		<title>Mikrotik.moscow [тема: LVS балансировка нагрузки]</title>
		<description>Новое в теме LVS балансировка нагрузки форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Sun, 16 Aug 2026 15:42:08 -0400</pubDate>
			<title>LVS балансировка нагрузки</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248566">LVS балансировка нагрузки</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			На самом деле, я думал скорее о LVS и keepalived. <br />
			<i>01.12.2005 09:44:00, expat.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248566</link>
			<guid>http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248566</guid>
			<pubDate>Thu, 01 Dec 2005 09:44:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248565">LVS балансировка нагрузки</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			<noindex><a href="http://forum.mikrotik.com//viewtopic.php?p=22269" target="_blank" rel="nofollow" >http://forum.mikrotik.com//viewtopic.php?p=22269</a></noindex><br /><br />Hey,<br /><br />Looks like my previous post got buried. I'm having issues with IPSec VPNs and MTU.<br /><br />I'm trying to establish an IPSec VPN between two MikroTik routers. One end is behind a NAT, the other isn't. I’ve followed all the common advice on the internet – ensuring proper NAT-T configuration, checking firewall rules, and even experimenting with different MTU sizes. Nothing seems to work.<br /><br />Here's the setup:<br /><br />* &nbsp; **Router A (Behind NAT):** RouterOS v7.10<br />* &nbsp; **Router B (Public IP):** RouterOS v7.10<br />* &nbsp; **Encryption:** AES256-SHA256-DH2<br />* &nbsp; **Tunnel Mode:** IPSec Tunnel Mode<br /><br />I've tried the following MTU settings (on Router A):<br /><br />* &nbsp; 1400<br />* &nbsp; 1300<br />* &nbsp; 1200<br /><br />No matter what I set it to, the tunnel either fails to connect or experiences very slow speeds. I'm not seeing any errors in the logs, which makes troubleshooting even harder.<br /><br />Is there anything else I should try? Anyone else experienced similar issues? Any help is greatly appreciated! #mikrotik #ipsec #vpn #mtu #troubleshooting <br />
			<i>04.11.2005 16:54:00, changeip.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248565</link>
			<guid>http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248565</guid>
			<pubDate>Fri, 04 Nov 2005 16:54:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248564">LVS балансировка нагрузки</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Для входящего балансирования нагрузки ВЫ ДОЛЖНЫ сотрудничать со своими провайдерами. <br />
			<i>04.11.2005 16:43:00, Eugene.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248564</link>
			<guid>http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248564</guid>
			<pubDate>Fri, 04 Nov 2005 16:43:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248563">LVS балансировка нагрузки</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Слышал, что собираются внедрять какую-то форму входящей балансировки нагрузки. Что с этим делом вообще? Над этим работают? Когда примерно можно будет что-то увидеть? <br />
			<i>04.11.2005 14:34:00, expat.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248563</link>
			<guid>http://mikrotik.moscow/forum/forum57/64358-lvs-balansirovka-nagruzki/message248563</guid>
			<pubDate>Fri, 04 Nov 2005 14:34:00 -0500</pubDate>
