    Проблема с балансировкой нагрузки.
    Проблема с балансировкой нагрузки., RouterOS
    logg
    16.01.2014 10:41:00
    Привет, неделю назад купил RB 751U-2HnD, нужно настроить его для балансировки нагрузки между двумя ADSL. У меня такая конфигурация:
    `/ip firewall nat`
    0 X ;;; Load Balancing | НЕ ТРОГАТЬ |
        chain=srcnat action=masquerade out-interface=Wireless
    1   chain=srcnat action=masquerade out-interface=WAN2
    2   chain=srcnat action=masquerade to-addresses=0.0.0.0 out-interface=WAN3
    `/ip firewall mangle`
    0   chain=prerouting action=accept dst-address=192.168.2.0/24 in-interface=Local
    1   chain=prerouting action=accept dst-address=192.168.2.0/24
    2   chain=prerouting action=accept dst-address=192.168.3.0/24 in-interface=Local
    3   chain=prerouting action=accept dst-address=192.168.3.0/24
    4   chain=prerouting action=mark-connection new-connection-mark=WAN2_conn passthrough=yes dst-address-type=!local in-interface=Local
        per-connection-classifier=both-addresses-and-ports:2/0
    5   chain=prerouting action=mark-connection new-connection-mark=WAN3_conn passthrough=yes dst-address-type=!local in-interface=Local
        per-connection-classifier=both-addresses-and-ports:2/1
    6   chain=prerouting action=mark-routing new-routing-mark=to_WAN3 passthrough=yes in-interface=Local connection-mark=WAN3_conn
    7   chain=input action=mark-connection new-connection-mark=WAN2_conn passthrough=yes in-interface=WAN2
    8   chain=input action=mark-connection new-connection-mark=WAN3_conn passthrough=yes in-interface=WAN3
    9   chain=prerouting action=mark-routing new-routing-mark=to_WAN2 passthrough=yes in-interface=Local connection-mark=WAN2_conn
    10   chain=output action=mark-routing new-routing-mark=to_WAN2 passthrough=yes connection-mark=WAN2_conn
    11   chain=output action=mark-routing new-routing-mark=to_WAN3 passthrough=yes connection-mark=WAN3_conn
    `/ip route`
    0 A S  0.0.0.0/0                          192.168.2.1               1
    1 A S  0.0.0.0/0                          192.168.3.1               1
    2 X S  0.0.0.0/0                          192.168.1.1               1
    3 A S  0.0.0.0/0                          192.168.3.1               1
    4   S  0.0.0.0/0                          192.168.2.1               2
    5 X S  0.0.0.0/0                          192.168.1.1               1
    6 ADC  192.168.2.0/24     192.168.2.124   WAN2                      0
    7 ADC  192.168.3.0/24     192.168.3.125   WAN3                      0
    8 ADC  192.168.100.0/24   192.168.100.1   Local                     0
    У меня есть некоторые проблемы:
    *   Трафик не балансируется равномерно по двум соединениям: в WAN2 я вижу 10 ГБ трафика, а в WAN3 только 400 МБ.
    *   Когда я пытаюсь открыть страницу, она загружается очень медленно, как будто балансировка нагрузки теряет время на установление соединения: когда запрос идет через какой-то из каналов. Например, когда я захожу на сайт Mikrotik, на это уходит 10 секунд, а когда я на самом Mikrotik, скорость намного выше.
    *   Не получается нормально настроить переадресацию портов для моего DVR. Иногда соединение устанавливается, иногда нет.  Вот правило для этого:
    7   chain=dstnat action=dst-nat to-addresses=192.168.100.6 to-ports=1025 protocol=tcp in-interface=!Local dst-port=1025
    8   chain=dstnat action=dst-nat to-addresses=192.168.100.6 to-ports=9001 protocol=tcp in-interface=!Local dst-port=9001
    Может кто-нибудь помочь, пожалуйста. Заранее спасибо.
    karina
    17.01.2014 15:20:00
    Прежде чем что-либо делать, эти правила SRc NAT настроены неправильно. Первое (1) в порядке, там меняется source NAT на 0.0.0.0, должно быть masquerade.
    logg
    19.01.2014 11:29:00
    Спасибо за ответ, не могли бы вы рассказать об этом подробнее, пожалуйста?
    deejayq
    20.01.2014 14:49:00
    Твои правила какие-то перепутались, попробуй пример вот здесь: http://wiki.mikrotik.com/wiki/Manual:PCC
