Спасибо за информацию! Вот 2 карты работают на 5.8ГГц (cm9 и sr5), и ещё одна на 2.4ГГц (senao). 4 точки доступа:
R name=“accesspoint-city-5ghz” mtu=1500 mac-address=00:01:B4:02:0B:1A arp=enabled disable-running-check=no interface-type=Atheros AR5213 radio-name=“accesspoint-city-5ghz” mode=ap-bridge ssid=“mag1” area=“” frequency-mode=regulatory-domain country=new zealand antenna-gain=0 frequency=5220 band=5ghz scan-list=default rate-set=default supported-rates-a/g=6Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power=26 tx-power-mode=all-rates-fixed noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=pppoe wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=WPA new disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
R name=“accesspoint-lyttelton-5ghz” mtu=1500 mac-address=00:0B:6B:36:14:21 arp=enabled disable-running-check=no interface-type=Atheros AR5213 radio-name=“gondola-ma2” mode=ap-bridge ssid=“mag2” area=“” frequency-mode=regulatory-domain country=new zealand antenna-gain=0 frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power=26 tx-power-mode=all-rates-fixed noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=WPA new disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
R name=“accesspoint-lyttelton1” mtu=1500 mac-address=00:02:6F:35:5B:D0 arp=enabled disable-running-check=no interface-type=Prism prism-cardtype=200mW radio-name=“accesspoint-lyttelton1” mode=ap-bridge ssid=“WirelessWebLyttelton” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=2412 band=2.4ghz-b scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps basic-rates-b=1Mbps max-station-count=2007 tx-power-mode=default periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=pre-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms compression=no allow-sharedkey=no
R name=“accesspoint-city4” mtu=1500 mac-address=00:02:6F:35:5D:A3 arp=enabled disable-running-check=no interface-type=Prism prism-cardtype=200mW radio-name=“WirelessWebCity4 radio” mode=ap-bridge ssid=“WirelessWebCity4” area=“” frequency-mode=manual-txpower country=japan1 antenna-gain=0 frequency=2467 band=2.4ghz-b scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps basic-rates-b=1Mbps max-station-count=2007 tx-power-mode=default periodic-calibration=default periodic-calibration-interval=60 dfs-mode=none antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=brents wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=pre-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms compression=no allow-sharedkey=no
X name=“spare-bb-from-gondola” mtu=1500 mac-address=00:01:B4:02:06:C0 arp=enabled disable-running-check=no interface-type=Atheros AR5213 radio-name=“bb-from-gondola” mode=ap-bridge ssid=“bb-from-gondola” area=“” frequency-mode=regulatory-domain country=no_country_set antenna-gain=0 frequency=5300 band=5ghz scan-list=default rate-set=configured supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power=23 tx-power-mode=all-rates-fixed noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=brents wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=pre-2.9.25 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
Похоже, что это не проблема с беспроводной сетью, так как она работает стабильно: PPPoE отключается, а беспроводное соединение остается активным с хорошим сигналом и пингами. После примерно 6-10 минут происходит сброс PPPoE.
