		<title>Mikrotik.moscow [тема: Очереди, возникающие из-за dhcp/radius – два пользователя в одной очереди?]</title>
		<description>Новое в теме Очереди, возникающие из-за dhcp/radius – два пользователя в одной очереди? форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Thu, 20 Aug 2026 02:56:46 -0400</pubDate>
			<title>Очереди, возникающие из-за dhcp/radius – два пользователя в одной очереди?</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283643">Очереди, возникающие из-за dhcp/radius – два пользователя в одной очереди?</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Hey! 👋<br /><br />Just wanted to share a quick update on what I've been working on. It's been a wild ride, but I think I'm finally starting to see the light at the end of the tunnel. 🤩<br /><br />**Here’s a breakdown of what’s been happening:**<br /><br />* &nbsp; **Frontend:** Revamped the user interface with a more modern and intuitive design. We’re using React.js for maximum flexibility and performance. ✨<br />* &nbsp; **Backend:** Integrated a new API endpoint for user authentication. Security is paramount, so we’ve implemented robust encryption and validation processes. 🛡️<br />* &nbsp; **Database:** Migrated to a more scalable database solution (PostgreSQL) to handle increased traffic and data volume. 🚀<br />* &nbsp; **Testing:** Ran comprehensive unit and integration tests to ensure everything is working flawlessly. 🧪<br /><br />**What’s next?**<br /><br />I’m currently focusing on polishing the user experience and adding some cool new features. Stay tuned for more updates! 😉<br /><br />You can check out the project on GitHub: [<noindex><a href="https://github.com/your-username/your-repo%5D(&lt;#0" target="_blank" rel="nofollow" >https://github.com/your-username/your-repo](&lt;#0</a></noindex>  >)<br /><br />#webdev #frontend #backend #reactjs #postgresql #codinglife <br />
			<i>19.07.2006 08:49:00, normis.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283643</link>
			<guid>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283643</guid>
			<pubDate>Wed, 19 Jul 2006 08:49:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283642">Очереди, возникающие из-за dhcp/radius – два пользователя в одной очереди?</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Я вообще не понимаю такой английский, и уверен, ты мой вопрос тоже не понял. Грегор <br />
			<i>19.07.2006 08:44:00, grzesjan.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283642</link>
			<guid>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283642</guid>
			<pubDate>Wed, 19 Jul 2006 08:44:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283641">Очереди, возникающие из-за dhcp/radius – два пользователя в одной очереди?</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Привет, друг! Думаю, возможно, ты можешь создать новую очередь, например, специально для этого подсети, типа xxx.xxx.xxx.0/24 [это для диапазонов в 24 бита]. Или для любой другой подсети. Мой PPPoE, hotspot и динамический вполне хватит простой очереди. Дай мне больше возможностей для экспериментов с RouterOS. Спасибо, Hasbullah.com <br />
			<i>19.07.2006 08:06:00, balimore.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283641</link>
			<guid>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283641</guid>
			<pubDate>Wed, 19 Jul 2006 08:06:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283640">Очереди, возникающие из-за dhcp/radius – два пользователя в одной очереди?</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Думаю, нельзя настроить одну очередь для двух разных пользователей HotSpot. Можно реализовать это, используя статические очереди + правила mangle. <br />
			<i>19.07.2006 09:01:00, sergejs.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283640</link>
			<guid>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283640</guid>
			<pubDate>Wed, 19 Jul 2006 09:01:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283639">Очереди, возникающие из-за dhcp/radius – два пользователя в одной очереди?</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Привет, я использую dhcp/hotspot, оба основаны на radius. Radius выдает атрибут RateLimit для dhcp, и это создает очередь и ограничивает пропускную способность для этого пользователя. В целом, всё работает. Есть ли возможность, чтобы два разных MAC-адреса, два разных пользователя, работали в одной и той же очереди? То есть, установить общий предел пропускной способности для двух или более ПК. Спасибо заранее за любые идеи.<br /><br />С уважением,<br />Gregor <br />
			<i>19.07.2006 07:44:00, grzesjan.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283639</link>
			<guid>http://mikrotik.moscow/forum/forum57/71259-ocheredi_-voznikayushchie-iz_za-dhcp_radius-_-dva-polzovatelya-v-odnoy-ocheredi/message283639</guid>
			<pubDate>Wed, 19 Jul 2006 07:44:00 -0400</pubDate>
