5 new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN3_mark disabled=no in-interface=Local-slave5 new-routing-mark=to_WAN3 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_mark disabled=no new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_mark disabled=no new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN3_mark disabled=no new-routing-mark=to_WAN3 passthrough=yes
Мне нужно создавать метки для входящих пакетов, но что лучше: использовать цепочку prerouting или input?
добавить action=mark-connection chain=prerouting connection-mark=no-mark disabled=no in-interface=WAN1 new-connection-mark=WAN1_mark passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no in-interface=WAN2 new-connection-mark=WAN2_mark passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=no in-interface=WAN3 new-connection-mark=WAN3_mark passthrough=yes
или
add action=mark-connection chain=input disabled=no new-connection-mark=WAN1_mark in-interface=WAN1 passthrough=yes
add action=mark-connection chain=input disabled=no new-connection-mark=WAN2_mark in-interface=WAN2 passthrough=yes
add action=mark-connection chain=input disabled=no new-connection-mark=WAN3_mark in-interface=WAN3 passthrough=yes
или
