Дорогие друзья,
На hAP AX3 я хочу ограничить только WPA3 и отключить переходный режим WPA2/WPA3.
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=all .width=20/40/80mhz configuration.country=France .mode=ap .ssid=XXXXXXXXXXXXXXXX disabled=no security.authentication-types=wpa3-psk .disable-pmkid=yes .encryption=ccmp,gcmp,ccmp-256,gcmp-256 .management-protection=required .wps=disable
hAP AX3 определяется как точка доступа с переходным режимом wpa2/wpa3:
sudo iwlist wlp59s0 используется на моём Debian с Intel ax200 и правильным драйвером.
Cell 16 - Address: XXXXXXXXXXXXXXXX
Channel:149 Frequency:5.745 GHz
Quality=32/70 Signal level=-78 dBm
Encryption key:on ESSID:“XXXXXXXXXXXXXXXXXXX”
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=0000003663acf32d
Extra: Last beacon: 128ms ago
IE: Unknown: 000B4F69736561752D3567687A
IE: Unknown: 01088C129824B048606C
IE: Unknown: 030195
IE: Unknown: 07544652202401172801172C01173001173401173801173C011740011764 011E68011E6C011E70011E74011E78011E7C011E80011E84011E88011E8C 011E90011E95010E99010E9D010EA1010EA5010EA9010EAD010E
IE: Unknown: 200100
IE: Unknown: 23020800
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : CCMP
Pairwise Ciphers (4) : CCMP unknown (8) unknown (10) unknown (9)
Authentication Suites (1) : unknown (8)
IE: Unknown: 0B050100030000
IE: Unknown: 460573D000000C
IE: Unknown: 2D1AEF0903FFFF000000000000000000000100000000000000000000
IE: Unknown: 3D1695050400000000000000000000000000000000000000
IE: Unknown: 7F0A04000F00000000400040
IE: Unknown: BF0CB2798933FAFF0000FAFF0000
IE: Unknown: C005019B00FCFF
IE: Unknown: C304021C1C1C
IE: Unknown: FF1C230D01081A4010047048881F418104110800FAFFFAFF391CC7711C07
IE: Unknown: FF0724F43F0008FCFF
IE: Unknown: FF022703
IE: Unknown: FF0E260403A4FF27A4FF4243FF6232FF
IE: Unknown: F40120
IE: Unknown: DD178CFDF00101020100020101030301010004010109020000
IE: Unknown: DD180050F2020101840003A4000027A4000042435E0062322F00
IE: Unknown: DD168CFDF0040000494C51030209720100000000FDFF0000
IE: Unknown: DD078CFDF004010100
Какие правильные настройки, чтобы отключить переходный режим WPA2/WPA3?
Также хочу оставить только AC и AX и отключить всё остальное. Это возможно?
FF
Mode:Master
IE: Unknown: 030195
IE: Unknown: 200100
Group Cipher : CCMP
IE: Unknown: F40120
FF
