    Проблема с дрожанием NV2 (потеря 1%)
    Проблема с дрожанием NV2 (потеря 1%), RouterOS
    vladimirslk
    01.01.2012 20:11:00
    2x 433AH по обеим сторонам, 52hN MIMO 2x2 + 2 антенны 28dbi V+H по обеим сторонам, около 1 км, конфигурация одинаковая по обеим сторонам
    mode=station-wds
    country=no_country_set
    antenna-gain=0
    frequency=5200
    band=5ghz-onlyn
    channel-width=20/40mhz-ht-above
    scan-list=default
    wireless-protocol=nv2-nstreme
    rate-set=default
    supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
    supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
    basic-rates-b=1Mbps
    basic-rates-a/g=6Mbps
    max-station-count=2007
    distance=dynamic
    tx-power-mode=default
    noise-floor-threshold=default
    nv2-noise-floor-offset=default
    periodic-calibration=default
    periodic-calibration-interval=60
    dfs-mode=none
    wds-mode=dynamic
    wds-default-bridge=RM-televork
    wds-default-cost=100
    wds-cost-range=50-150
    wds-ignore-ssid=no
    update-stats-interval=disabled
    bridge-mode=enabled
    default-authentication=yes
    default-forwarding=yes
    default-ap-tx-limit=0
    default-client-tx-limit=0
    proprietary-extensions=post-2.9.25
    wmm-support=disabled
    hide-ssid=no
    security-profile=uplink
    disconnect-timeout=3s
    on-fail-retry-time=100ms
    preamble-mode=both
    compression=no
    allow-sharedkey=no
    station-bridge-clone-mac=00:00:00:00:00:00
    ht-ampdu-priorities=0,1,2,3,4,5,6,7
    ht-guard-interval=any
    ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15
    ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
    ht-txchains=0,1
    ht-rxchains=0,1
    ht-amsdu-limit=8192
    ht-amsdu-threshold=8192
    tdma-period-size=2
    nv2-queue-count=2
    nv2-qos=default
    nv2-cell-radius=30
    nv2-security=disabled
    nv2-preshared-key=“”
    hw-retries=8
    frame-lifetime=0
    adaptive-noise-immunity=none
    hw-fragmentation-threshold=disabled
    hw-protection-mode=none
    hw-protection-threshold=0
    frequency-offset=-2200
    rate-selection=legacy
    статус: подключено к ess
    диапазон: 5ghz-n
    частота: 5200MHz
    wireless-protocol: nv2
    tx-rate: 300.0Mbps
    rx-rate: 300.0Mbps
    ssid:
    bssid: 00:21:A4:35:00:E6
    radio-name: 0021A43500E6
    уровень сигнала: -32dBm
    уровень сигнала ch0: -33dBm
    уровень сигнала ch1: -46dBm
    уровень сигнала передачи: -20dBm
    уровень сигнала передачи ch0: -24dBm
    уровень сигнала передачи ch1: -26dBm
    noise-floor: -108dBm
    отношение сигнал/шум: 76dB
    tx-ccq: 95%
    rx-ccq: 99%
    аутентифицированных клиентов: 1
    текущее расстояние: 1 км
    wds-link: да
    bridge: нет
    Иногда джиттер прыгает от 100 до 800 мс, примерно с интервалом в минуту. Что ещё можно подстроить для P2P-связи?
    P.S. По поводу уровней мощности: при низких уровнях соединение на 300/300 не устанавливается. Допустим, -45–55 (мощность установлена на 5) сейчас стоит по умолчанию (карточные настройки скорости).
    0ldman
    27.02.2012 04:28:00
    -20 и -30 — это перегрузка приёмника. Он начнёт терять пакеты. Если при уровне сигнала -50 не удаётся получить 300/300, значит канал не чистый, и это, скорее всего, тоже влияет на потерю пакетов.
    KillerOPS
    21.01.2012 18:35:00
    Попробуй использовать MPLS вместо WDS, а если не сработает — отключи одну антенну.
    vladimirslk
    24.01.2012 20:16:00
    Я забил на это, просто установил оптику в марте/апреле, уменьшение мощности даст что-то около 160/120 Мбит/с в ссылке, стабильность на том же уровне. MPLS — это вариант попробовать, но я думаю, что на этой линии это невозможно, она же магистраль для провайдера...
    karina
    26.02.2012 22:26:00
    по моему мнению, тут слишком много мощности и усиления антенны. Пару sxt-ов с головой хватило бы для этой связи на 1 км.
    sup5
    27.02.2012 06:18:00
    используйте station-bridge вместо station-wds отключите все QAM64 HT-MCS и скорости 48/54 Мбит/с используйте адаптивное шумоподавление ищите чистый канал (возможно, диапазон выше 5.7 ГГц)
