		<title>Mikrotik.moscow [тема: Разрешение IP
Hey everyone!
Just wanted to let you know that I'm allowing an IP through the firewall for a new testing environment. It’s a crucial step for development, so please don't block it. Let me know if you encounter any issues or have questions.]</title>
		<description>Новое в теме Разрешение IP
Hey everyone!
Just wanted to let you know that I'm allowing an IP through the firewall for a new testing environment. It’s a crucial step for development, so please don't block it. Let me know if you encounter any issues or have questions. форума RouterOS на сайте Mikrotik.moscow [mikrotik.moscow]</description>
		<pubDate>Sun, 16 Aug 2026 19:31:26 -0400</pubDate>
			<title>Разрешение IP
Hey everyone!
Just wanted to let you know that I'm allowing an IP through the firewall for a new testing environment. It’s a crucial step for development, so please don't block it. Let me know if you encounter any issues or have questions.</title>
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226230">Разрешение IP
Hey everyone!
Just wanted to let you know that I'm allowing an IP through the firewall for a new testing environment. It’s a crucial step for development, so please don't block it. Let me know if you encounter any issues or have questions.</a></b> <i>RouterOS</i> в форуме <a href="http://mikrotik.moscow/forum/forum57/">RouterOS</a>. <br />
			Я сбросил настройки роутера и начал с нуля. Оказывается, RTP-порты 10000-20000, но у меня проблема: работает только один сервер или другой. Вот моя конфигурация: Любой из этих вариантов работает, но как сделать так, чтобы оба работали? chain=dstnat action=dst-nat to-addresses=[Asterisk-IP] protocol=udp src-port=10000-20000 chain=dstnat action=dst-nat to-addresses=[Freeswitch-IP] protocol=udp src-port=10000-20000 Заметьте: я нарисовал две трубки, но на самом деле у меня один телефон с двумя линиями, так что у обеих линий один и тот же IP. <br />
			<i>11.01.2014 05:39:00, mjutras.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226230</link>
			<guid>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226230</guid>
			<pubDate>Sat, 11 Jan 2014 05:39:00 -0500</pubDate>
Hey everyone!
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226229">Разрешение IP
Hey everyone!
			Если вы имеете в виду "порт SIP-сервиса", он включен с портами 5060-5065. Да, у меня есть другие телефоны (в других сетях), подключенные к тому же серверу, и мой телефон работает отлично, если я обхожу Mikrotik. Может, проблема именно в нем… мой сервер использует порты 16384-32768. Я добавил фильтр: Цепь:input / Протокол:UDP / Исходный порт: 16384-32768 / Действие:Accept, но это не изменило ситуацию. Сервер находится за NAT (Watchguard), но другой телефон подключается к нему без проблем. Может, стоит сделать сброс до заводских настроек и начать все сначала, попытавшись подключиться к внешнему серверу, а потом уже настраивать подключение к внутреннему? <br />
			<i>09.01.2014 21:19:00, mjutras.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226229</link>
			<guid>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226229</guid>
			<pubDate>Thu, 09 Jan 2014 21:19:00 -0500</pubDate>
Hey everyone!
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226228">Разрешение IP
Hey everyone!
			Похоже, ты не принимаешь RTP (аудио) порты для своего вызова. У тебя включен SIP ALG? NAT включен в настройках расширения на Asterisk сервере? Какой диапазон портов установлен для RTP на твоем сервере? Твой сервер напрямую на публичном IP или тоже за NAT роутером? С уважением, Александр. <br />
			<i>09.01.2014 20:26:00, Neilson.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226228</link>
			<guid>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226228</guid>
			<pubDate>Thu, 09 Jan 2014 20:26:00 -0500</pubDate>
Hey everyone!
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226227">Разрешение IP
Hey everyone!
			Я больше не уверен, в чём проблема. Попробовал отключить все фильтры блокировки и dsnat, а проблема осталась. Вот подробнее о проблеме: у меня телефон Cisco IP с двумя активными линиями. Линия 1 подключена к моему локальному SIP-серверу и работает отлично. Линия 2 подключена к удалённому SIP-серверу, линия активна, есть гудок, но если я звоню на внутренний номер в другой сети, но привязанной к тому же SIP-серверу, то звонок идет, но звука нет. Если подключить мой IP-телефон напрямую к кабельному модему, Линия 2 работает нормально. Знаю, что дело в файрволе, но не уверен, как это диагностировать. У меня 751G-2HnD с прошивкой 3.09. Любая помощь будет очень кстати. <br />
			<i>09.01.2014 14:20:00, mjutras.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226227</link>
			<guid>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226227</guid>
			<pubDate>Thu, 09 Jan 2014 14:20:00 -0500</pubDate>
Hey everyone!
			<description><![CDATA[<b><a href="http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226226">Разрешение IP
Hey everyone!
			У меня небольшая проблема. У меня есть внутренний Asterisk-сервер с клиентами за пределами моей сети, поэтому я добавил NAT, чтобы перенаправлять SIP и несколько других портов на мой внутренний IP. Работает вроде как надо. Я настроил ещё один Asterisk-сервер за пределами сети, но у меня нет к нему доступа. Проблема в Mikrotik, потому что если его обойти, то всё работает. Я настроил лог, где могу посмотреть, что происходит, когда я пытаюсь получить доступ к внешнему серверу с IP-телефона, и получаю вот это: input: in:ether1-gateway out:(none), src-mac 00:07:7d:xx:xx:xx, proto UDP, 74.xxx.xxx.xxx:27026-&gt;96.xxx.xxx.xxx:16466, len 280. Я попробовал добавить новое правило: Chain:input/ source address:74.xxx.xxx.xxx / action:Accept. Я обычно использую Winbox, так что извините, если вышеприведённая строка неформальная. Не помогло. Какие есть предложения? <br />
			<i>08.01.2014 23:49:00, mjutras.</i>]]></description>
			<link>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226226</link>
			<guid>http://mikrotik.moscow/forum/forum57/59520-razreshenie-ip-hey-everyone_-just-wanted-to-let-you-know-that-i_m-allowing-an-ip-through-the-firewall-for-a-new-testing-environment.-it_s-a-crucial-step-for-development_-so-please-don_t-block-it.-let-me-know-if-you-encounter-any-issues-or-have-questions./message226226</guid>
			<pubDate>Wed, 08 Jan 2014 23:49:00 -0500</pubDate>
