    Ошибки CAPsMAN в журнале
    Ошибки CAPsMAN в журнале, RouterOS
    westex
    20.07.2015 20:52:00
    У меня есть 5 RB951Ui-2HnD. Один работает как основной роутер и контроллер CAPsMAN, а четыре — как точками доступа. Некоторое время назад я заметил записи в логе. Вот несколько из них:
    Jul/20/2015 12:59:54 caps,error removing stale connection [::ffff:10.10.2.14:51092,Run,[4C:5E:0C:A6:AC:FF]] because of ident conflict with [::ffff:10.10.2.14:39660,Join,[4C:5E:0C:A6:AC:FF]]
    Jul/20/2015 13:00:42 script,error 10.10.2.12 down
    Jul/20/2015 13:00:50 script,error 10.10.2.12 up
    Jul/20/2015 13:00:57 caps,error removing stale connection [::ffff:10.10.2.14:39660,Run,[4C:5E:0C:A6:AC:FF]] because of ident conflict with [::ffff:10.10.2.14:44498,Join,[4C:5E:0C:A6:AC:FF]]
    Jul/20/2015 13:01:00 caps,error removing stale connection [::ffff:10.10.2.12:42350,Run,[4C:5E:0C:DC:D7:19]] because of ident conflict with [::ffff:10.10.2.12:43156,Join,[4C:5E:0C:DC:D7:19]]
    Jul/20/2015 13:01:41 script,error 10.10.2.12 down
    Jul/20/2015 13:01:49 script,error 10.10.2.12 up
    Jul/20/2015 13:02:00 caps,error removing stale connection [::ffff:10.10.2.12:43156,Run,[4C:5E:0C:DC:D7:19]] because of ident conflict with [::ffff:10.10.2.12:38466,Join,[4C:5E:0C:DC:D7:19]]
    Что означает caps,error removing stale connection [::ffff:10.10.2.14:51092,Run,[4C:5E:0C:A6:AC:FF]] because of ident conflict with [::ffff:10.10.2.14:39660,Join,[4C:5E:0C:A6:AC:FF]]?
    Вот настройки:
    [aadmin@WestaHotel] > caps-man interface print
    Flags: M - master, D - dynamic, B - bound, X - disabled, I - inactive, R - running
    0 MDBR cAP-master                                              D4:CA:6D:DA:76:3F none
    1 MDBR cAP-2L-1                                                4C:5E:0C:A6:AD:28 none
    2 MDBR cAP-2R-1                                                4C:5E:0C:DC:D7:1E none
    3 MDBR cAP-3L-1                                                4C:5E:0C:D7:1C:97 none
    4 MDBR cAP-3R-1                                                4C:5E:0C:A6:AD:04 none
    [aadmin@WestaHotel] > caps-man radio print
    Flags: L - local, P - provisioned
    0  P 4C:5E:0C:D7:1C:97 cAP-3L-1                              [4C:5E:0C:D7:1C:92] cAP-3L
    1  P D4:CA:6D:DA:76:3F cAP-main-1                            [D4:CA:6D:DA:76:3A] cAP-main
    2  P 4C:5E:0C:A6:AD:28 cAP-2L-1                              [4C:5E:0C:A6:AD:23] cAP-2L
    3  P 4C:5E:0C:A6:AD:04 cAP-3R-1                              [4C:5E:0C:A6:AC:FF] cAP-3R
    4  P 4C:5E:0C:DC:D7:1E cAP-2R-1                              [4C:5E:0C:DC:D7:19] cAP-2R
    [aadmin@WestaHotel] > caps-man remote-cap print
    # ADDRESS        NAME                         STATE                             RADIOS
    0 10.10.2.13/36877                                                             [4C:5E:0C:D7:1C:92] Run 1
    1 10.10.99.1/50406                                                             [D4:CA:6D:DA:76:3A] Run 1
    2 10.10.2.11/32919                                                             [4C:5E:0C:A6:AD:23] Run 1
    3 10.10.2.14/44498                                                             [4C:5E:0C:A6:AC:FF] Run 1
    4 10.10.2.12/38466                                                             [4C:5E:0C:DC:D7:19] Run 1
    Кто-нибудь, пожалуйста, помогите!
    P.S. В логе “script,error 10.10.2.12 down and up” — это скрипт для пинга точек доступа.
    Caci99
    11.12.2018 19:56:00
    Сегодня тоже столкнулся с одной странной проблемой. Пытался добавить в Capsman, который работает на RB2011UiAS-2HnD, его собственный беспроводной интерфейс. Создал мост с интерфейсами от eth2 до eth10. Причина, по которой в логах появляется «removing stale connection…», в том, что Cap отключается и переподключается, из-за чего Capsman видит дубликат записи и удаляет её. После того как перепробовал разные настройки моста без результата, в итоге решил проблему, указав в качестве discovery interface для Cap один из активных ethernet-интерфейсов, входящих в мост, а не сам мост:
    /interface wireless cap> print
    enabled: yes
    interfaces: wlan1
    certificate: none
    lock-to-caps-man: no
    discovery-interfaces: ether3
    caps-man-addresses:
    caps-man-names:
    caps-man-certificate-common-names:
    bridge: none
    static-virtual: no
    spaxton
    30.04.2019 21:16:00
    Для всех, кто с этим сталкивался… Прежде всего, обратите внимание на правила брандмауэра. Если у вас внизу списка правил стоит блокировка всего, что не разрешено в какой-то из предыдущих правил, то нужно добавить правило, которое разрешит входящий UDP на порты 5246 и 5247. Если беспроводные интерфейсы находятся на том же роутере, где установлен CAPsMAN, то добавьте правило, разрешающее входящий трафик с исходным адресом самого роутера. Вот как я это делаю. Всего доброго.
    l0ft13
    06.06.2022 12:49:00
    Сегодня у меня была такая же ошибка в версии 6.49.6. CAPSMAN работает на том же устройстве, что и интерфейсы. Проблему решил, указав caps-man-addresses=192.168.199.1 (IP адрес системы).
    dvaai
    02.10.2022 08:11:00
    Добрый день всем, я обнаружил, что интерфейс discovery был настроен неправильно, поэтому я сменил его на нужный мне интерфейс «WAN», и ошибка исчезла. Думаю, эта информация может вам помочь. С уважением, Итан Дэвидс
    KoolDee
    20.01.2023 11:07:00
    Всем привет. У меня на центральном роутере на работе возникла такая проблема, которую я заметил в логах. Но эта проблема касалась не всех точек доступа, а только последней, к которой я подключался (следующая всегда замещала её, и проблемы начинались снова). Придя к выводу, что дело в топологии, я вспомнил про пункт STP в настройках моста. Я поставил параметр «none» на всех точках доступа, и проблема исчезла. Но стоит отметить, что я использую роутеры Mikrotik одновременно и как управляемые коммутаторы, и как точки доступа, так что у вас может быть своя причина потери связи.
    anuser
    14.12.2017 11:05:00
    Итак, сегодня у меня было то же самое. Например: «удаление устаревшего соединения [::ffff:10.2.30.120:54023,Run[64:D1:54:87:E4:6F]] из-за конфликта идентификаторов с [::ffff:10.2.30.120:38611,Join[64:D1:54:87:E4:6F]]». Это происходило со всеми моими WAP/HAP устройствами, подключёнными к настройке с CAPSMAN на базе CHR/VMware. У меня стоит версия 6.40.5. На контроллере CAPSMAN таких правил нет, то есть соединение между CAPSMAN и точками доступа идеальное (около 1 мс). Кто-то сталкивался с этой проблемой и смог её решить?
    Vladkarok
    11.10.2017 10:49:00
    У меня была такая проблема с новым встроенным файрволом в версии v6.40.3. Есть правило: 6    ;;; defconf: заблокировать всё, что не из LAN цепочка=input действие=drop in-interface-list=!LAN. Поскольку динамический интерфейс CAPsMAN новый и его нет в списке интерфейсов «LAN», это правило блокирует связь между CAPs.
    pukkita
    11.10.2017 12:00:00
    Измени логику: chain=input action=drop in-interface-list=WAN
    tomaspi
    13.08.2015 12:14:00
    Привет! Сегодня у меня была такая же ошибка. Я настраивал rb951ui как CAPsMAN, а его внутренний WLAN-интерфейс — как CAP. Проблема оказалась в фаерволе — нужно было правильно пропустить UDP-трафик. Знаю, ситуация чуть другая, но, возможно, стоит проверить это (если ты ещё не нашёл решение).
    OnixJonix
    12.04.2017 08:36:00
    То же самое у меня! Не могу найти причину! Мои CAPS постоянно отключаются и подключаются!! Не могу понять, что значит запись в логе!! Команда Mikrotik, что означает этот лог??? Что это может вызывать???
    drpater
    16.05.2017 09:33:00
    Возможные причины: плохое сетевое соединение между capsman и caps, высокая загрузка процессора у capsman.
