Привет всем!
Надеюсь, кто-нибудь сможет подсказать по поводу WDS bridge, с которым у меня небольшая заминка. WDS работает нормально, трафик проходит, но не могу получить доступ к Mikrotik по их управляющему IP.
Вот конфигурация:
Farside (дальняя сторона) 10.10.11.3:
`/interface bridge add arp=proxy-arp l2mtu=1526 name=backhaul`
`/interface wireless set [ find default-name=wlan1 ] antenna-gain=24 band=5ghz-onlyn channel-width=20/40mhz-ht-below disabled=no ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=station-wds ssid=Latteraghbh wds-default-bridge=backhaul wds-mode=dynamic wireless-protocol=nv2`
`/interface wireless nstreme set wlan1 enable-nstreme=yes`
`/ip neighbor discovery set wlan1 discover=no`
`/interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik`
`/ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d`
`/ip ipsec proposal set [ find default=yes ] enc-algorithms=3des`
`/system logging action set 0 memory-lines=100 set 1 disk-lines-per-file=100`
`/interface bridge port add bridge=backhaul interface=ether1 add bridge=backhaul interface=wlan1`
`/ip address add address=10.10.11.3/24 interface=backhaul network=10.10.11.0`
`/ip firewall connection tracking set enabled=no`
`/ip service set api disabled=yes`
`/system identity set name=“Backhaul Slave”`
Master Side (сторона контроллера)
`/interface bridge add arp=proxy-arp l2mtu=1526 name=echo`
`/interface wireless set [ find default-name=wlan1 ] antenna-gain=24 band=5ghz-onlyn basic-rates-a/g="" channel-width=20/40mhz-ht-above country=ireland dfs-mode=no-radar-detect disabled=no frequency=5620 ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge nv2-qos=frame-priority ssid=Latteraghbh wds-default-bridge=echo wds-mode=dynamic wireless-protocol=nv2`
`/interface wireless manual-tx-power-table set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:25,HT20-1:25,HT20-2 :25,HT20-3:24,HT20-4:23,HT20-5:22,HT20-6:21,HT20-7:19,HT40-0:25,HT40-1:24,HT40-2:23,HT40-3:22,HT40-4:21,HT40-5:17,HT40-6:17,HT40-7:17"`
`/interface bridge port add bridge=echo interface=wlan1 add bridge=echo interface=ether1`
`/ip address add address=10.10.11.2/24 interface=echo network=10.10.11.0`
`/ip firewall nat add action=masquerade chain=srcnat out-interface=ether1`
`/system identity set name=“Backhaul Master”`
Раньше это работало отлично с nano, есть какие-нибудь идеи?
Вот конфигурация:
