    Не вижу соседей RoMon
    Не вижу соседей RoMon, RouterOS
    viteralex
    01.12.2021 21:27:00
    Привет. Есть CRS326-24G-2S+ с версией 6.49.1 и такой конфигурацией:
    /interface bridge
    add admin-mac=2C:C8:1B:E2:67:7C auto-mac=no name=bridge vlan-filtering=yes
    /interface vlan
    add interface=bridge name=vlan1010 vlan-id=1010
    /interface list
    add name=Mgmt
    /interface bridge port
    add bridge=bridge interface=ether1
    add bridge=bridge interface=ether2
    add bridge=bridge interface=ether3
    add bridge=bridge interface=ether4
    add bridge=bridge interface=ether5
    add bridge=bridge interface=ether6
    add bridge=bridge interface=ether7
    add bridge=bridge interface=ether8
    add bridge=bridge interface=ether9
    add bridge=bridge interface=ether10
    add bridge=bridge interface=ether11
    add bridge=bridge interface=ether12
    add bridge=bridge interface=ether13
    add bridge=bridge interface=ether14
    add bridge=bridge interface=ether15
    add bridge=bridge interface=ether16
    add bridge=bridge interface=ether17
    add bridge=bridge interface=ether18
    add bridge=bridge interface=ether19
    add bridge=bridge interface=ether20
    add bridge=bridge interface=ether21
    add bridge=bridge interface=ether22
    add bridge=bridge interface=ether23
    add bridge=bridge interface=ether24
    add bridge=bridge interface=sfp-sfpplus1 pvid=1010
    /ip neighbor discovery-settings
    set discover-interface-list=Mgmt
    /interface bridge vlan
    add bridge=bridge tagged=bridge,sfp-sfpplus1 vlan-ids=1010
    /interface list member
    add interface=vlan1010 list=Mgmt
    /ip address
    add address=10.10.10.1/26 interface=vlan1010 network=10.10.10.0
    /system identity
    set name=val-sw1
    /system ntp client
    set enabled=yes primary-ntp=10.10.10.62
    /system routerboard settings
    set boot-os=router-os
    /tool romon
    set enabled=yes
    /tool romon port
    add disabled=no interface=vlan1010
    И CCR2004-16G-2S+ с версией 7.0.4 и конфигурацией:
    /interface bridge
    add admin-mac=DC:2C:6E:41:5B:37 auto-mac=no name=bridge pvid=1010 vlan-filtering=yes
    /interface ethernet
    set [ find default-name=ether1 ] comment="Uplink to val-sw1"
    set [ find default-name=ether2 ] comment="Uplink to val-sw2"
    set [ find default-name=ether3 ] comment="Uplink to val-sw3"
    set [ find default-name=ether4 ] comment="Uplink to val-sw4"
    set [ find default-name=ether5 ] comment="Uplink to val-sw5"
    set [ find default-name=ether6 ] comment="Uplink to val-sw6"
    set [ find default-name=ether7 ] comment="Uplink to val-sw7"
    set [ find default-name=sfp-sfpplus1 ] comment=WAN1
    set [ find default-name=sfp-sfpplus2 ] comment=WAN2
    /interface vlan
    add comment="Mgmt vlan" interface=bridge name=vlan1010 vlan-id=1010
    add comment="Work vlan" interface=bridge name=vlan2001 vlan-id=2001
    add comment="Guest wifi vlan" interface=bridge name=vlan2002 vlan-id=2002
    add comment="CCTV and Access control" interface=bridge name=vlan2003 vlan-id=2003
    add comment=Bots interface=bridge name=vlan2004 vlan-id=2004
    /interface list
    add name=Mgmt
    add bridge=bridge interface=ether1 pvid=1010
    add bridge=bridge interface=ether2 pvid=1010
    add bridge=bridge interface=ether3 pvid=1010
    add bridge=bridge disabled=yes interface=ether4 pvid=1010
    add bridge=bridge disabled=yes interface=ether5 pvid=1010
    add bridge=bridge disabled=yes interface=ether6 pvid=1010
    add bridge=bridge interface=ether7 pvid=1010
    add bridge=bridge tagged=bridge,ether1,ether2,ether3,ether4,ether5,ether6,ether7 vlan-ids=1010
    add bridge=bridge tagged=bridge,ether1,ether2,ether3,ether4,ether5,ether6,ether7 vlan-ids=2001
    add bridge=bridge tagged=bridge,ether7 vlan-ids=2002
    add bridge=bridge tagged=bridge,ether7 vlan-ids=2003
    add bridge=bridge tagged=bridge,ether1,ether2,ether3,ether4,ether5,ether6,ether7 vlan-ids=2004
    /system identity
    set name=val-rtr1
    /tool romon
    set enabled=yes
    /tool romon port
    set [ find default=yes ] forbid=yes
    И при этом не видно соседей romon. При этом vlan1010 работает, устройства друг друга пингуют.
    Meins
    29.01.2022 18:43:00
    Привет! Похоже, у меня такая же проблема. Как только активируешь VLAN, то не видишь никаких клиентов ROMON. Я замечал это уже в нескольких версиях прошивки.
    viteralex
    05.01.2022 11:20:00
    Я связался со службой поддержки Mikrotik, и они подтвердили эту проблему. Пообещали исправить её в следующих обновлениях.
    WildWest
    31.01.2022 21:57:00
    Та же проблема с коммутаторами CRS326/328!!! Romon перестал передаваться через VLAN по транковым портам. С этим вот не работает, а с этим вот работает. Пробовал и тестировал на нескольких разных сетях. Проблема встречается только на коммутаторах серии CRS 3xx. А на RouterOS 6 всё работало нормально.
    Theo9216
    08.04.2022 13:48:00
    После обновления с версии 6.49.5 до 7.2 почти все соседи в списке RoMon пропали. У нас в сети около 100 устройств, а видим мы только 10 из них. Фильтрация входящего трафика отключена, а типы кадров настроены на принятие всех. Раньше до обновления всё работало отлично. Буду признателен за любую помощь.
    heavenlyangel
    20.07.2022 02:35:00
    То же самое, помогите, пожалуйста.
    jamiewatson69
    24.10.2022 19:45:00
    Кто-нибудь с этим продвинулся? Я на 7.6 и вижу то же самое.
    AndreyRa
    04.11.2022 15:07:00
    Это ошибка в последних прошивках, которая возникает, если у вас для моста задан MAC-адрес администратора. В таком случае нужно вручную задать параметр ID RoMON, который должен быть равен MAC-адресу любого Ethernet-порта (даже если он не подключен). Эту идею я подсмотрел на http://forum.mikrotik.com/t/is-romon-broken-in-7-1-1/154704/1
    zervan
    05.11.2022 00:03:00
    У меня такая же проблема, но установка RoMON ID не помогла. Единственное решение, которое я нашёл — использовать гибридные порты между коммутаторами. Похоже, что кадры RoMON (а также Neighbors Discovery) передаются без тегов.
