		<title>Mikrotik.moscow [тема: Помогите, пожалуйста, с гостевой Wi-Fi.]</title>
		<description>Новое в теме Помогите, пожалуйста, с гостевой Wi-Fi. форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Mon, 02 Nov 2026 07:25:01 -0500</pubDate>
			<title>Помогите, пожалуйста, с гостевой Wi-Fi.</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419645">Помогите, пожалуйста, с гостевой Wi-Fi.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Да, вот она:<br />/interface bridge port &nbsp;<br />add bridge=bridge interface=wifi-5ghz &nbsp;<br /><br />/interface bridge vlan &nbsp;<br />add bridge=bridge tagged=bridge,wifi-5ghz-guest vlan-ids=10 &nbsp;<br />add bridge=bridge tagged=bridge,wifi-5ghz vlan-ids=100 &nbsp;<br />add bridge=bridge tagged=bridge vlan-ids=50 &nbsp;<br /><br />/interface vlan &nbsp;<br />add arp=reply-only interface=bridge name=guest vlan-id=10 &nbsp;<br />add arp=reply-only interface=bridge name=iot vlan-id=50 &nbsp;<br />add interface=bridge name=lan vlan-id=100 &nbsp;<br /><br />/ip dhcp-server &nbsp;<br />add add-arp=yes address-pool=lan interface=lan name=lan &nbsp;<br />add add-arp=yes address-pool=guest interface=guest name=guest &nbsp;<br />add add-arp=yes address-pool=iot interface=iot name=iot &nbsp;<br /><br />/ip dhcp-server network &nbsp;<br />add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1 &nbsp;<br />add address=192.168.50.0/24 dns-server=8.8.8.8 gateway=192.168.50.1 &nbsp;<br />add address=192.168.100.0/24 dns-server=192.168.100.1 gateway=192.168.100.1 &nbsp;<br /><br />/ip address &nbsp;<br />add address=192.168.100.1/24 interface=lan network=192.168.100.0 &nbsp;<br />add address=192.168.10.1/24 interface=guest network=192.168.10.0 &nbsp;<br />add address=192.168.50.1/24 interface=iot network=192.168.50.0 &nbsp;<br /><br />/interface wifi datapath &nbsp;<br />add bridge=bridge disabled=no name=home-private-datapath vlan-id=100 &nbsp;<br />add bridge=bridge disabled=no name=home-guest-datapath vlan-id=10 &nbsp;<br />add bridge=bridge disabled=no name=iot-datapath vlan-id=50 &nbsp;<br /><br />/interface bridge &nbsp;<br />add frame-types=admit-only-vlan-tagged name=bridge vlan-filtering=yes &nbsp;<br />// возможно, вам не понадобится только vlan-tagged, если в мосту будет идти нетегированный трафик &nbsp;<br />В общем, скорее всего, не нужно вручную добавлять порты моста и настраивать беспроводной интерфейс как tagged, просто выставьте тегирование для нужных VLAN на мосту, остальное сделает datapath за вас. Эта конфигурация отлично работает у меня на ax3. Не забудьте настроить фаервол так, чтобы VLAN’ы имели доступ в интернет, но при этом не могли обращаться друг к другу. <br />
			<i>30.09.2024 11:38:00, kleshki.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419645</link>
			<guid>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419645</guid>
			<pubDate>Mon, 30 Sep 2024 11:38:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419644">Помогите, пожалуйста, с гостевой Wi-Fi.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Я хотел бы настроить это с VLAN, но перепробовал много вариантов и без успеха. Можете выложить простой скрипт для тестирования? Всем спасибо. Люблю MT и сообщество MT. <br />
			<i>30.09.2024 11:31:00, juanvi.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419644</link>
			<guid>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419644</guid>
			<pubDate>Mon, 30 Sep 2024 11:31:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419643">Помогите, пожалуйста, с гостевой Wi-Fi.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			В этой настройке практически нет конфигурации, связанной с VLAN. Фильтр моста, два интерфейса, перенос IP с моста на LAN VLAN, соответствующий datapath для каждого WLAN. А дальше то, что ты сказал: firewall и так далее. Твоё решение тоже работает, отлично. Просто моё мнение, что это должно быть настроено именно так. <br />
			<i>24.09.2024 20:22:00, kleshki.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419643</link>
			<guid>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419643</guid>
			<pubDate>Tue, 24 Sep 2024 20:22:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419642">Помогите, пожалуйста, с гостевой Wi-Fi.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Для такой простой настройки, на мой взгляд, VLANы — сущий пустяк. Достаточно будет правильно настроить правила файрвола и назначить интерфейс wlan1 в мост для использования с DHCP, чтобы не светилось красным. <br />
			<i>24.09.2024 20:18:00, TheCat12.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419642</link>
			<guid>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419642</guid>
			<pubDate>Tue, 24 Sep 2024 20:18:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419641">Помогите, пожалуйста, с гостевой Wi-Fi.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Реализуйте отдельные VLAN для LAN и гостевой сети и назначьте DHCP-серверы для каждой VLAN. Соответственно настройте файрвол. Это решит ваши проблемы, в том числе с красным DHCP (он красный, потому что интерфейс WLAN считается отключённым, пока не подключится хотя бы один клиент, и DHCP на отключённом интерфейсе действительно отображается красным). <br />
			<i>24.09.2024 20:14:00, kleshki.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419641</link>
			<guid>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419641</guid>
			<pubDate>Tue, 24 Sep 2024 20:14:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419640">Помогите, пожалуйста, с гостевой Wi-Fi.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Это делается с помощью правил файрвола, конечно: /ip firewall filter &nbsp;<br />add action=accept chain=forward connection-state=established,related,untracked &nbsp;<br />add action=drop chain=forward in-interface=bridge1 out-interface=wlan1 &nbsp;<br />add action=accept chain=forward protocol=tcp dst-port=80,443 in-interface=wlan1 out-interface=bridge1 &nbsp;<br />add action=drop chain=forward in-interface=wlan1 out-interface=bridge1 &nbsp;<br /><br />Второе правило — это исключение для доступа в интернет с интерфейса wlan. <br />
			<i>24.09.2024 20:10:00, TheCat12.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419640</link>
			<guid>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419640</guid>
			<pubDate>Tue, 24 Sep 2024 20:10:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419639">Помогите, пожалуйста, с гостевой Wi-Fi.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Вот решение, которое я нашёл. DHCP-сервер отображается красным, пока какой-нибудь клиент не получит от него IP — почему так, не знаю, но работает нормально:<br /><br />2024-09-23 09:56:57, RouterOS 7.16rc4 &nbsp;<br />software id = JU87-GNM6 &nbsp;<br />model = RBmAP2nD &nbsp;<br />serial number =<br /><br />/interface bridge add name=bridge1 &nbsp;<br />/interface wireless set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=spain disabled=no frequency=auto mode=ap-bridge ssid=Andine-invitados wireless-protocol=802.11 wps-mode=disabled  <br />/interface wireless security-profiles set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik  <br />add authentication-types=wpa2-psk mode=dynamic-keys name=privado supplicant-identity=“” &nbsp;<br />/interface wireless add disabled=no keepalive-frames=disabled mac-address=D6:01:C3:42:E2:08 master-interface=wlan1 multicast-buffering=disabled name=wlan2 security-profile=privado ssid=AND_hall wps-mode=disabled &nbsp;<br />/ip pool add name=dhcp_pool1 ranges=10.20.30.2-10.20.30.254 &nbsp;<br />/ip dhcp-server add address-pool=dhcp_pool1 interface=wlan1 name=dhcp1 &nbsp;<br />/interface bridge port add bridge=bridge1 interface=ether2 &nbsp;<br />add bridge=bridge1 interface=ether1 &nbsp;<br />add bridge=bridge1 interface=wlan2 &nbsp;<br />/ip address add address=10.20.30.1/24 interface=wlan1 network=10.20.30.0 &nbsp;<br />/ip dhcp-client add interface=bridge1 &nbsp;<br />/ip dhcp-server network add address=10.20.30.0/24 dns-server=10.20.30.1 gateway=10.20.30.1 &nbsp;<br />/ip dns set allow-remote-requests=yes &nbsp;<br />/ip firewall nat add action=masquerade chain=srcnat src-address=10.20.30.0/24 &nbsp;<br />/ip hotspot profile set [ find default=yes ] html-directory=hotspot  <br />/ip ipsec profile set [ find default=yes ] dpd-interval=2m dpd-maximum-failures=5  <br />/system clock set time-zone-name=Europe/Madrid &nbsp;<br />/system identity set name=Recepcion &nbsp;<br />/system note set show-at-login=no<br /><br />Понятно, что сейчас хорошей практикой считается изолировать основной мост от гостевой беспроводной сети. Можешь скинуть примеры? Спасибо заранее. <br />
			<i>23.09.2024 08:35:00, juanvi.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419639</link>
			<guid>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419639</guid>
			<pubDate>Mon, 23 Sep 2024 08:35:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419638">Помогите, пожалуйста, с гостевой Wi-Fi.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Привет! У меня не получается настроить гостевую WLAN в такой ситуации. Надеюсь, тут мне помогут. У меня есть LAN 192.168.8.0/24. Я подключил mAP, настроенный как полный мост в этом LAN (eth1), так что у меня свободен порт, как и раньше (сейчас eth2) для ПК и беспроводной точки доступа для подключения беспроводного принтера в этом месте. DHCP-сервер уже работает в этом LAN, всё в одном мосту. Я хочу настроить гостевую (изолированную) точку доступа на этом mAP, но сталкиваюсь с кучей проблем: не получается запустить DHCP на подчинённых интерфейсах, фильтрация мостов (как quickset) не работает, если mAP полностью в мосту, попытки с VLAN не дают доступа к WAN… Может, кто-нибудь приведёт пример на ROS 7.15? Заранее спасибо! <br />
			<i>06.09.2024 07:26:00, juanvi.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419638</link>
			<guid>http://mikrotik.moscow/forum/forum57/87713-pomogite_-pozhaluysta_-s-gostevoy-wi_fi./message419638</guid>
			<pubDate>Fri, 06 Sep 2024 07:26:00 -0400</pubDate>
