		<title>Mikrotik.moscow [тема: P2P трафик на порту 80...]</title>
		<description>Новое в теме P2P трафик на порту 80... форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Tue, 18 Aug 2026 05:48:36 -0400</pubDate>
			<title>P2P трафик на порту 80...</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253388">P2P трафик на порту 80...</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Сначала зайдите в mangle и настройте ваш роутер следующим образом:<br /><br />0 chain=prerouting p2p=all-p2p src-address-list=not_me action=mark-connection new-connection-mark=p2p_conn passthrough=yes<br />1 chain=prerouting protocol=tcp dst-port=80 connection-mark=!p2p_conn src-address-list=not_me action=mark-connection new-connection-mark=http_conn passthrough=yes<br />2 chain=prerouting protocol=tcp dst-port=21 connection-mark=!p2p_conn,http_conn src-address-list=not_me action=mark-connection new-connection-mark=ftp_conn passthrough=yes<br />3 chain=prerouting protocol=tcp dst-port=110 connection-mark=!p2p_conn,http_conn,ftp_conn src-address-list=not_me action=mark-connection new-connection-mark=pop3_conn passthrough=yes<br />4 chain=forward connection-mark=p2p_conn action=mark-packet new-packet-mark=p2p_mark passthrough=yes<br />5 chain=forward protocol=tcp connection-mark=http_conn action=mark-packet new-packet-mark=http_mark passthrough=yes<br />6 chain=forward protocol=tcp connection-mark=ftp_conn action=mark-packet new-packet-mark=ftp_mark passthrough=yes<br />7 chain=forward protocol=tcp connection-mark=pop3_conn src-address-list=not_me action=mark-packet new-packet-mark=pop3_mark passthrough=yes<br /><br />Затем зайдите в queue tree и настройте его следующим образом:<br /><br />0 name=“2_http_queue” parent=local packet-mark=http_mark limit-at=614400 queue=default priority=2 max-limit=768000 burst-limit=0 burst-threshold=0 burst-time=0s<br />1 name=“6_ftp_queue” parent=local packet-mark=ftp_mark limit-at=115200 queue=default priority=6 max-limit=768000 burst-limit=0 burst-threshold=0 burst-time=0s<br />2 name=“1_pop3_queue” parent=local packet-mark=pop3_mark limit-at=38400 queue=default priority=1 max-limit=768000 burst-limit=0 burst-threshold=0 burst-time=0s<br />3 name=“p2p_down_queue” parent=local packet-mark=p2p_mark limit-at=10000 queue=default priority=8 max-limit=20000 burst-limit=0 burst-threshold=0 burst-time=0s<br /><br />Основной принцип вышеуказанной конфигурации заключается в том, что мы маркируем все типы соединений, которые хотим, затем мы маркируем их пакеты и, наконец, ставим их в очередь. &nbsp;Pop3 имеет наивысший приоритет, а p2p — самый низкий. При этом мы ограничили доступную пропускную способность для каждого типа в соответствии с нашей полосой пропускания.<br /><br />Примечание: вам придется изменить некоторые настройки, чтобы использовать их со своим соединением. <br />
			<i>04.04.2006 02:43:00, zaherhamiyah.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253388</link>
			<guid>http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253388</guid>
			<pubDate>Tue, 04 Apr 2006 02:43:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253387">P2P трафик на порту 80...</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Попробую еще раз, но когда я настраиваю это, только несколько байт отмечаются как P2P, а остальные — как что-то другое… <br />
			<i>03.04.2006 15:44:00, user19.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253387</link>
			<guid>http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253387</guid>
			<pubDate>Mon, 03 Apr 2006 15:44:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253386">P2P трафик на порту 80...</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Фильтры P2P трафика на MikroTik работают не только на основе портов, но и распознают P2P трафик по содержимому. То есть, он может обнаружить P2P трафик, проходящий через порт 80 (если RouterOS вообще определяет этот P2P протокол). В форуме и в руководстве есть множество примеров, как настроить обнаружение P2P на MikroTik. С наилучшими пожеланиями, Christian Meis <br />
			<i>03.04.2006 14:33:00, cmit.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253386</link>
			<guid>http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253386</guid>
			<pubDate>Mon, 03 Apr 2006 14:33:00 -0400</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253385">P2P трафик на порту 80...</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Привет, как можно ограничить P2P трафик, когда он идёт через порт 80? Спасибо, Димас, Колумбия. <br />
			<i>03.04.2006 14:13:00, user19.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253385</link>
			<guid>http://mikrotik.moscow/forum/forum57/65418-p2p-trafik-na-portu-80.../message253385</guid>
			<pubDate>Mon, 03 Apr 2006 14:13:00 -0400</pubDate>
