    Странное поведение с WDS.
    Странное поведение с WDS., RouterOS
    stadtnetz
    27.01.2005 10:34:00
    У нас есть 2 outdoor-роутербоарда, работающих в режиме wds-bridged. Если tx-power одного из беспроводных интерфейсов, используемых для wds, здесь вывод ping при установке tx-power в 9: ping 192.168.125.5 PING 192.168.125.5 (192.168.125.5): 56 data bytes 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=8.5 ms 64 bytes from 192.168.125.5: icmp_seq=1 ttl=64 time=4.2 ms 64 bytes from 192.168.125.5: icmp_seq=2 ttl=64 time=4.3 ms 64 bytes from 192.168.125.5: icmp_seq=3 ttl=64 time=19.7 ms 64 bytes from 192.168.125.5: icmp_seq=4 ttl=64 time=5.4 ms 64 bytes from 192.168.125.5: icmp_seq=5 ttl=64 time=4.4 ms — 192.168.125.5 ping statistics — 6 packets transmitted, 6 packets received, 0% packet loss round-trip min/avg/max = 4.2/7.7/19.7 ms при установке tx-power по умолчанию, ping получает дубликаты и имеет более высокое время, чем раньше: ping 192.168.125.5 PING 192.168.125.5 (192.168.125.5): 56 data bytes 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=180.9 ms 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=283.3 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=392.1 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=486.5 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=591.6 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=674.7 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=769.1 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=869.6 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=960.6 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=1051.6 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=1 ttl=64 time=91.4 ms 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=1170.4 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=1 ttl=64 time=211.2 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=1331.9 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=1 ttl=64 time=399.1 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=1511.2 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=1 ttl=64 time=586.3 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=1690.4 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=1 ttl=64 time=733.5 ms (DUP!) 64 bytes from 192.168.125.5: icmp_seq=0 ttl=64 time=1825.6 ms (DUP!) — 192.168.125.5 ping statistics — 2 packets transmitted, 2 packets received, +18 duplicates, 0% packet loss round-trip min/avg/max = 91.4/790.5/1825.6 ms
    Может ли кто-нибудь объяснить это?
    denialsander
    27.01.2005 11:58:00
    На каком расстоянии друг от друга твои AP? Какую радиокарту используешь? Кабели? Антенны?
    stadtnetz
    27.01.2005 12:55:00
    Расстояние: около 400 м
    Кабель MT1 (наружный): 1 м малопотерь
    Антенна: 8 дБи всенаправленная наружная
    Кабель MT2 (наружный): 10 м малопотерь
    Карты: 200 мВт Mikrotik Prism PCMCIA (с обеих сторон)
    mirko
    28.01.2005 07:16:00
    Похоже, сигнал слишком сильный. У нас была аналогичная проблема на PtP-линке на 200 метров, где использовались Atheros на 5 ГГц. Уровень сигнала был между -40 и -45, tx-power=default.  Линка постоянно разрывалась и восстанавливалась каждые несколько секунд. Пришлось установить tx-power=1, чтобы она заработала. Оставалось либо убрать антенны, либо понизить tx-power.
    denialsander
    28.01.2005 07:44:00
    Мощность EIRP должна быть около 30 dBm. Если это соединение на 2.4 GHz, то RF должен быть примерно -60, а если на 5.6 GHz – около -66. Если я не ошибся в расчетах, сигнал не должен быть слишком сильным. Но можно попробовать разные значения TX. Какой у тебя ACK-setting?
    Art
    28.01.2005 09:40:00
    Хм, мощность передачи нельзя установить выше 20, это значит, что твоя настройка по умолчанию больше 20 (возможно, 23). У меня была та же проблема с Senao 200 мВт, и я установил tx-power=20, и теперь всё отлично работает. Мои соединения 5 км ptp и в режиме AP.
