		<title>Mikrotik.moscow [тема: Ошибки сетевого интерфейса Ethernet]</title>
		<description>Новое в теме Ошибки сетевого интерфейса Ethernet форума Аппаратное обеспечение на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Tue, 03 Nov 2026 22:32:20 -0500</pubDate>
			<title>Ошибки сетевого интерфейса Ethernet</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261353">Ошибки сетевого интерфейса Ethernet</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Hey team! 👋<br /><br />Just wanted to give you a quick update on the project "Phoenix". We're making great progress, but we hit a slight snag with the API integration. 😅 It's nothing major, just some unexpected quirks we're working through.<br /><br />Here's a breakdown of where we're at:<br /><br />* &nbsp; **Frontend:** 90% complete - just polishing up some UI elements.<br />* &nbsp; **Backend:** 85% - API integration is the main focus now.<br />* &nbsp; **Database:** 100% - all set!<br />* &nbsp; **Testing:** 60% - focusing on API-related tests for now.<br /><br />We're aiming to have everything wrapped up by next Friday, but it might slip to Monday if we encounter more API surprises. 🤞<br /><br />Also, a friendly reminder to submit your timesheets by end of day! Don't want anyone forgetting! 😉<br /><br />Thanks,<br />[Никнейм]<br />#phoenixproject #progressupdate #timesheets #worklife <br />
			<i>24.01.2006 22:11:00, cibernet.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261353</link>
			<guid>http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261353</guid>
			<pubDate>Tue, 24 Jan 2006 22:11:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261352">Ошибки сетевого интерфейса Ethernet</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Тут никакой коммутации не было. Настройка была* полностью проброшена. Мог бы попробовать использовать другой интерфейс, но RB* находился на крыше, на улице, в 20 метрах от ближайшего источника питания, мне нужен был способ запитать плату, и поскольку только 1 порт поддерживает PoE, я не смог бы сделать это, не оставив устройство открытым. ЗАМЕЧАНИЕ: Я говорю «БЫЛ», потому что клиент в итоге отказался от всей этой затеи, и у нас остались пара антенн, глядящих в небо, и недовольный клиент. <br />
			<i>24.01.2006 22:01:00, andreacoppini.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261352</link>
			<guid>http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261352</guid>
			<pubDate>Tue, 24 Jan 2006 22:01:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261351">Ошибки сетевого интерфейса Ethernet</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Вы eth как bridge wlan используете? Попробуйте подключить устройство к другому из трех eth в RB. <br />
			<i>24.01.2006 21:49:00, cibernet.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261351</link>
			<guid>http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261351</guid>
			<pubDate>Tue, 24 Jan 2006 21:49:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261350">Ошибки сетевого интерфейса Ethernet</a></b> <i>Аппаратное обеспечение</i> в форуме <a href="http://mikrotik.moscow/forum/forum58/">Аппаратное обеспечение</a>. <br />
			Установил на объекте клиента RB532, подключил как обычно, включил, линк есть. Проблем вроде бы нет. НО, когда попытались запустить тест скорости, получили вот это: Ноутбук &gt; Ноутбук (через RB532 &gt; [RF] &gt; RB532) = примерно 10 Мбит/с Ноутбук &gt; RB532 = примерно 10 Мбит/с RB532 &gt; [RF] &gt; RB532 = примерно 22 Мбит/с Это явно говорит о проблеме, связанной с Ethernet-интерфейсом RB. Попробовал подключить RB к коммутатору клиента, а потом напрямую к своему ноутбуку, результат тот же. Так же пробовал принудительно задавать параметрам Eth-порта RB: 100/FullDuplex, 100/HalfDuplex и AutoNegotiate. Коммутаторы новые, 10/100, в локальной сети больше ничего нет. Кто-нибудь сталкивался с подобным? <br />
			<i>21.12.2005 21:41:00, andreacoppini.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261350</link>
			<guid>http://mikrotik.moscow/forum/forum58/67066-oshibki-setevogo-interfeysa-ethernet/message261350</guid>
			<pubDate>Wed, 21 Dec 2005 21:41:00 -0500</pubDate>
