    MT RB L2TP клиент и Cisco L2TP сервер?
    MT RB L2TP клиент и Cisco L2TP сервер?, RouterOS
    mikrotrick
    02.08.2006 15:28:00
    Привет всем! Я пытаюсь настроить l2t между MT RB (v2.9.26) [l2tp client] и Cisco 38xx [l2tp server]. Настройка клиента кажется довольно простой (не так много параметров), но с Cisco выходит какая-то канитель. Не найдется ли у кого-нибудь простые строки конфигурации Cisco (части vpdn-group и virtual-template)? Заранее спасибо.
    Eugene
    02.08.2006 15:48:00
    **Client**
    версия 12.3
    service timestamps debug datetime msec
    service timestamps log datetime msec
    no service password-encryption
    hostname Router1
    boot-start-marker
    boot-end-marker
    enable secret 5 $1$HwpA$2eNLsT/iZwHySc9SVtBXF1
    no aaa new-model
    ip subnet-zero
    ip cef
    no ftp-server write-enable
    interface Ethernet0/0
    ip address 1.1.1.21 255.255.255.0
    half-duplex
    pppoe enable
    pppoe-client dial-pool-number 1
    interface Serial0/0
    no ip address
    shutdown
    interface Ethernet0/1
    no ip address
    shutdown
    half-duplex
    interface Dialer1
    mtu 1492
    ip address negotiated
    encapsulation ppp
    dialer pool 1
    dialer-group 1
    ppp authentication pap callin
    ppp pap sent-username pppoe@example.com password 0 pppoe
    ip classless
    ip http server
    control-plane
    line con 0
    exec-timeout 0 0
    line aux 0
    line vty 0 4
    exec-timeout 0 0
    password enable
    login
    end
    **LAC**
    версия 12.2
    service timestamps debug uptime
    service timestamps log uptime
    hostname Router2
    enable secret 5 $1$kB1F$Vdg/lWkIjhunBs0HhHxjA0
    username LNS password 0 LNS
    ip subnet-zero
    vpdn enable
    vpdn-group 2
    request-dialin
     protocol l2tp
     domain example.com
    initiate-to ip 1.1.1.23
    local name LAC
    l2tp tunnel password 7 022A2578
    vpdn-group pppoe
    accept-dialin
     protocol pppoe
     virtual-template 1
    local name lac
    call rsvp-sync
    interface Loopback0
    ip address 10.0.0.1 255.255.255.0
    ip address 1.1.1.22 255.255.255.0
    half-duplex
    pppoe enable
    interface Serial0/0
    no ip address
    shutdown
    no ip address
    shutdown
    half-duplex
    interface Virtual-Template1
    mtu 1492
    ip unnumbered Loopback0
    no peer default ip address
    ppp authentication pap chap
    ip local pool pppoe 10.0.0.100 10.0.0.200
    ip classless
    ip http server
    dial-peer cor custom
    line con 0
    exec-timeout 0 0
    line aux 0
    line vty 0 4
    exec-timeout 0 0
    password enable
    login
    end
    **LNS**
    версия 12.2
    hostname Router3
    enable secret 5 $1$DlK.$pP97tuKL0k6X9lbMV1//W1
    enable password enable1
    username LAC password 0 LAC
    ip subnet-zero
    frame-relay switching
    vpdn enable
    vpdn-group 1
    accept-dialin
     protocol l2tp
     virtual-template 1
    terminate-from hostname LAC
    local name LNS
    lcp renegotiation on-mismatch
    l2tp tunnel password 7 062A2112
    call rsvp-sync
    interface Loopback0
    ip address 10.1.0.1 255.255.255.0
    ip address 1.1.1.23 255.255.255.0
    no ip mroute-cache
    half-duplex
    interface Serial0/0
    no ip address
    encapsulation frame-relay IETF
    no ip mroute-cache
    no fair-queue
    no arp frame-relay
    no frame-relay inverse-arp
    frame-relay lmi-type ansi
    frame-relay intf-type dce
    interface Serial0/0.1 point-to-point
    ip address 2.2.2.2 255.255.255.0
    no ip mroute-cache
    no arp frame-relay
    frame-relay interface-dlci 42
    no ip address
    no ip mroute-cache
    shutdown
    half-duplex
    ip mtu 1492
    peer default ip address pool example
    ip local pool example 10.1.0.100 10.1.0.200
    ip classless
    ip route 2.2.2.0 255.255.255.0 Serial0/0.1
    ip http server
    line con 0
    exec-timeout 0 0
    line aux 0
    line vty 0 4
    exec-timeout 0 0
    password enable
    login
    end
    mikrotrick
    03.08.2006 13:12:00
    Привет, Женя, спасибо, но если использовать эту конфигурацию LNS на Cisco и l2tp-клиенте на RB, не получится. Причина в проблеме с авторизацией туннеля. Кстати, PPTP работает отлично с этой конфигурацией (protocol any в vpdn-group). Кто-нибудь использует Cisco и RB с l2tp?
    Eugene
    04.08.2006 07:02:00
    Тебе нужно добавить что-то вроде: no l2tp tunnel authentication Eugene
