Обновился до 7.12beta1 на hAPax3 и постоянно получаю отключения с ошибкой «SA Query Timeout». Пробовал отключить steering, но это не помогло. Вот разделы с беспроводными настройками из экспорта. Спасибо.
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax skip-dfs-channels=disabled width=20/40/80mhz configuration.country="United States" mode=ap ssid=76-5ghz disabled=no security.authentication-types=wpa2-psk,wpa3-psk steering.rrm=no wnm=no
set [ find default-name=wifi2 ] channel.band=2ghz-g skip-dfs-channels=disabled width=20mhz configuration.country="United States" mode=ap ssid=76-2ghz disabled=no security.authentication-types=wpa2-psk steering.rrm=no wnm=no
add configuration.country="United States" mode=ap ssid=2point4 disabled=no mac-address=1A:FD:74:FE:87:EA master-interface=wifi2 name=2point4 security.authentication-types=wpa2-psk steering.rrm=no wnm=no
add configuration.country="United States" mode=ap ssid=Guest disabled=no mac-address=1A:FD:74:FE:87:E8 master-interface=wifi1 name=Guest-wifi1 security.authentication-types=wpa2-psk,wpa3-psk steering.rrm=no wnm=no
add configuration.country="United States" mode=ap ssid=Guest disabled=no mac-address=1A:FD:74:FE:87:E9 master-interface=wifi2 name=Guest-wifi2 security.authentication-types=wpa2-psk steering.rrm=no wnm=no
/interface wifiwave2 security
add authentication-types=wpa2-psk disabled=no name=common-auth wps=disable
