		<title>Mikrotik.moscow [тема: Результат теста: Ядро CCR выдало ошибку (Kernel panic) 6.8rc1 (обновлено: 11-01-2014)]</title>
		<description>Новое в теме Результат теста: Ядро CCR выдало ошибку (Kernel panic) 6.8rc1 (обновлено: 11-01-2014) форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Sun, 16 Aug 2026 19:31:12 -0400</pubDate>
			<title>Результат теста: Ядро CCR выдало ошибку (Kernel panic) 6.8rc1 (обновлено: 11-01-2014)</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231033">Результат теста: Ядро CCR выдало ошибку (Kernel panic) 6.8rc1 (обновлено: 11-01-2014)</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Okay, let's break down the provided crash dump information. This looks like a kernel crash dump related to a driver or system call within a Linux-based system (likely Android, given the CPU architecture and stack traces). Here's a structured analysis of the errors and what it likely indicates, focusing on interpreting the most important parts:<br /><br />**1. The Error: Kernel Panic & `strnlen` Failure**<br /><br />* &nbsp; **`Kernel Panic`**: This is the ultimate sign of a serious system error. The kernel is unable to continue operating safely.<br />* &nbsp; **`strnlen` Failure**: The core problem seems to stem from a call to the `strnlen` function, which calculates the length of a null-terminated string. `strnlen` is crucial for preventing buffer overflows. &nbsp;The fact that it's failing strongly suggests an invalid string being passed to it, or a calculation leading to an out-of-bounds access.<br /><br />**2. Trace of Function Calls Leading to the Error**<br /><br />The stack trace shows the sequence of function calls that ultimately resulted in the `strnlen` failure. Let's follow it from the bottom up (which is how stacks are organized):<br /><br />* &nbsp; **`... (Bottom of Stack)`:** (Implied, these are lower-level system calls)<br />* &nbsp; **`vfs_read`:** A kernel function for reading data from a virtual filesystem. &nbsp;This implies that the problem originated during a read operation.<br />* &nbsp; **`SyS_read`:** The system call interface for `read`. This is the function that user-space applications (like the `net` process in this case) call to request data from the kernel.<br />* &nbsp; **`handle_syscall`:** &nbsp;The kernel's entry point for system calls.<br />* &nbsp; **`seq_read`**: This function likely handles sequential reading, possibly from a driver or character device.<br />* &nbsp; **`seq_printf`**: A function often used within kernel modules for formatted output to a sequence file. &nbsp;This is a *very* significant clue. It suggests that an attempt was made to print a string within the kernel's code, but something went wrong with the string's construction or length calculation.<br />* &nbsp; **`show_interrupts`**: A function used to display interrupt information. &nbsp;Interrupts are signals triggered by hardware.<br />* &nbsp; **`handle_syscall`:** Again, the system call handler.<br />* &nbsp; **`SyS_read`:** The system call interface.<br />* &nbsp; **`vfs_read`:** The virtual filesystem read function.<br />* &nbsp; **`strnlen`**: The point of failure. It's clear that a string of an unexpected length or containing invalid characters was provided as input to `strnlen`.<br />* &nbsp;**`string.isra.2`**: This is an optimization function. It does not provide helpful details, but confirms that `strnlen` is called from an optimized context.<br /><br />**3. Processes Involved**<br /><br />* &nbsp; **`tid 279, pid 279 (net)`**: The crash originated within a process with ID 279. The name "net" indicates it's likely related to network functionality (networking driver, network manager, etc.). &nbsp;This is a primary suspect.<br />* &nbsp; **`tid 279`**: Indicates the crash is happening on the context of the `net` thread/process.<br /><br />**4. Key Suspect Areas**<br /><br />* &nbsp; **Networking Driver/Stack**: The most probable source is a networking driver or a networking-related stack within the kernel. This could be the driver for a network interface card (NIC), a wireless adapter, or a virtual network adapter.<br />* &nbsp; **`seq_printf`**: &nbsp;This points to an area within the kernel where formatted output is being generated. It suggests a driver or module is trying to log or display information, and the string being constructed for output is the problem. &nbsp;The fact that it is using sequence files is also important. This is related to tracing and debugging facilities within the kernel.<br />* &nbsp; **Kernel Log Output**: &nbsp;A driver or module might be attempting to print debugging information to the kernel log, and the string it is trying to output is malformed.<br /><br />**5. Interpreting the Cycle Number**<br /><br />The "cycle" numbers provided in the crash dump are hardware-specific timers. They are mostly irrelevant for debugging.<br /><br />**6. Possible Causes and Debugging Steps**<br /><br />* &nbsp; **Buffer Overflow**: The most likely cause is a buffer overflow. A buffer allocated to hold a string is either too small or is being overwritten, leading to an out-of-bounds access when calculating the string's length.<br />* &nbsp; **Incorrect String Length Calculation**: The code might be incorrectly calculating the length of a string, leading `strnlen` to receive an invalid value.<br />* &nbsp; **Null Pointer or Uninitialized String**: A null pointer or an uninitialized string might be passed to `strnlen`.<br />* &nbsp; **Hardware Interaction:** The bug might be related to the interaction between the kernel and a hardware device. Perhaps a device is providing unexpected data, leading to an invalid string being constructed.<br />* &nbsp; **Race Condition:** A race condition is possible, but less probable given the stack trace.<br /><br />**Debugging Suggestions:**<br /><br />1. &nbsp;**Examine the Networking Driver Code:** Start by thoroughly examining the code for the networking driver, especially any code that handles string manipulation or formatted output (using `seq_printf`).<br />2. &nbsp;**Kernel Logs and Traces:** Analyze the kernel logs for any related errors or warnings. &nbsp;You can use tools like `dmesg` to view the kernel log. &nbsp;Consider enabling more verbose kernel logging to capture more information.<br />3. &nbsp;**Kernel Debugger**: Use a kernel debugger (like GDB with QEMU) to step through the code and examine the values of variables at the time of the crash.<br />4. &nbsp;**Static Analysis Tools**: Use static analysis tools to scan the code for potential vulnerabilities, such as buffer overflows.<br />5. &nbsp;**Hardware Testing:** If the bug is hardware-related, try testing with different hardware configurations.<br />6. &nbsp;**Reproducible Test Case**: Attempt to create a reproducible test case that triggers the crash. This will make it much easier to debug the problem.<br />7. &nbsp;**Sequence File Debugging**: &nbsp;Investigate the sequence file associated with the driver or module. &nbsp;Sequence files are often used to provide runtime information about the driver.<br /><br />**In Summary:**<br /><br />This crash dump strongly suggests a bug in the kernel's networking stack, likely related to string manipulation within a driver or module and the use of `seq_printf` to generate kernel log output. The most probable cause is a buffer overflow or an incorrect string length calculation. Careful examination of the networking driver code and thorough debugging with a kernel debugger are the best approaches to pinpointing the root cause. <br />
			<i>11.01.2014 05:03:00, evharten.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231033</link>
			<guid>http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231033</guid>
			<pubDate>Sat, 11 Jan 2014 05:03:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231032">Результат теста: Ядро CCR выдало ошибку (Kernel panic) 6.8rc1 (обновлено: 11-01-2014)</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Мы решили эту проблему, можете скачать v6.8rc1 заново. <br />
			<i>10.01.2014 13:44:00, uldis.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231032</link>
			<guid>http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231032</guid>
			<pubDate>Fri, 10 Jan 2014 13:44:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231031">Результат теста: Ядро CCR выдало ошибку (Kernel panic) 6.8rc1 (обновлено: 11-01-2014)</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Обновлено до 6.8rc1 _ 2014-01-08 14:00:28: Pid: 277, comm: net, CPU: 13<br />r0 : 0xfffffff710791240 r1 : 0xfffffff71079123f r2 : 0xfffffff710791240<br />r3 : 0x0000000000000000 r4 : 0xffffffffffffffff r5 : 0xffffffffffffffff<br />r6 : 0xffffffffffffffff r7 : 0x0000000000000000 r8 : 0x0000000000000000<br />r9 : 0x0000000000000000 r10: 0xfffffff710791240 r11: 0xfffffff710791240<br />r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x0000000000000000<br />r15: 0x0000000000000050 r16: 0x000000000000000a r17: 0x0000000000000000<br />r18: 0x0000000000000000 r19: 0x0000000000000000 r20: 0xfffffe40fdd4faf0<br />r21: 0xfffffe40fdd4faa0 r22: 0xfffffe40fdd4faf8 r23: 0xfffffe40fdd4faa8<br />r24: 0xfffffe40fdd4fb00 r25: 0xfffffe40fdd4fab0 r26: 0xfffffe40fdd4fa98<br />r27: 0xfffffe40fdd4fab8 r28: 0xfffffe40fdd4fa90 r29: 0xfffffe40fdd4fac0<br />r30: 0xfffffe00f9f804ad r31: 0xfffffff710791240 r32: 0xffffffffffffffff<br />r33: 0xfffffe00f9f90000 r34: 0xfffffe40fdd4fa10 r35: 0xfffffe00f9441011<br />r36: 0xfffffe00fdab3820 r37: 0xfffffff70016a020 r38: 0xfffffe40fdd4f9f0<br />r39: 0xfffffe40fdd4fa10 r40: 0xfffffe40fdd4fc48 r41: 0xfffffe40fdd4fc80<br />r42: 0xfffffe40fdd4fc50 r43: 0xfffffe40fdd4f9c8 r44: 0x0000000000000000<br />r45: 0xfffffe40ff011000 r46: 0xfffffff500c24d18 r47: 0xfffffff7001df800<br />r48: 0xfffffe40fdd4fa08 r49: 0xfffffe00fc3025c0 r50: 0xfffffe00006e2440<br />r51: 0xfffffff500c24d18 r52: 0xfffffe40fdd4fcc0 tp : 0x000001f4ffb90000<br />sp : 0xfffffe40fdd4fa88 lr : 0xfffffff7002d8eb0<br />pc : 0xfffffff7002d68d8 ex1: 1 faultnum: 18<br />Dump инструкций:<br />28060800d107f00a 283bf945d01c128c 1400018151483000 286a6ee0514402c0 <br />&lt;5c66400000a0128a&gt; 17bff99e51483000 27fffffed1483000 283bf8055107f00b <br /><br />Начало дампа стека для tid 277, pid 277 (net) на cpu 13 в цикле 24090235803<br /> &nbsp;frame 0: 0xfffffff7002d68d8 strnlen+0x20/0x38 (sp 0xfffffe40fdd4fa88)<br /> &nbsp;frame 1: 0xfffffff7002d8eb0 string.isra.2+0x78/0x180 (sp 0xfffffe40fdd4fa88)<br /> &nbsp;frame 2: 0xfffffff7002da210 vsnprintf+0x3b0/0x7d0 (sp 0xfffffe40fdd4fac0)<br /> &nbsp;frame 3: 0xfffffff70018f9e8 seq_printf+0xb8/0x138 (sp 0xfffffe40fdd4fb90)<br /> &nbsp;frame 4: 0xfffffff7000cbc38 show_interrupts+0x488/0x538 (sp 0xfffffe40fdd4fc08)<br /> &nbsp;frame 5: 0xfffffff7001900f0 seq_read+0x4e0/0x7a0 (sp 0xfffffe40fdd4fa10)<br /> &nbsp;frame 6: 0xfffffff70018b128 openat+0x128/0x2a0 (sp 0xfffffe40fdd4fa10)<br /> &nbsp;frame 7: 0xfffffff70018ae90 __libc_read+0xe0/0x260 (sp 0xfffffe40fdd4fa10)<br /> &nbsp;frame 8: 0xfffffff70018a978 read+0x78/0x90 (sp 0xfffffe40fdd4fa10)<br /> &nbsp;frame 9: 0xfffffff700189e80 kill+0x680/0x920 (sp 0xfffffe40fdd4fa10)<br /> &nbsp;frame 10: 0x77c3ea40 0x77c3ea40 (sp 0x7ff5f440)<br /> &nbsp;frame 11: 0x77bb5140 0x77bb5140 (sp 0x7ff5f440)<br /> &nbsp;frame 12: 0x77bb6fb8 0x77bb6fb8 (sp 0x7ff5f4a0)<br /> &nbsp;frame 13: 0x77bb6cb8 0x77bb6cb8 (sp 0x7ff5f4b8)<br /> &nbsp;frame 14: 0x77b9f7e0 0x77b9f7e0 (sp 0x7ff5f4e0)<br /> &nbsp;frame 15: 0x77b9d508 0x77b9d508 (sp 0x7ff5f558)<br /> &nbsp;frame 16: 0x83e70 0x83e70 (sp 0x7ff5f5a0)<br /> &nbsp;frame 17: 0x102660 0x102660 (sp 0x7ff5fa10)<br /> &nbsp;frame 18: 0x102fe8 0x102fe8 (sp 0x7ff5fac0)<br /> &nbsp;frame 19: 0x103050 0x103050 (sp 0x7ff5fad8)<br /> &nbsp;frame 20: 0xcd9b8 0xcd9b8 (sp 0x7ff5faf0)<br /> &nbsp;frame 21: 0x1b890 0x1b890 (sp 0x7ff5fc20)<br /> &nbsp;frame 22: 0x77b2a830 0x77b2a830 (sp 0x7ff5fcb0)<br />Конец дампа стека<br />---[ end trace e56dcc5de9db7e27 ]--- <br />
			<i>09.01.2014 05:36:00, evharten.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231031</link>
			<guid>http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231031</guid>
			<pubDate>Thu, 09 Jan 2014 05:36:00 -0500</pubDate>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231030">Результат теста: Ядро CCR выдало ошибку (Kernel panic) 6.8rc1 (обновлено: 11-01-2014)</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			RB: CCR1016-12G (8GB ram) Pid: 278, comm: net, CPU: 8<br />r0 : 0xfffffff710791240 r1 : 0xfffffff71079123f r2 : 0xfffffff710791240<br />r3 : 0x0000000000000000 r4 : 0xffffffffffffffff r5 : 0xffffffffffffffff<br />r6 : 0xffffffffffffffff r7 : 0x0000000000000000 r8 : 0x0000000000000000<br />r9 : 0x0000000000000000 r10: 0xfffffff710791240 r11: 0xfffffff710791240<br />r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x0000000000000000<br />r15: 0x0000000000000050 r16: 0x000000000000000a r17: 0x0000000000000000<br />r18: 0x0000000000000000 r19: 0x0000000000000000 r20: 0xfffffe00fbdffaf0<br />r21: 0xfffffe00fbdffaa0 r22: 0xfffffe00fbdffaf8 r23: 0xfffffe00fbdffaa8<br />r24: 0xfffffe00fbdffb00 r25: 0xfffffe00fbdffab0 r26: 0xfffffe00fbdffa98<br />r27: 0xfffffe00fbdffab8 r28: 0xfffffe00fbdffa90 r29: 0xfffffe00fbdffac0<br />r30: 0xfffffe00f98804ad r31: 0xfffffff710791240 r32: 0xffffffffffffffff<br />r33: 0xfffffe00f9890000 r34: 0xfffffe00fbdffa10 r35: 0xfffffe00f9344011<br />r36: 0xfffffe40ff903820 r37: 0xfffffff70016a020 r38: 0xfffffe00fbdff9f0<br />r39: 0xfffffe00fbdffa10 r40: 0xfffffe00fbdffa18 r41: 0xfffffe00006e2540<br />r42: 0x0000000000000000 r43: 0xfffffe00fbdff9c8 r44: 0x0000000000000000<br />r45: 0xfffffe40ff011000 r46: 0xfffffff500c24d18 r47: 0xfffffff7001df800<br />r48: 0xfffffe00fbdffa08 r49: 0xfffffe00fc251eb8 r50: 0xfffffe00006e2440<br />r51: 0xfffffff500c24d18 r52: 0xfffffe00fbdffcc0 tp : 0x000001f4ffb40000<br />sp : 0xfffffe00fbdffa88 lr : 0xfffffff7002d8eb0<br />pc : 0xfffffff7002d68d8 ex1: 1 faultnum: 18<br />Instruction dump:<br />28060800d107f00a 283bf945d01c128c 1400018151483000 286a6ee0514402c0 <br />&lt;5c66400000a0128a&gt; 17bff99e51483000 27fffffed1483000 283bf8055107f00b <br /><br />Starting stack dump of tid 278, pid 278 (net) on cpu 8 at cycle 24922148319<br /> &nbsp;frame 0: 0xfffffff7002d68d8 strnlen+0x20/0x38 (sp 0xfffffe00fbdffa88)<br /> &nbsp;frame 1: 0xfffffff7002d8eb0 string.isra.2+0x78/0x180 (sp 0xfffffe00fbdffa88)<br /> &nbsp;frame 2: 0xfffffff7002da210 vsnprintf+0x3b0/0x7d0 (sp 0xfffffe00fbdffac0)<br /> &nbsp;frame 3: 0xfffffff70018f9e8 seq_printf+0xb8/0x138 (sp 0xfffffe00fbdffb90)<br /> &nbsp;frame 4: 0xfffffff7000cfe20 show_stacklogs+0x0/0x0 (sp 0xfffffe00fbdffce0)<br /> &nbsp;frame 5: 0xfffffff70017d460 kthread_park+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 6: 0xfffffff70008c478 __kthread_create+0x168/0x480 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 7: 0xfffffff700089e80 kthread_create_on_cpu+0x180/0x340 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 8: 0xfffffff700089a60 kthread_create+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 8: 0xfffffff700089a60 kthread_create+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 9: 0xfffffff700089a60 kthread_create+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 10: 0xfffffff700089a60 kthread_create+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 11: 0xfffffff700089a60 kthread_create+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 12: 0xfffffff700089a60 kthread_create+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 13: 0xfffffff700089a60 kthread_create+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 14: 0xfffffff700089a60 kthread_create+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 15: 0xfffffff700089a60 kthread_create+0x0/0x0 (sp 0xfffffe00fbdffd50)<br /> &nbsp;frame 16: 0x922c8 0x922c8 (sp 0x7fc5f558)<br /> &nbsp;frame 17: 0xbdde0 0xbdde0 (sp 0x7fc5fa10)<br /> &nbsp;frame 18: 0xbe768 0xbe768 (sp 0x7fc5fac0)<br /> &nbsp;frame 19: 0xbe7d0 0xbe7d0 (sp 0x7fc5fad8)<br /> &nbsp;frame 20: 0xd37a0 0xd37a0 (sp 0x7fc5faf0)<br /> &nbsp;frame 21: 0x1b890 0x1b890 (sp 0x7fc5fc20)<br /> &nbsp;frame 22: 0x77a7a830 0x77a7a830 (sp 0x7fc5fcb0)<br />Stack dump complete<br />---[ end trace 35e00ef426c7e435 ]---<br />ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver<br />tilegx-ohci tilegx-ohci.0: Tile-Gx OHCI<br />tilegx-ohci tilegx-ohci.0: new USB bus registered, assigned bus number 2<br />hub 2-0:1.0: USB hub found<br />hub 2-0:1.0: 1 port detected System is in a reboot loop after this. <br />
			<i>03.01.2014 05:34:00, evharten.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231030</link>
			<guid>http://mikrotik.moscow/forum/forum57/60608-rezultat-testa_-yadro-ccr-vydalo-oshibku-_kernel-panic_-6.8rc1-_obnovleno_-11_01_2014/message231030</guid>
			<pubDate>Fri, 03 Jan 2014 05:34:00 -0500</pubDate>
