		<title>Mikrotik.moscow [тема: Точка доступа + мост.]</title>
		<description>Новое в теме Точка доступа + мост. форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Thu, 20 Aug 2026 16:29:52 -0400</pubDate>
			<title>Точка доступа + мост.</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278985">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Окей, ребята, вот настройки, которых мне удалось добиться для моста… / интерфейс bridge<br />add name="bridge" mtu=1500 arp=enabled stp=yes priority=32768 ageing-time=5m \<br /> &nbsp; &nbsp;forward-delay=15s garbage-collection-interval=5s hello-time=2s \<br /> &nbsp; &nbsp;max-message-age=20s comment="" disabled=no<br />/ интерфейс bridge port<br />add interface=LAN bridge=bridge priority=128 path-cost=10 comment="" \<br /> &nbsp; &nbsp;disabled=no<br />add interface=WAN2 bridge=bridge priority=128 path-cost=10 comment="" \<br /> &nbsp; &nbsp;disabled=no<br />/ интерфейс bridge broute<br />add chain=brouting in-interface=WAN2 \<br /> &nbsp; &nbsp;src-mac-address=00:00:00:00:00:10/FF:FF:FF:FF:FF:FF \<br /> &nbsp; &nbsp;dst-mac-address=00:00:00:00:00:00/00:00:00:00:00:00 action=accept \<br /> &nbsp; &nbsp;comment="" disabled=no<br />add chain=brouting in-interface=LAN \<br /> &nbsp; &nbsp;src-mac-address=00:02:3F:19:B3:0F/FF:FF:FF:FF:FF:FF \<br /> &nbsp; &nbsp;dst-mac-address=00:00:00:00:00:00/00:00:00:00:00:00 action=accept \<br /> &nbsp; &nbsp;comment="" disabled=no<br />add chain=brouting dst-mac-address=00:0C:42:06:0C:E3/FF:FF:FF:FF:FF:FF \<br /> &nbsp; &nbsp;action=accept comment="" disabled=no<br />add chain=brouting src-mac-address=00:00:00:00:00:00/00:00:00:00:00:00 \<br /> &nbsp; &nbsp;dst-mac-address=00:0C:42:06:0C:E1/FF:FF:FF:FF:FF:FF action=accept \<br /> &nbsp; &nbsp;comment="" disabled=no<br />add chain=brouting mac-protocol=arp action=accept comment="" disabled=no<br />add chain=brouting action=drop comment="drop everything else" disabled=no <br />any idea how to fix invalid hotspot? thanks <br />
			<i>20.08.2006 15:02:00, Hellbound.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278985</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278985</guid>
			<pubDate>Sun, 20 Aug 2006 15:02:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278984">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Может кто-нибудь хотя бы пример броута подкинет? Документация очень плохая и вообще без примерной настройки. Мне нужны два бриджа для каждого интерфейса? Если два интерфейса назначить на один бридж, то какой интерфейс я должен назначить на WAN IP и LAN IP? И какой интерфейс я должен назначить для хотспота? Спасибо. <br />
			<i>19.08.2006 14:48:00, Hellbound.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278984</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278984</guid>
			<pubDate>Sat, 19 Aug 2006 14:48:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278983">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Вопрос в том, после бриджа, какой интерфейс выбрать для точки доступа: LAN или Bridge? И как с настройками IP? Их назначать на Bridge-интерфейс или LAN? Спасибо. <br />
			<i>19.08.2006 10:04:00, Hellbound.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278983</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278983</guid>
			<pubDate>Sat, 19 Aug 2006 10:04:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278982">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Конечно. Но проблема в том, что мой веб-сервер находится в другом месте, и на моем управляемом коммутаторе мне пришлось подключить его к LAN-порту шлюза. Есть какие-нибудь советы по настройке моста? <br />
			<i>17.08.2006 10:45:00, Hellbound.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278982</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278982</guid>
			<pubDate>Thu, 17 Aug 2006 10:45:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278981">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Ты думал о том, чтобы выделить этому веб-серверу отдельную VLAN, которую потом можно будет объединить с WAN-интерфейсом? Eugene <br />
			<i>17.08.2006 08:50:00, Eugene.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278981</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278981</guid>
			<pubDate>Thu, 17 Aug 2006 08:50:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278980">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Вот как это выглядит, надеюсь, понятно. <br />
			<i>16.08.2006 16:48:00, Hellbound.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278980</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278980</guid>
			<pubDate>Wed, 16 Aug 2006 16:48:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278979">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Нужно быть более конкретным в описании структуры вашей сети и проблеме. <br />
			<i>16.08.2006 08:26:00, Eugene.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278979</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278979</guid>
			<pubDate>Wed, 16 Aug 2006 08:26:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278978">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Проблема в том, что все мои записи ARP будут показывать &gt; НЕАКТИВНЫ, все мои точки доступа (hotspot) будут указывать &gt; НЕАКТИВНЫ, вся сеть просто зависнет, как только я соединяю ее таким образом. Есть какие-нибудь идеи, почему так происходит? <br />
			<i>15.08.2006 05:00:00, Hellbound.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278978</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278978</guid>
			<pubDate>Tue, 15 Aug 2006 05:00:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278977">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Свяжи два интерфейса и добавь правила в таблицу маршрутизации (/interface bridge broute). Всё, что отбрасывается из таблицы маршрутизации, будет направляться. Eugene. <br />
			<i>11.08.2006 11:03:00, Eugene.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278977</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278977</guid>
			<pubDate>Fri, 11 Aug 2006 11:03:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278976">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Никто никогда не делал бриджинг в дополнение к hotspot? Мой веб-сервер уже долго лежит, пожалуйста, помогите. <br />
			<i>11.08.2006 10:57:00, Hellbound.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278976</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278976</guid>
			<pubDate>Fri, 11 Aug 2006 10:57:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278975">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			На самом деле, нет, мне нужен полностью прозрачный бридж только для указанного MAC-адреса, то есть я не хочу переводить адрес в локальный, где работают мои веб-сервер и почта. Причина в том, что если я укажу локальный адрес (например, диапазон 10.x.x.x), то панель управления программного обеспечения будет испытывать трудности с пониманием его публичного адреса и будет отбрасывать определенные HTTP-запросы. Есть какие-нибудь идеи, как реализовать бриджинг? Спасибо за ответ. <br />
			<i>10.08.2006 09:44:00, Hellbound.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278975</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278975</guid>
			<pubDate>Thu, 10 Aug 2006 09:44:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278974">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Предполагаю, вам нужно использовать полный NAT. Оставляйте приватные адреса на ваших серверах, но добавьте публичные адреса на интерфейс WAN и настройте правила NAT. <br />
			<i>10.08.2006 05:43:00, sergejs.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278974</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278974</guid>
			<pubDate>Thu, 10 Aug 2006 05:43:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278973">Точка доступа + мост.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Привет, ребята! У меня Mikrotik сервер с 3 сетевыми картами: LAN (установлен хотспот), WAN1, WAN2. У меня есть веб-сервер в сети LAN, он подключен через беспроводное соединение. Как мне сделать бридж только для MAC-адреса этого веб-сервера на WAN1, к которой подключен мой S-DSL модем? Я пробовал обычный бридж, но мой хотспот перестал работать. Буду очень благодарен за пример конфига. Спасибо! <br />
			<i>09.08.2006 17:24:00, Hellbound.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278973</link>
			<guid>http://mikrotik.moscow/forum/forum57/70303-tochka-dostupa-_-most./message278973</guid>
			<pubDate>Wed, 09 Aug 2006 17:24:00 -0400</pubDate>
