		<title>Mikrotik.moscow [тема: Нужна помощь с мониторингом батареи UPS для Routerboards.]</title>
		<description>Новое в теме Нужна помощь с мониторингом батареи UPS для Routerboards. форума Аппаратное обеспечение на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Fri, 07 Aug 2026 17:38:36 -0400</pubDate>
			<title>Нужна помощь с мониторингом батареи UPS для Routerboards.</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294472">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Hey! 👋<br /><br />Just wanted to share this crazy experience I had yesterday. I was trying to debug a particularly nasty piece of code, you know, the kind that makes you question all your life choices. 😅 After hours of staring at the screen and feeling like I was banging my head against a wall, I finally found the issue. It was a single semicolon that was completely out of place! 🤦‍♀️<br /><br />Seriously, a semicolon. <br /><br />I’ve been coding for 10 years, and I still fall for this. It's humbling, to say the least. 😂<br /><br />Here’s a breakdown of what happened:<br /><br />* &nbsp; **Initial State:** Code was throwing a "syntax error" - vague and unhelpful, as always.<br />* &nbsp; **Debugging Process:** Tried everything from stepping through the code to using the debugger. Nothing.<br />* &nbsp; **The Moment of Truth:** I decided to read the code *really* slowly, line by line. And there it was... that rogue semicolon.<br />* &nbsp; **Resolution:** Removed the semicolon, ran the code, and it worked perfectly. 🎉<br /><br />Moral of the story: always double-check your semicolons (and maybe take a break when you're feeling frustrated). 🧘‍♀️<br /><br />You can find more about debugging tips on my blog: [<noindex><a href="https://www.example.com/debugging-tips%5D(&lt;#0" target="_blank" rel="nofollow" >https://www.example.com/debugging-tips](&lt;#0</a></noindex>  >)<br /><br />#debugging #codinglife #programmerproblems #semicolons #coding #softwaredevelopment<br /><br />P.S. Still questioning my life choices, but at least the code works now. 😉 <br />
			<i>21.10.2009 18:30:00, matrot2.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294472</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294472</guid>
			<pubDate>Wed, 21 Oct 2009 18:30:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294471">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Удаленный мониторинг ИБП-MT-12 в реальном времени. <noindex><a href="http://tandem.ck.ua/soft_apps.php" target="_blank" rel="nofollow" >http://tandem.ck.ua/soft_apps.php</a></noindex> <br />
			<i>20.08.2009 19:16:00, matrot2.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294471</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294471</guid>
			<pubDate>Thu, 20 Aug 2009 19:16:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294470">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			English version: <noindex><a href="http://tandem.ck.ua/ups_mtm-eng.php" target="_blank" rel="nofollow" >http://tandem.ck.ua/ups_mtm-eng.php</a></noindex> <br />
			<i>09.07.2009 17:45:00, matrot2.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294470</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294470</guid>
			<pubDate>Thu, 09 Jul 2009 17:45:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294469">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Простите. Я отдыхал. Завтра дам ответы. <br />
			<i>09.07.2009 15:40:00, matrot2.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294469</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294469</guid>
			<pubDate>Thu, 09 Jul 2009 15:40:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294468">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Тоже самое делал несколько дней назад… все еще жду. <br />
			<i>09.07.2009 02:04:00, QpoX.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294468</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294468</guid>
			<pubDate>Thu, 09 Jul 2009 02:04:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294467">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Только что отправил им письмо, чтобы узнать, отправляют ли они заказы за границу и какие системы денежных переводов принимают. <br />
			<i>09.07.2009 01:58:00, nz_monkey.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294467</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294467</guid>
			<pubDate>Thu, 09 Jul 2009 01:58:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294466">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Переводчик от Google помогает, с русского на английский. Цена составила 240 гривен, что, по курсу XE.com, примерно 30-40 долларов США. Хотелось бы заказать что-нибудь подобное… <br />
			<i>08.07.2009 21:55:00, jp1.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294466</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294466</guid>
			<pubDate>Wed, 08 Jul 2009 21:55:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294465">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Спасибо, Matrot! Я разобрался, как это работает, по картинкам, но было бы здорово получить нормальный перевод на английский, чтобы убедиться, что я всё правильно понял. Как только появится английская версия страницы, я собираюсь заказать несколько комплектов для полевых испытаний. <br />
			<i>07.07.2009 22:16:00, nz_monkey.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294465</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294465</guid>
			<pubDate>Tue, 07 Jul 2009 22:16:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294464">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Английская страница будет 13.07.2009. Сообщу тебе. <br />
			<i>07.07.2009 06:34:00, matrot2.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294464</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294464</guid>
			<pubDate>Tue, 07 Jul 2009 06:34:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294463">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Привет. Я студент-финалиสต์ телекоммуникационного факультета. Пост оказался очень интересным, и я хотел бы узнать о нём больше: как это работает, насколько результаты соответствуют ожиданиям... чтобы включить это в свою диссертацию. Думал подключить ИБП к моему роутерборду, чтобы защитить его от отключения электроэнергии. Спасибо. <br />
			<i>17.06.2008 08:24:00, Aroca.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294463</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294463</guid>
			<pubDate>Tue, 17 Jun 2008 08:24:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294462">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			UPS и UPS-монитор. К сожалению, не моя идея. <noindex><a href="http://local.com.ua/forum/index.php?showtopic=15362" target="_blank" rel="nofollow" >http://local.com.ua/forum/index.php?showtopic=15362</a></noindex> <br />
			<i>06.07.2009 14:11:00, matrot2.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294462</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294462</guid>
			<pubDate>Mon, 06 Jul 2009 14:11:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294461">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Привет, Оди! Я был бы заинтересован в твоем модуле. Напиши мне на aroca@grupoawa.es, и мы обсудим, пожалуйста. С уважением. <br />
			<i>18.06.2008 07:48:00, Aroca.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294461</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294461</guid>
			<pubDate>Wed, 18 Jun 2008 07:48:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294460">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Вау, выглядит как отличный маленький аппарат. К сожалению, я не читаю по-русски. Есть ли английская страница с информацией? С уважением, Эндрю. <br />
			<i>06.07.2009 22:36:00, nz_monkey.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294460</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294460</guid>
			<pubDate>Mon, 06 Jul 2009 22:36:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294459">Нужна помощь с мониторингом батареи UPS для Routerboards.</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Ребята, хоть я и не новичок в MT-ROS (работал с 70 рублями с rosv.3.2 и v3.3), в некоторых вещах я всё ещё как девственник… Как заставить Routerboard сообщить мне (скриптом почты или SMS, это уже решено) о том, что UPS работает от батареи? Как преобразовать современный стандарт USB-кабель, подключенный к UPS, в последовательное соединение с Routerboard? У меня есть несколько USB-to-Serial адаптеров, но они требуют специального драйверного ПО для Windows, чтобы работать на ПК. Но как их использовать на Routerboard? Хорошо, что MT имеет возможность работы с UPS. Но если я читаю форум и руководство, то упоминаются только APC-UPS, с соответствующими схемами проводки для последовательных кабелей. Они одинаковы для других брендов? И для USB? Я без понятия. Здесь, в Европе, APC-USB почти невозможно найти или они стоят в два или три раза дороже, чем другие качественные UPS. (И я не говорю про дешёвый товар из супермаркета!) Единственные UPS с последовательным портом, которые я смог найти здесь, в Испании, были дешёвые модели Belkin, которые сломались у меня уже через полгода или меньше… бесполезные. У меня 8 UPS работают на ПК, а теперь 2 на удалённых Routerboard в удалённых локациях. Но UPS не особо полезен мне в этих удалённых локациях, когда я узнаю, что батарея разряжена, только когда оборудование умирает! Мне нужно знать, когда пропало электропитание сети, чтобы у меня было время решить проблему! Я могу использовать специальные Ethernet-мониторы, которые мониторят сеть, но им тоже нужна мощность и место. И они стоят мне целое состояние! Они работают от 9В, поэтому используют свой сетевой адаптер, потому что у меня нет 9В от UPS. Из-за этого адаптер потребляет всю выходную мощность, что существенно сокращает срок службы UPS при работе от батареи. (Чтобы батарею "накачать" до 230В, а адаптер возвращает её к 9В! Это приводит к двойным потерям!). MT-устройства получают питание прямо от кабелей батареи (это моя собственная модификация). Поэтому, Routerboard переходит в спящий режим, когда напряжение падает ниже определённого уровня? Или он делает это после получения определённой команды от USB? UPS действительно отличное резервное питание в средах с ненадежным электропитанием, у меня был rb333 (три радиокарты, но только два клиента, поэтому не много активности процессора) + rb532A с двумя простаивающими картами, работавшие почти 30 часов на 500ВА UPS. Мой ПК работает только полчаса на той же UPS! Но теперь устройства умирают по два раза в месяц, что, вероятно, стоило мне радиокарты, и принесло мне недовольного клиента! Пожалуйста, помогите! Если это окажется полезной информацией, мы можем преобразовать её в понятную и чёткую информацию для WiKi! Я уверен, что многие пользователи сочтут эту информацию интересной. rgds. Руди <br />
			<i>26.02.2008 00:48:00, WirelessRudy.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294459</link>
			<guid>http://mikrotik.moscow/forum/forum58/73112-nuzhna-pomoshch-s-monitoringom-batarei-ups-dlya-routerboards./message294459</guid>
			<pubDate>Tue, 26 Feb 2008 00:48:00 -0500</pubDate>
