Эти настройки на ap/интерфейс беспроводной сети wlan1: имя=“wlan1” mtu=1500 mac-адрес=00:0B:6B:57:12:00 arp=enabled disable-running-check=no radio-name=“000B6B5712A0” mode=bridge ssid=“LINK” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=27 frequency=5805 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=54Mbps max-station-count=2007 ack-timeout=dynamic tx-power=17 tx-power-mode=card-rates noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=no default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no comment=“” disabled=no / интерфейс беспроводной сети nstreme set wlan1 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200 / интерфейс беспроводной сети manual-tx-power-table set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17 ,48Mbps:17,54Mbps:17 / интерфейс беспроводной сети security-profiles set default name=“default” mode=none authentication-types=“” unicast-ciphers=“” group-ciphers=“” wpa-pre-shared-key=“” wpa2-pre-shared-key=“” eap-methods=passthrough tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0=“” static-algo-1=none static-key-1=“” static-algo-2=none static-key-2=“” static-algo-3=none static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key=“” radius-mac-authentication=no group-key-update=5m / интерфейс беспроводной сети align set frame-size=300 active-mode=yes receive-all=no audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no frames-per-second=25 audio-min=-100 audio-max=-20 / интерфейс беспроводной сети access-list add mac-address=00:0B:6B:57:11:16 interface=wlan1 authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0 private-algo=none private-key=“” comment=“” disabled=no / интерфейс беспроводной сети snooper set multiple-channels=yes channel-time=200ms receive-errors=no / интерфейс беспроводной сети sniffer set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no memory-limit=10 file-name=“” file-limit=10 streaming-enabled=no streaming-server=0.0.0.0 streaming-max-rate=0
