Помогите, пожалуйста, срочно настроить Nstreme-Dual. У меня 2 RB500 с 2 AR5413 на каждой плате RB500. Я очень строго следовал документации, настраивал Nstreme-Dual шаг за шагом. Конфигурация следующая:
Плата 1: admin@MikroTik] interface wireless>
name=“wlan1” mtu =1500 mac-address=00:11:F5:60:0B:EB arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=“0011F5600BEB” mode=nstreme-dual-slave ssid=“MikroTik” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
1
name=“wlan2” mtu=1500 mac-address=00:11:F5:60:0C:A5 arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=“0011F5600CA5” mode=nstreme-dual-slave ssid=“MikroTik” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
Конфигурация Nstreme-Dual для платы 1:
Flags: X - отключено, R - работает
0 R name=“nstreme1” mtu=1500 mac-address=00:11:F5:60:0C:A5 arp=enabled disable-running-check=no tx-radio=wlan1 rx-radio=wlan2 remote-mac=00:11:F5:60:0A:6D tx-band=5ghz tx-frequency=5180 rx-band=5ghz rx-frequency=5320 rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps framer-policy=exact-size framer-limit=2560
Плата 2: admin@MikroTik] interface wireless>
name=“wlan1” mtu =1500 mac-address=00:11:F5:60:0A:79 arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=“0011F5600BEB” mode=nstreme-dual-slave ssid=“MikroTik” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
1
name=“wlan2” mtu=1500 mac-address=00:11:F5:60:0A:6D arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=“0011F5600CA5” mode=nstreme-dual-slave ssid=“MikroTik” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
Конфигурация Nstreme-Dual для платы 2:
0 R name=“nstreme1” mtu=1500 mac-address=00:11:F5:60:0A:6D arp=enabled disable-running-check=no tx-radio=wlan1 rx-radio=wlan2 remote-mac=00:11:F5:60:0C:A5 tx-band=5ghz tx-frequency=5180 rx-band=5ghz rx-frequency=5320 rates-b=1Mbps ,2Mbps,5.5Mbps,11Mbps rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps framer-policy=exact-size framer-limit=2560
Но при мониторинге интерфейса Nstreme-Dual на любой плате получаю следующее:
eme-dual> monitor
0 rx-signal-strength: -95dBm tx-signal-strength: -95dBm rx-rate: 1Mbps tx-rate: 6Mbps connected: no
Я перепробовал разные Atheros карты, AR5213, но результат тот же!!! Помогите, пожалуйста, не вижу, где допустил ошибку, и очень переживаю из-за этого, так как это моя первая попытка настроить Nstreme2, и мне нужно настроить соединение к среде в среду на этой неделе!!!
1
1
eme-dual> monitor
