		<title>Mikrotik.moscow [тема: Полоса пропускания канала связи.]</title>
		<description>Новое в теме Полоса пропускания канала связи. форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Sun, 09 Aug 2026 23:00:36 -0400</pubDate>
			<title>Полоса пропускания канала связи.</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/60986-polosa-propuskaniya-kanala-svyazi./message232775">Полоса пропускания канала связи.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			<noindex><a href="http://www.mikrotik.com/forum/viewtopic.php?t=1906" target="_blank" rel="nofollow" >http://www.mikrotik.com/forum/viewtopic.php?t=1906</a></noindex><br /><br />Hey guys,<br /><br />Just wanted to share a quick workaround I found for getting VLANs to work on older Mikrotik routers (v2, v3) that are struggling with the native VLAN tag on bridges.<br /><br />So, I'm running a bunch of these older routers as access points, and I wanted to allow my VLAN tagged traffic to pass through them without having to upgrade the firmware. Turns out, you can use a simple route to achieve this.<br /><br />Here’s the setup:<br /><br />1. &nbsp;Create a VLAN interface.<br />2. &nbsp;Assign an IP address to the VLAN interface.<br />3. &nbsp;Create a static route with the destination being the VLAN network and the gateway being the VLAN interface.<br /><br />That's it! It's surprisingly effective. &nbsp;I was skeptical at first, but it's been working flawlessly for me.<br /><br />Just thought I'd share this little trick in case anyone else is dealing with similar limitations.<br /><br />Cheers!<br />#mikrotik #vlan #workaround <br />
			<i>27.01.2005 12:31:00, ofasa.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/60986-polosa-propuskaniya-kanala-svyazi./message232775</link>
			<guid>http://mikrotik.moscow/forum/forum57/60986-polosa-propuskaniya-kanala-svyazi./message232775</guid>
			<pubDate>Thu, 27 Jan 2005 12:31:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/60986-polosa-propuskaniya-kanala-svyazi./message232774">Полоса пропускания канала связи.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Искать. Я прочитал, этого достаточно, но тебе стоит поискать информацию о длинных связях где-то здесь. <br />
			<i>26.01.2005 14:32:00, mip.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/60986-polosa-propuskaniya-kanala-svyazi./message232774</link>
			<guid>http://mikrotik.moscow/forum/forum57/60986-polosa-propuskaniya-kanala-svyazi./message232774</guid>
			<pubDate>Wed, 26 Jan 2005 14:32:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/60986-polosa-propuskaniya-kanala-svyazi./message232773">Полоса пропускания канала связи.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Привет! Сможет ли Atheros радио на 5 ГГц обеспечить достаточную пропускную способность на расстоянии 25 км для передачи 4 Т1-канала? Спасибо. <br />
			<i>25.01.2005 20:36:00, kokopelli.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/60986-polosa-propuskaniya-kanala-svyazi./message232773</link>
			<guid>http://mikrotik.moscow/forum/forum57/60986-polosa-propuskaniya-kanala-svyazi./message232773</guid>
			<pubDate>Tue, 25 Jan 2005 20:36:00 -0500</pubDate>
