    Проблемы с OSPF (2 RouterOS и 1 Cisco 3640).
    Проблемы с OSPF (2 RouterOS и 1 Cisco 3640)., RouterOS
    ericsooter
    17.08.2006 13:29:00
    У меня небольшая OSPF backbone-сеть из трех роутеров. Довольно базовая настройка, без использования зон. Вот конфигурация:
    Router 1 (Cisco 3640)
    В NOC:
    200.41.124.1/24 ← Ethernet
    10.24.32.9/30 ← ATM Sub-interface
    Router 2 (RB532 с 2.27)
    На DSL-местоположении
    Недавно заменил на Cisco 2600 / маршрутизация OSPF
    set router-id=200.41.124.1
    distribute-default=never
    redistribute-connected=no
    redistribute-static=as-type-1
    redistribute-rip=no
    redistribute-bgp=no
    metric-default=1
    metric-connected=20
    metric-static=20
    metric-rip=20
    metric-bgp=20
    / routing ospf area set
    backbone
    area-id=0.0.0.0
    type=default
    translator-role=translate-candidate
    authentication=none
    prefix-list-import=“”
    prefix-list-export=“”
    disabled=no
    / routing ospf interface set
    FIXME interface=ether1 cost=10 priority=1 authentication-key=“” network-type=broadcast retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s
    set FIXME interface=ether2 cost=10 priority=1 authentication-key=“” network-type=broadcast retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s
    set FIXME interface=ether3 cost=10 priority=1 authentication-key=“” network-type=broadcast retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s
    / routing ospf network add
    network=10.24.32.8/30 area=backbone disabled=no
    add network=100.168.65.0/24 area=backbone disabled=no
    add network=200.41.124.0/24 area=backbone disabled=no
    Router 3 (RB532 с 2.27)
    На Tower Location
    / routing ospf set
    router-id=100.168.65.1
    redistribute-static=no
    redistribute-rip=no
    redistribute-bgp=no
    metric-default=1
    metric-connected=20
    metric-static=20
    metric-rip=20
    metric-bgp=20
    backbone
    area-id=0.0.0.0
    type=default
    authentication=none
    disabled=no
    FIXME interface=ether2 cost=1 priority=1 authentication-key=“” network-type=broadcast retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s
    set FIXME interface=ether1 cost=1 priority=1 authentication-key=“” network-type=broadcast retransmit-interval=5s transmit-delay=1s hello-interval=10s dead-interval=40s
    add network=200.41.125.0/24 area=backbone disabled=no
    Связь 1-2: 3МБ DSL-канал (работает хорошо)
    Связь 1-3: ptp 802.11b wifi соединение с хорошей пропускной способностью
    Связь 2-3: Очень слабая wifi-связь. Около 700кб-1мб со сбросами пакетов (использовать только если что-то не работает).
    Когда Router 2 был Cisco, все работало отлично. Все связи сходились в любой ситуации. Но с тех пор как я заменил Cisco на RB532, у меня начались проблемы между связями 2 и 3, которая и так не самая надежная; но она хоть что-то поддерживает. На роутере 2 связи постоянно возвратно-вперед переключаются между направлениями. Состояние канала меняется примерно 10 раз в минуту.  Похоже, проблема между двумя RB.
    Уверен, что в моей конфигурации есть проблемы. Кто-нибудь замечает что-нибудь?
    Эрик
