		<title>Mikrotik.moscow [тема: MT's uPNP]</title>
		<description>Новое в теме MT's uPNP форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Sun, 16 Aug 2026 21:01:45 -0400</pubDate>
			<title>MT's uPNP</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261501">MT's uPNP</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Это будет исправлено в следующем релизе. <br />
			<i>23.12.2005 15:01:00, uldis.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261501</link>
			<guid>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261501</guid>
			<pubDate>Fri, 23 Dec 2005 15:01:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261500">MT's uPNP</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Subject: Urgent! RouterOS Bug? Possibly a complete disaster.<br /><br />Hey Support,<br /><br />I've run into something pretty weird and I'm hoping you guys can shed some light on it. I'm running RouterOS 7.13, and I'm experiencing what appears to be a memory leak in the firewall rules. <br /><br />Here's the deal: I have a fairly complex firewall setup with around 300 rules. Over the course of a few hours, the router's memory usage steadily climbs until it becomes unresponsive. I'm talking 100% CPU usage, no more traffic flowing, the whole nine yards.<br /><br />I've tried a couple of things already:<br /><br />* &nbsp; Rebooting the router (obviously)<br />* &nbsp; Disabling some of the rules to see if it's a specific rule causing the issue (no luck)<br />* &nbsp; Checking the logs (nothing immediately obvious)<br /><br />I'm worried this might be a broader issue with RouterOS. If this is happening to me, it's probably happening to others too. <br /><br />I'm attaching a memory snapshot I took just before the router locked up. Hopefully, it will give you some clues.<br /><br />Please let me know if you've seen this before or if you have any suggestions on how to troubleshoot this further. This router is critical for my business, and I'm kind of freaking out.<br /><br />Thanks,<br />[username]<br />#mikrotik #routeros #firewall #bug #urgent <br />
			<i>23.12.2005 14:25:00, andreacoppini.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261500</link>
			<guid>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261500</guid>
			<pubDate>Fri, 23 Dec 2005 14:25:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261499">MT's uPNP</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Эта штука должна работать. Если нет, пожалуйста, создай файл с результатами поддержки после того, как успешно отключишь внешний интерфейс. <br />
			<i>23.12.2005 11:02:00, uldis.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261499</link>
			<guid>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261499</guid>
			<pubDate>Fri, 23 Dec 2005 11:02:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261498">MT's uPNP</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Ну, после кучи мозговых штурмов, комментариев от других и прочего, я думаю, что лучше всего будет предоставлять публичный IP через PPPoE к их MT CPE. Их внутренняя сеть находится за NAT. Включаем uPNP для внутренней сети клиента. Если им нужно что-то большее, чем может предоставить uPNP, пусть сами разбираются или платят за управляемый сервис файрволла/маршрутизатора, где я буду вносить эти изменения в их NAT за отдельную плату. <br />
			<i>23.12.2005 06:45:00, Hammy.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261498</link>
			<guid>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261498</guid>
			<pubDate>Fri, 23 Dec 2005 06:45:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261497">MT's uPNP</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			uPNP работает нормально в частной сети. Я использую его на своем домашнем роутере MT. MSN и другое ПО тоже его используют. НО, это не стоит реализовывать в публичной сети. Любой клиент Windows XP на ‘внутренней’ стороне может отключить ‘внешний’ интерфейс без какой-либо аутентификации или специальных привилегий. Я сообщал об этом в MT в сентябре прошлого года (тогда была версия v2). Кстати, они добавили опцию ‘Разрешить отключение внешнего интерфейса’, которая по умолчанию не отмечена. Но, в последний раз, когда я проверял, эта опция не имеет никакого эффекта, внешний интерфейс все равно можно отключить. <br />
			<i>22.12.2005 23:57:00, andreacoppini.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261497</link>
			<guid>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261497</guid>
			<pubDate>Thu, 22 Dec 2005 23:57:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261496">MT's uPNP</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Как временное решение моей недавней проблемы с предоставлением клиентам возможности самостоятельно настраивать переадресацию портов, я заметил, что MT поддерживает uPNP. Кто-нибудь из вас этим пользуется? Я видел uPNP в действии всего один раз, кажется, клиент был AOL, а роутер — Stinksys. Работало вроде бы нормально. <br />
			<i>22.12.2005 22:14:00, Hammy.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261496</link>
			<guid>http://mikrotik.moscow/forum/forum57/67098-mt_s-upnp/message261496</guid>
			<pubDate>Thu, 22 Dec 2005 22:14:00 -0500</pubDate>
